Motorola 68360 Board Support Package.
More...
| file   | bsp.h |
|   | Board Support Package for ‘Generic’ Motorola MC68360.
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "scc1" |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_scc1_driver_attach |
#define  | ATLASHSB_ESR   0x20010000L |
#define  | ATLASHSB_USICR   0x20010001L |
#define  | ATLASHSB_DSRR   0x20010002L |
#define  | ATLASHSB_LED4   0x20010004L |
#define  | ATLASHSB_ROM_U6   0xFF080000L	/* U6 flash ROM socket */ |
int  | rtems_scc1_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
void  | M360ExecuteRISC (uint16_t command) |
void *  | M360AllocateBufferDescriptors (int count) |
void *  | M360AllocateRiscTimers (int count) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
void  | _Init68360 (void) |
rtems_isr_entry  | M68Kvec [] |
char  | M360DefaultWatchdogFeeder |
int  | m360_clock_rate |
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
