Motorola 68340 Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
int  | dbug_in_char (int minor) |
void  | dbug_out_char (int minor, int ch) |
int  | dbug_char_present (int minor) |
void  | _dbug_dumpanic (void) |
void  | _Init68340 (void) |
rtems_isr_entry  | M68Kvec [] |
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
