RTEMS  5.1
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
IO Internal Library
Internal IO library API and implementation. More...
file  __usrenv.c
 RTEMS File System Location Support.
file  clonenode.c
 Clones a Node.
file  freenode.c
 Releases all Resources of a Location.
file  libio.c
 File Descriptor Routines.
file  sup_fs_check_permissions.c
 RTEMS File System Permissions Check Support.
file  sup_fs_eval_path.c
 RTEMS File Sysyem Path Eval Support.
file  sup_fs_eval_path_generic.c
 RTEMS File System Eval Generic Path.
file  sup_fs_exist_in_same_instance.c
 Checks that the Locations Exist in the Same File System Instance.
file  sup_fs_location.c
file  sup_fs_next_token.c
 RTEMS File System Eval Eat Delimiter Path.
struct  rtems_filesystem_eval_path_generic_config
#define RTEMS_FILESYSTEM_SYMLOOP_MAX   32
#define F_DUP2FD   20
#define rtems_libio_iop_to_descriptor(_iop)   ((_iop) - &rtems_libio_iops[0])
#define rtems_libio_check_is_open(_iop)
#define LIBIO_GET_IOP(_fd, _iop)
 Macro to get the iop for the specified file descriptor. More...
#define LIBIO_GET_IOP_WITH_ACCESS(_fd, _iop, _access_flags, _access_error)
 Macro to get the iop for the specified file descriptor with access flags and error. More...
#define rtems_libio_check_buffer(_buffer)
#define rtems_libio_check_count(_count)
#define rtems_filesystem_mt_entry_declare_lock_context(ctx)   rtems_interrupt_lock_context ctx
#define rtems_filesystem_mt_entry_lock(ctx)   rtems_interrupt_lock_acquire( &rtems_filesystem_mt_entry_lock_control, &ctx )
#define rtems_filesystem_mt_entry_unlock(ctx)   rtems_interrupt_lock_release( &rtems_filesystem_mt_entry_lock_control, &ctx )
typedef bool(* rtems_filesystem_eval_path_is_directory) (rtems_filesystem_eval_path_context_t *ctx, void *arg)
 Tests if the current location is a directory. More...
typedef rtems_filesystem_eval_path_generic_status(* rtems_filesystem_eval_path_eval_token) (rtems_filesystem_eval_path_context_t *ctx, void *arg, const char *token, size_t tokenlen)
 Evaluates a token. More...
typedef ssize_t(* rtems_libio_iovec_adapter) (rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
enum  rtems_filesystem_eval_path_generic_status { RTEMS_FILESYSTEM_EVAL_PATH_GENERIC_CONTINUE, RTEMS_FILESYSTEM_EVAL_PATH_GENERIC_DONE, RTEMS_FILESYSTEM_EVAL_PATH_GENERIC_NO_ENTRY }
void rtems_filesystem_location_clone (rtems_filesystem_location_info_t *clone, const rtems_filesystem_location_info_t *master)
 Clones a node. More...
void rtems_filesystem_location_free (rtems_filesystem_location_info_t *loc)
 Releases all resources of a location. More...
void rtems_libio_lock (void)
void rtems_libio_unlock (void)
rtems_libio_t * rtems_libio_allocate (void)
unsigned int rtems_libio_fcntl_flags (int fcntl_flags)
int rtems_libio_to_fcntl_flags (unsigned int flags)
void rtems_libio_free (rtems_libio_t *iop)
rtems_filesystem_location_info_t * rtems_filesystem_eval_path_start (rtems_filesystem_eval_path_context_t *ctx, const char *path, int eval_flags)
rtems_filesystem_location_info_t * rtems_filesystem_eval_path_start_with_parent (rtems_filesystem_eval_path_context_t *ctx, const char *path, int eval_flags, rtems_filesystem_location_info_t *parentloc, int parent_eval_flags)
rtems_filesystem_location_info_t * rtems_filesystem_eval_path_start_with_root_and_current (rtems_filesystem_eval_path_context_t *ctx, const char *path, size_t pathlen, int eval_flags, rtems_filesystem_global_location_t *const *global_root_ptr, rtems_filesystem_global_location_t *const *global_current_ptr)
void rtems_filesystem_eval_path_continue (rtems_filesystem_eval_path_context_t *ctx)
void rtems_filesystem_eval_path_cleanup (rtems_filesystem_eval_path_context_t *ctx)
void rtems_filesystem_eval_path_recursive (rtems_filesystem_eval_path_context_t *ctx, const char *path, size_t pathlen)
void rtems_filesystem_eval_path_cleanup_with_parent (rtems_filesystem_eval_path_context_t *ctx, rtems_filesystem_location_info_t *parentloc)
void rtems_filesystem_eval_path_restart (rtems_filesystem_eval_path_context_t *ctx, rtems_filesystem_global_location_t **newstartloc_ptr)
 Requests a path evaluation restart. More...
void rtems_filesystem_eval_path_generic (rtems_filesystem_eval_path_context_t *ctx, void *arg, const rtems_filesystem_eval_path_generic_config *config)
void rtems_filesystem_initialize (void)
 Base File System Initialization. More...
rtems_filesystem_location_info_t * rtems_filesystem_location_copy (rtems_filesystem_location_info_t *dst, const rtems_filesystem_location_info_t *src)
 Copies a location. More...
rtems_filesystem_global_location_t * rtems_filesystem_location_transform_to_global (rtems_filesystem_location_info_t *loc)
void rtems_filesystem_global_location_assign (rtems_filesystem_global_location_t **lhs_global_loc_ptr, rtems_filesystem_global_location_t *rhs_global_loc)
 Assigns a global file system location. More...
rtems_filesystem_global_location_t * rtems_filesystem_global_location_obtain (rtems_filesystem_global_location_t *const *global_loc_ptr)
 Obtains a global file system location. More...
void rtems_filesystem_global_location_release (rtems_filesystem_global_location_t *global_loc, bool deferred)
 Releases a global file system location. More...
void rtems_filesystem_location_detach (rtems_filesystem_location_info_t *detach)
void rtems_filesystem_location_copy_and_detach (rtems_filesystem_location_info_t *copy, rtems_filesystem_location_info_t *detach)
int rtems_filesystem_mknod (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
int rtems_filesystem_chdir (rtems_filesystem_location_info_t *loc)
int rtems_filesystem_chmod (const rtems_filesystem_location_info_t *loc, mode_t mode)
int rtems_filesystem_chown (const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
void rtems_filesystem_location_remove_from_mt_entry (rtems_filesystem_location_info_t *loc)
void rtems_filesystem_do_unmount (rtems_filesystem_mount_table_entry_t *mt_entry)
void rtems_filesystem_eval_path_eat_delimiter (rtems_filesystem_eval_path_context_t *ctx)
void rtems_filesystem_eval_path_next_token (rtems_filesystem_eval_path_context_t *ctx)
void rtems_filesystem_eval_path_error (rtems_filesystem_eval_path_context_t *ctx, int eno)
int rtems_filesystem_location_exists_in_same_instance_as (const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
 Checks that the locations exist in the same file system instance. More...
bool rtems_filesystem_check_access (int flags, mode_t object_mode, uid_t object_uid, gid_t object_gid)
 Checks if access to an object is allowed for the current user. More...
bool rtems_filesystem_eval_path_check_access (rtems_filesystem_eval_path_context_t *ctx, int eval_flags, mode_t node_mode, uid_t node_uid, gid_t node_gid)
const uint32_t rtems_libio_number_iops
rtems_libio_t rtems_libio_iops []
void * rtems_libio_iop_free_head
void ** rtems_libio_iop_free_tail
const rtems_filesystem_file_handlers_r rtems_filesystem_null_handlers
rtems_filesystem_mount_table_entry_t rtems_filesystem_null_mt_entry
rtems_filesystem_global_location_t rtems_filesystem_global_location_null
 The global null location. More...
rtems_interrupt_lock rtems_filesystem_mt_entry_lock_control
◆ LIBIO_GET_IOP
#define LIBIO_GET_IOP (   _fd,
  _iop
Value:
do { \
unsigned int _flags; \
if ( (uint32_t) ( _fd ) >= rtems_libio_number_iops ) { \
rtems_set_errno_and_return_minus_one( EBADF ); \
_iop = rtems_libio_iop( _fd ); \
_flags = rtems_libio_iop_hold( _iop ); \
if ( ( _flags & LIBIO_FLAGS_OPEN ) == 0 ) { \
rtems_libio_iop_drop( _iop ); \
} while ( 0 )
Checks that the file descriptor is in the valid range and open.
◆ LIBIO_GET_IOP_WITH_ACCESS
#define LIBIO_GET_IOP_WITH_ACCESS (   _fd,
  _iop,
  _access_flags,
  _access_error
Value:
do { \
unsigned int _mandatory; \
_mandatory = LIBIO_FLAGS_OPEN | ( _access_flags ); \
if ( ( _flags & _mandatory ) != _mandatory ) { \
int _error; \
_error = EBADF; \
} else { \
_error = _access_error; \
rtems_set_errno_and_return_minus_one( _error ); \
} while ( 0 )
◆ rtems_libio_check_buffer
#define rtems_libio_check_buffer (   _buffer)
Value:
do { \
if ((_buffer) == 0) { \
errno = EINVAL; \
return -1; \
} while (0)
◆ rtems_libio_check_count
#define rtems_libio_check_count (   _count)
Value:
do { \
if ((_count) == 0) { \
return 0; \
} while (0)
◆ rtems_libio_check_is_open
#define rtems_libio_check_is_open (   _iop)
Value:
do { \
if ((rtems_libio_iop_flags(_iop) & LIBIO_FLAGS_OPEN) == 0) { \
errno = EBADF; \
return -1; \
} while (0)
Typedef Documentation
◆ rtems_filesystem_eval_path_eval_token
Evaluates a token.
Parameters
[in,out]ctxThe path evaluation context.
[in,out]argThe handler argument.
[in]tokenThe token contents.
[in]tokenlenThe token length in characters.
Return values
statusThe generic path evaluation status.
See also
rtems_filesystem_eval_path_generic().
◆ rtems_filesystem_eval_path_is_directory
Parameters
Return values
trueThe current location is a directory.
falseOtherwise.
See also
◆ rtems_filesystem_check_access()
bool rtems_filesystem_check_access ( int  flags,
mode_t  object_mode,
uid_t  object_uid,
gid_t  object_gid
If the effective UID is zero or equals the UID of the object, then the user permission flags of the object will be used. Otherwise if the effective GID is zero or equals the GID of the object or one of the supplementary group IDs is equal to the GID of the object, then the group permission flags of the object will be used. Otherwise the other permission flags of the object will be used.
Parameters
[in]flagsThe flags determining the access type. It can be RTEMS_FS_PERMS_READ, RTEMS_FS_PERMS_WRITE or RTEMS_FS_PERMS_EXEC.
[in]object_modeThe mode of the object specifying the permission flags.
[in]object_uidThe UID of the object.
[in]object_gidThe GID of the object.
Return values
trueAccess is allowed.
falseOtherwise.
◆ rtems_filesystem_eval_path_restart()
void rtems_filesystem_eval_path_restart ( rtems_filesystem_eval_path_context_t *  ctx,
rtems_filesystem_global_location_t **  newstartloc_ptr
Sets the start and current location to the new start location. The caller must terminate its current evaluation process. The path evaluation continues in the next loop iteration within rtems_filesystem_eval_path_continue(). This avoids recursive invocations. The function obtains the new start location and clones it to set the new current location. The previous start and current locations are released.
Parameters
[in,out]newstartloc_ptrPointer to the new start location.
◆ rtems_filesystem_global_location_assign()
void rtems_filesystem_global_location_assign ( rtems_filesystem_global_location_t **  lhs_global_loc_ptr,
rtems_filesystem_global_location_t *  rhs_global_loc
Parameters
[in,out]lhs_global_loc_ptrPointer to the global left hand side file system location. The current left hand side location will be released.
[in]rhs_global_locThe global right hand side file system location.
◆ rtems_filesystem_global_location_obtain()
rtems_filesystem_global_location_t* rtems_filesystem_global_location_obtain ( rtems_filesystem_global_location_t *const *  global_loc_ptr)
Deferred releases will be processed in this function.
This function must be called from normal thread context and may block on a mutex. Thread dispatching is disabled to protect some critical sections.
Parameters
[in]global_loc_ptrPointer to the global file system location.
Returns
A global file system location. It returns always a valid object. In case of an error, the global null location will be returned. Each operation or handler of the null location returns an error status. The errno indicates the error. The NULL pointer is never returned.
See also
rtems_filesystem_location_transform_to_global(), rtems_filesystem_global_location_obtain_null(), and rtems_filesystem_global_location_release().
◆ rtems_filesystem_global_location_release()
void rtems_filesystem_global_location_release ( rtems_filesystem_global_location_t *  global_loc,
bool  deferred
In case the reference count reaches zero, all associated resources will be released. This may include the complete unmount of the corresponding file system instance.
This function may block on a mutex. It may be called within critical sections of the operating system. In this case the release will be deferred. The next obtain call will do the actual release.
Parameters
[in]global_locThe global file system location. It must not be NULL.
[in]deferredIf true, then do a deferred release, otherwise release it immediately.
See also
rtems_filesystem_global_location_obtain().
◆ rtems_filesystem_initialize()
void rtems_filesystem_initialize ( void  )
Initialize the foundation of the file system. This is specified by the structure rtems_filesystem_mount_table. The usual configuration is a single instantiation of the IMFS or miniIMFS with a single "/dev" directory in it.
◆ rtems_filesystem_location_clone()
void rtems_filesystem_location_clone ( rtems_filesystem_location_info_t *  clone,
const rtems_filesystem_location_info_t *  master
Clones a node.
The caller must hold the file system instance lock.
Parameters
[out]cloneThe cloned location.
[in]masterThe master location.
See also
rtems_filesystem_instance_lock().
◆ rtems_filesystem_location_copy()
rtems_filesystem_location_info_t* rtems_filesystem_location_copy ( rtems_filesystem_location_info_t *  dst,
const rtems_filesystem_location_info_t *  src
Copies a location.
A bitwise copy is performed. The destination location will be added to the corresponding mount entry.
Parameters
[out]dstThe destination location.
[in]srcThe source location.
Return values
See also
rtems_filesystem_location_clone().
◆ rtems_filesystem_location_exists_in_same_instance_as()
int rtems_filesystem_location_exists_in_same_instance_as ( const rtems_filesystem_location_info_t *  a,
const rtems_filesystem_location_info_t *  b
Return values
0The locations exist and are in the same file system instance.
-1An error occurred. The errno indicates the error.
◆ rtems_filesystem_location_free()
void rtems_filesystem_location_free ( rtems_filesystem_location_info_t *  loc)
This function may block on a mutex and may complete an unmount process.
Parameters
[in]locThe location to free.
Note
The file system root location is released by the file system instance destruction handler (see rtems_filesystem_fsunmount_me_t).
See also
rtems_filesystem_freenode_t.
◆ rtems_libio_allocate()
rtems_libio_t* rtems_libio_allocate ( void  )
This routine searches the IOP Table for an unused entry. If it finds one, it returns it. Otherwise, it returns NULL.
◆ rtems_libio_fcntl_flags()
unsigned int rtems_libio_fcntl_flags ( int  fcntl_flags)
Convert UNIX fnctl(2) flags to ones that RTEMS drivers understand
◆ rtems_libio_free()
void rtems_libio_free ( rtems_libio_t *  iop)
This routine frees the resources associated with an IOP (file descriptor) and clears the slot in the IOP Table.
◆ rtems_libio_to_fcntl_flags()
int rtems_libio_to_fcntl_flags ( unsigned int  flags)
Convert RTEMS internal flags to UNIX fnctl(2) flags
Variable Documentation
◆ rtems_filesystem_global_location_null
Every operation and the open and fstat handlers of this location returns an error status. The errno is not touched by these operations and handlers. The purpose of this location is to deliver the error return status for a previous error condition which must set the errno accordingly.
The usage of this null location instead of the NULL pointer eliminates a lot of branches.
The user environment root and current directory are statically initialized with the null location. Due to that all file system services are in a defined state even if no root file system was mounted.
