This type definition enumerates all the interrupt identification types.
| Enumerator |
| ALT_INT_INTERRUPT_SGI0  |
| ALT_INT_INTERRUPT_SGI1  |
| ALT_INT_INTERRUPT_SGI2  |
| ALT_INT_INTERRUPT_SGI3  |
| ALT_INT_INTERRUPT_SGI4  |
| ALT_INT_INTERRUPT_SGI5  |
| ALT_INT_INTERRUPT_SGI6  |
| ALT_INT_INTERRUPT_SGI7  |
| ALT_INT_INTERRUPT_SGI8  |
| ALT_INT_INTERRUPT_SGI9  |
| ALT_INT_INTERRUPT_SGI10  |
| ALT_INT_INTERRUPT_SGI11  |
| ALT_INT_INTERRUPT_SGI12  |
| ALT_INT_INTERRUPT_SGI13  |
| ALT_INT_INTERRUPT_SGI14  |
| ALT_INT_INTERRUPT_SGI15  | Software Generated Interrupts (SGI), 0 - 15.
- All interrupts in this group are software triggered.
| ALT_INT_INTERRUPT_PPI_TIMER_GLOBAL  |
| ALT_INT_INTERRUPT_PPI_TIMER_PRIVATE  |
| ALT_INT_INTERRUPT_PPI_TIMER_WATCHDOG  |
 Private Peripheral Interrupts (PPI) for the Global Timer, per CPU private timer, and watchdog timer.
- All interrupts in this group are edge triggered.
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_BTAC  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_GHB  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_TAG  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_DATA  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_TLB  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_OUTER  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_TAG  |
| ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_DATA  |
| ALT_INT_INTERRUPT_CPU0_DEFLAGS0  |
| ALT_INT_INTERRUPT_CPU0_DEFLAGS1  |
| ALT_INT_INTERRUPT_CPU0_DEFLAGS2  |
| ALT_INT_INTERRUPT_CPU0_DEFLAGS3  |
| ALT_INT_INTERRUPT_CPU0_DEFLAGS4  |
| ALT_INT_INTERRUPT_CPU0_DEFLAGS5  |
| ALT_INT_INTERRUPT_CPU0_DEFLAGS6  | Interrupts sourced from CPU0.
The ALT_INT_INTERRUPT_CPU0_PARITYFAIL interrupt combines the BTAC, GHB, I_TAG, I_DATA, TLB, D_OUTER, D_TAG, and D_DATA interrupts for CPU0.
- PARITYFAIL interrupts in this group are edge triggered.
- DEFFLAGS interrupts in this group are level triggered.
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_BTAC  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_GHB  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_TAG  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_DATA  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_TLB  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_OUTER  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_TAG  |
| ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_DATA  |
| ALT_INT_INTERRUPT_CPU1_DEFLAGS0  |
| ALT_INT_INTERRUPT_CPU1_DEFLAGS1  |
| ALT_INT_INTERRUPT_CPU1_DEFLAGS2  |
| ALT_INT_INTERRUPT_CPU1_DEFLAGS3  |
| ALT_INT_INTERRUPT_CPU1_DEFLAGS4  |
| ALT_INT_INTERRUPT_CPU1_DEFLAGS5  |
| ALT_INT_INTERRUPT_CPU1_DEFLAGS6  | Interrupts sourced from CPU1.
The ALT_INT_INTERRUPT_CPU1_PARITYFAIL interrupt combines the BTAC, GHB, I_TAG, I_DATA, TLB, D_OUTER, D_TAG, and D_DATA interrupts for CPU1.
| ALT_INT_INTERRUPT_SCU_PARITYFAIL0  |
| ALT_INT_INTERRUPT_SCU_PARITYFAIL1  |
| ALT_INT_INTERRUPT_SCU_EV_ABORT  | Interrupts sourced from the Snoop Control Unit (SCU).
| ALT_INT_INTERRUPT_L2_ECC_BYTE_WR_IRQ  |
| ALT_INT_INTERRUPT_L2_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_L2_ECC_UNCORRECTED_IRQ  |
| ALT_INT_INTERRUPT_L2_COMBINED_IRQ  | Interrupts sourced from the L2 Cache Controller.
The ALT_INT_INTERRUPT_L2_COMBINED_IRQ interrupt combines the cache controller internal DECERRINTR, ECNTRINTR, ERRRDINTR, ERRRTINTR, ERRWDINTR, ERRWTINTR, PARRDINTR, PARRTINTR, and SLVERRINTR interrupts. Consult the L2C documentation for information on these interrupts.
- ECC interrupts in this group are edge triggered.
- Other interrupts in this group are level triggered.
| ALT_INT_INTERRUPT_DDR_ECC_ERROR_IRQ  | Interrupts sourced from the SDRAM Controller.
- All interrupts in this group are level triggered.
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ0  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ1  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ2  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ3  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ4  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ5  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ6  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ7  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ8  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ9  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ10  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ11  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ12  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ13  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ14  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ15  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ16  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ17  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ18  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ19  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ20  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ21  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ22  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ23  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ24  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ25  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ26  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ27  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ28  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ29  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ30  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ31  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ32  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ33  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ34  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ35  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ36  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ37  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ38  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ39  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ40  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ41  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ42  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ43  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ44  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ45  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ46  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ47  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ48  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ49  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ50  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ51  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ52  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ53  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ54  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ55  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ56  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ57  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ58  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ59  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ60  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ61  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ62  |
| ALT_INT_INTERRUPT_F2S_FPGA_IRQ63  | Interrupt request from the FPGA logic, 0 - 63.
- Trigger type depends on the implementation in the FPGA.
| ALT_INT_INTERRUPT_DMA_IRQ0  |
| ALT_INT_INTERRUPT_DMA_IRQ1  |
| ALT_INT_INTERRUPT_DMA_IRQ2  |
| ALT_INT_INTERRUPT_DMA_IRQ3  |
| ALT_INT_INTERRUPT_DMA_IRQ4  |
| ALT_INT_INTERRUPT_DMA_IRQ5  |
| ALT_INT_INTERRUPT_DMA_IRQ6  |
| ALT_INT_INTERRUPT_DMA_IRQ7  |
| ALT_INT_INTERRUPT_DMA_IRQ_ABORT  |
| ALT_INT_INTERRUPT_DMA_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_DMA_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the DMA Controller.
| ALT_INT_INTERRUPT_EMAC0_IRQ  |
| ALT_INT_INTERRUPT_EMAC0_TX_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_EMAC0_TX_ECC_UNCORRECTED_IRQ  |
| ALT_INT_INTERRUPT_EMAC0_RX_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_EMAC0_RX_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the Ethernet MAC 0 (EMAC0).
| ALT_INT_INTERRUPT_EMAC1_IRQ  |
| ALT_INT_INTERRUPT_EMAC1_TX_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_EMAC1_TX_ECC_UNCORRECTED_IRQ  |
| ALT_INT_INTERRUPT_EMAC1_RX_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_EMAC1_RX_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the Ethernet MAC 1 (EMAC1).
| ALT_INT_INTERRUPT_USB0_IRQ  |
| ALT_INT_INTERRUPT_USB0_ECC_CORRECTED  |
| ALT_INT_INTERRUPT_USB0_ECC_UNCORRECTED  | Interrupts sourced from the USB OTG 0.
| ALT_INT_INTERRUPT_USB1_IRQ  |
| ALT_INT_INTERRUPT_USB1_ECC_CORRECTED  |
| ALT_INT_INTERRUPT_USB1_ECC_UNCORRECTED  | Interrupts sourced from the USB OTG 1.
| ALT_INT_INTERRUPT_CAN0_STS_IRQ  |
| ALT_INT_INTERRUPT_CAN0_MO_IRQ  |
| ALT_INT_INTERRUPT_CAN0_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_CAN0_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the CAN Controller 0.
| ALT_INT_INTERRUPT_CAN1_STS_IRQ  |
| ALT_INT_INTERRUPT_CAN1_MO_IRQ  |
| ALT_INT_INTERRUPT_CAN1_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_CAN1_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the CAN Controller 1.
| ALT_INT_INTERRUPT_SDMMC_IRQ  |
| ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_CORRECTED  |
| ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_UNCORRECTED  |
| ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_CORRECTED  |
| ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_UNCORRECTED  | Interrupts sourced from the SDMMC Controller.
| ALT_INT_INTERRUPT_NAND_IRQ  |
| ALT_INT_INTERRUPT_NANDR_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_NANDR_ECC_UNCORRECTED_IRQ  |
| ALT_INT_INTERRUPT_NANDW_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_NANDW_ECC_UNCORRECTED_IRQ  |
| ALT_INT_INTERRUPT_NANDE_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_NANDE_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the NAND Controller.
| ALT_INT_INTERRUPT_QSPI_IRQ  |
| ALT_INT_INTERRUPT_QSPI_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_QSPI_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the QSPI Controller.
| ALT_INT_INTERRUPT_SPI0_IRQ  |
| ALT_INT_INTERRUPT_SPI1_IRQ  |
| ALT_INT_INTERRUPT_SPI2_IRQ  |
| ALT_INT_INTERRUPT_SPI3_IRQ  | Interrupts sourced from the SPI Controllers 0 - 3. SPI0_IRQ corresponds to SPIM0. SPI1_IRQ corresponds to SPIM1. SPI2_IRQ corresponds to SPIS0. SPI3_IRQ corresponds to SPIS1.
| ALT_INT_INTERRUPT_I2C0_IRQ  |
| ALT_INT_INTERRUPT_I2C1_IRQ  |
| ALT_INT_INTERRUPT_I2C2_IRQ  |
| ALT_INT_INTERRUPT_I2C3_IRQ  | Interrupts sourced from the I2C Controllers 0 - 3.
| ALT_INT_INTERRUPT_UART0  |
| ALT_INT_INTERRUPT_UART1  | Interrupts sourced from the UARTs 0 - 1.
| ALT_INT_INTERRUPT_GPIO0  |
| ALT_INT_INTERRUPT_GPIO1  |
| ALT_INT_INTERRUPT_GPIO2  | Interrupts sourced from the GPIO 0 - 2.
| ALT_INT_INTERRUPT_TIMER_L4SP_0_IRQ  |
| ALT_INT_INTERRUPT_TIMER_L4SP_1_IRQ  |
| ALT_INT_INTERRUPT_TIMER_OSC1_0_IRQ  |
| ALT_INT_INTERRUPT_TIMER_OSC1_1_IRQ  | Interrupts sourced from the Timer controllers.
| ALT_INT_INTERRUPT_WDOG0_IRQ  |
| ALT_INT_INTERRUPT_WDOG1_IRQ  | Interrupts sourced from the Watchdog Timers 0 - 1.
| ALT_INT_INTERRUPT_CLKMGR_IRQ  | Interrupts sourced from the Clock Manager.
| ALT_INT_INTERRUPT_MPUWAKEUP_IRQ  | Interrupts sourced from the Clock Manager MPU Wakeup.
| ALT_INT_INTERRUPT_FPGA_MAN_IRQ  | Interrupts sourced from the FPGA Manager.
| ALT_INT_INTERRUPT_NCTIIRQ0  |
| ALT_INT_INTERRUPT_NCTIIRQ1  | Interrupts sourced from the CoreSight for CPU0 and CPU1's CTI.
| ALT_INT_INTERRUPT_RAM_ECC_CORRECTED_IRQ  |
| ALT_INT_INTERRUPT_RAM_ECC_UNCORRECTED_IRQ  | Interrupts sourced from the On-chip RAM.
