RTEMS  5.1
int rtems_deviceio_open (rtems_libio_t *iop, const char *path, int oflag, mode_t mode, rtems_device_major_number major, rtems_device_minor_number minor)
 IMFS device node handlers. More...
int rtems_deviceio_close (rtems_libio_t *iop, rtems_device_major_number major, rtems_device_minor_number minor)
ssize_t rtems_deviceio_read (rtems_libio_t *iop, void *buf, size_t nbyte, rtems_device_major_number major, rtems_device_minor_number minor)
ssize_t rtems_deviceio_write (rtems_libio_t *iop, const void *buf, size_t nbyte, rtems_device_major_number major, rtems_device_minor_number minor)
int rtems_deviceio_control (rtems_libio_t *iop, ioctl_command_t command, void *buffer, rtems_device_major_number major, rtems_device_minor_number minor)
This contains the interface to device drivers using the RTEMS Classic API.
◆ rtems_deviceio_open()
int rtems_deviceio_open ( rtems_libio_t *  iop,
const char *  path,
int  oflag,
mode_t  mode,
IMFS Device Node Handlers
This file contains the set of handlers used to map operations on IMFS device nodes onto calls to the RTEMS Classic API IO Manager.
