RTEMS  5.1
gpio-support.c File Reference
RTEMS GPIO API implementation. More...
#include <rtems/score/atomic.h>
#include <rtems/chain.h>
#include <bsp/irq-generic.h>
#include <bsp/gpio.h>
#include <assert.h>
struct  rtems_gpio_group
 Object containing relevant information about a GPIO group. More...
struct  gpio_handler_node
 Object containing relevant information to a list of user-defined interrupt handlers. More...
struct  gpio_pin_interrupt_state
 Object containing relevant information of a pin's interrupt configuration/state. More...
struct  gpio_pin
 Object containing information on a GPIO pin. More...
struct  gpio_bank
 Object containing relevant information regarding a GPIO bank state. More...
#define MUTEX_ATTRIBUTES
 GPIO API mutex attributes. More...
#define CREATE_LOCK(name, lock_id)
#define ACQUIRE_LOCK(m)
#define RELEASE_LOCK(m)   assert ( rtems_semaphore_release(m) == RTEMS_SUCCESSFUL )
#define BANK_NUMBER(pin_number)   pin_number / BSP_GPIO_PINS_PER_BANK
#define PIN_NUMBER(pin_number)   pin_number % BSP_GPIO_PINS_PER_BANK
rtems_status_code rtems_gpio_initialize (void)
 Initializes the GPIO API. More...
rtems_gpio_group * rtems_gpio_create_pin_group (void)
 Instantiates a GPIO pin group. To define the group. More...
rtems_status_code rtems_gpio_define_pin_group (const rtems_gpio_group_definition *group_definition, rtems_gpio_group *group)
rtems_status_code rtems_gpio_write_group (uint32_t data, rtems_gpio_group *group)
 Writes a value to the group's digital outputs. The pins order is as defined in the group definition. More...
uint32_t rtems_gpio_read_group (rtems_gpio_group *group)
 Reads the value/level of the group's digital inputs. The pins order is as defined in the group definition. More...
rtems_status_code rtems_gpio_group_bsp_specific_operation (rtems_gpio_group *group, void *arg)
 Performs a BSP specific operation on a group of pins. The pins order is as defined in the group definition. More...
rtems_status_code rtems_gpio_multi_select (const rtems_gpio_pin_conf *pins, uint8_t pin_count)
rtems_status_code rtems_gpio_request_configuration (const rtems_gpio_pin_conf *conf)
 Requests a GPIO pin configuration. More...
rtems_status_code rtems_gpio_update_configuration (const rtems_gpio_pin_conf *conf)
 Updates the current configuration of a GPIO pin . More...
rtems_status_code rtems_gpio_multi_set (uint32_t *pin_numbers, uint32_t pin_count)
 Sets multiple output GPIO pins with the logical high. More...
rtems_status_code rtems_gpio_multi_clear (uint32_t *pin_numbers, uint32_t pin_count)
 Sets multiple output GPIO pins with the logical low. More...
uint32_t rtems_gpio_multi_read (uint32_t *pin_numbers, uint32_t pin_count)
 Returns the value (level) of multiple GPIO input pins. More...
rtems_status_code rtems_gpio_set (uint32_t pin_number)
 Sets an output GPIO pin with the logical high. More...
rtems_status_code rtems_gpio_clear (uint32_t pin_number)
 Sets an output GPIO pin with the logical low. More...
int rtems_gpio_get_value (uint32_t pin_number)
 Returns the value (level) of a GPIO input pin. More...
rtems_status_code rtems_gpio_request_pin (uint32_t pin_number, rtems_gpio_function function, bool output_enabled, bool logic_invert, void *bsp_specific)
rtems_status_code rtems_gpio_resistor_mode (uint32_t pin_number, rtems_gpio_pull_mode mode)
 Configures a single GPIO pin pull resistor. More...
rtems_status_code rtems_gpio_release_pin (uint32_t pin_number)
 Releases a GPIO pin, making it available to be used again. More...
rtems_status_code rtems_gpio_release_configuration (const rtems_gpio_pin_conf *conf)
rtems_status_code rtems_gpio_release_multiple_pins (const rtems_gpio_pin_conf *pins, uint32_t pin_count)
rtems_status_code rtems_gpio_release_pin_group (rtems_gpio_group *group)
 Releases a GPIO pin group, making the pins used available to be repurposed. More...
rtems_status_code rtems_gpio_debounce_switch (uint32_t pin_number, int ticks)
 Attaches a debouncing function to a given pin/switch. Debouncing is done by requiring a certain number of clock ticks to pass between interrupts. Any interrupt fired too close to the last will be ignored as it is probably the result of an involuntary switch/button bounce after being released. More...
rtems_status_code rtems_gpio_interrupt_handler_install (uint32_t pin_number, rtems_gpio_irq_state(*handler)(void *arg), void *arg)
 Connects a new user-defined interrupt handler to a given pin. More...
rtems_status_code rtems_gpio_enable_interrupt (uint32_t pin_number, rtems_gpio_interrupt interrupt, rtems_gpio_handler_flag flag, bool threaded_handling, rtems_gpio_irq_state(*handler)(void *arg), void *arg)
rtems_status_code rtems_gpio_interrupt_handler_remove (uint32_t pin_number, rtems_gpio_irq_state(*handler)(void *arg), void *arg)
 Disconnects an user-defined interrupt handler from the given pin. If in the end there are no more user-defined handlers connected to the pin, interrupts are disabled on the given pin. More...
rtems_status_code rtems_gpio_disable_interrupt (uint32_t pin_number)
 Stops interrupts from being generated on a given GPIO pin and removes the corresponding handler. More...
◆ ACQUIRE_LOCK
#define ACQUIRE_LOCK (   m)
Value:
Definition: status.h:47
rtems_status_code rtems_semaphore_obtain(rtems_id id, rtems_option option_set, rtems_interval timeout)
RTEMS Obtain Semaphore.
Definition: semobtain.c:51
#define RTEMS_WAIT
Definition: options.h:53
#define RTEMS_NO_TIMEOUT
Constant for indefinite wait.
Definition: rtems.h:174
◆ CREATE_LOCK
#define CREATE_LOCK (   name,
  lock_id
Value:
name, \
1, \
0, \
lock_id \
Definition: gpio-support.c:27
rtems_status_code rtems_semaphore_create(rtems_name name, uint32_t count, rtems_attribute attribute_set, rtems_task_priority priority_ceiling, rtems_id *id)
Definition: semcreate.c:34
◆ MUTEX_ATTRIBUTES
Value:
RTEMS_LOCAL \
#define RTEMS_BINARY_SEMAPHORE
Definition: attr.h:103
#define RTEMS_PRIORITY
Definition: attr.h:67
#define RTEMS_NO_PRIORITY_CEILING
Definition: attr.h:129
#define RTEMS_INHERIT_PRIORITY
Definition: attr.h:123
◆ rtems_gpio_clear()
rtems_status_code rtems_gpio_clear ( uint32_t  pin_number)
Parameters
[in]pin_numberGPIO pin number.
Return values
RTEMS_SUCCESSFULPin was cleared successfully.
RTEMS_INVALID_IDPin number is invalid.
RTEMS_NOT_CONFIGUREDThe received pin is not configured as a digital output.
RTEMS_UNSATISFIEDCould not clear the GPIO pin.
◆ rtems_gpio_create_pin_group()
rtems_gpio_group* rtems_gpio_create_pin_group ( void  )
See also
rtems_gpio_define_pin_group().
Return values
rtems_gpio_grouppointer.
◆ rtems_gpio_debounce_switch()
rtems_status_code rtems_gpio_debounce_switch ( uint32_t  pin_number,
int  ticks
Parameters
[in]ticksMinimum number of clock ticks that must pass between interrupts so it can be considered a legitimate interrupt.
Return values
RTEMS_SUCCESSFULDebounce function successfully attached to the pin.
RTEMS_NOT_CONFIGUREDThe current pin is not configured as a digital input, hence it can not be connected to a switch, or interrupts are not enabled for this pin.
◆ rtems_gpio_disable_interrupt()
rtems_status_code rtems_gpio_disable_interrupt ( uint32_t  pin_number)
Parameters
Return values
RTEMS_SUCCESSFULInterrupt successfully disabled for this pin.
RTEMS_NOT_CONFIGUREDPin has no active interrupts.
RTEMS_UNSATISFIEDCould not remove the current interrupt handler, could not recognize the current active interrupt on this pin or could not disable interrupts on this pin.
◆ rtems_gpio_get_value()
int rtems_gpio_get_value ( uint32_t  pin_number)
Parameters
Return values
Thefunction returns 0 or 1 depending on the pin current logical value.
-1Pin number is invalid, or not a digital input pin.
◆ rtems_gpio_group_bsp_specific_operation()
rtems_status_code rtems_gpio_group_bsp_specific_operation ( rtems_gpio_group *  group,
void *  arg
Parameters
[in]groupReference to the group.
[in]argPointer to a BSP defined structure with BSP-specific data. This field is handled by the BSP.
Return values
RTEMS_SUCCESSFULOperation completed with success.
RTEMS_NOT_DEFINEDGroup has no BSP specific pins, or the BSP does not support BSP specific operations for groups.
RTEMS_UNSATISFIEDCould not operate on at least one of the pins.
◆ rtems_gpio_initialize()
rtems_status_code rtems_gpio_initialize ( void  )
Return values
RTEMS_SUCCESSFULAPI successfully initialized.
See also
rtems_semaphore_create().
◆ rtems_gpio_interrupt_handler_install()
rtems_status_code rtems_gpio_interrupt_handler_install ( uint32_t  pin_number,
rtems_gpio_irq_state(*)(void *arg)  handler,
void *  arg
Parameters
[in]handlerPointer to a function that will be called every time the enabled interrupt for the given pin is generated. This function must return information about its handled/unhandled state.
[in]argVoid pointer to the arguments of the user-defined handler.
Return values
RTEMS_SUCCESSFULHandler successfully connected to this pin.
RTEMS_NO_MEMORYCould not connect more user-defined handlers to the given pin.
RTEMS_NOT_CONFIGUREDThe given pin has no interrupt configured.
RTEMS_TOO_MANYThe pin's current handler is set as unique.
RTEMS_RESOURCE_IN_USEThe current user-defined handler for this pin is unique.
◆ rtems_gpio_interrupt_handler_remove()
rtems_status_code rtems_gpio_interrupt_handler_remove ( uint32_t  pin_number,
void *  arg
Parameters
[in]handlerPointer to the user-defined handler
Return values
RTEMS_SUCCESSFULHandler successfully disconnected from this pin.
See also
◆ rtems_gpio_multi_clear()
rtems_status_code rtems_gpio_multi_clear ( uint32_t *  pin_numbers,
uint32_t  pin_count
Parameters
[in]pin_numbersArray with the GPIO pin numbers to clear.
[in]countNumber of GPIO pins to clear.
Return values
RTEMS_SUCCESSFULAll pins were cleared successfully.
RTEMS_INVALID_IDAt least one pin number is invalid.
RTEMS_NOT_CONFIGUREDAt least one of the received pins is not configured as a digital output.
RTEMS_UNSATISFIEDCould not clear the GPIO pins.
◆ rtems_gpio_multi_read()
uint32_t rtems_gpio_multi_read ( uint32_t *  pin_numbers,
uint32_t  pin_count
Parameters
[in]pin_numbersArray with the GPIO pin numbers to read.
[in]countNumber of GPIO pins to read.
Return values
Bitmaskwith the values of the corresponding pins. 0 for logical low and 1 for logical high.
GPIO_INPUT_ERRORCould not read at least one pin level.
◆ rtems_gpio_multi_set()
rtems_status_code rtems_gpio_multi_set ( uint32_t *  pin_numbers,
uint32_t  pin_count
Parameters
[in]pin_numbersArray with the GPIO pin numbers to set.
[in]countNumber of GPIO pins to set.
Return values
RTEMS_SUCCESSFULAll pins were set successfully.
RTEMS_UNSATISFIEDCould not set the GPIO pins.
◆ rtems_gpio_read_group()
uint32_t rtems_gpio_read_group ( rtems_gpio_group *  group)
Parameters
Return values
Thefunction returns a 32-bit bitmask with the group's input pins current logical values.
GPIO_INPUT_ERRORGroup has no input pins.
◆ rtems_gpio_release_configuration()
rtems_status_code rtems_gpio_release_configuration ( const rtems_gpio_pin_conf *  conf)
Parameters
[in]confGPIO pin configuration to be released.
Return values
RTEMS_SUCCESSFULPin successfully disabled.
RTEMS_UNSATISFIEDPin configuration is NULL.
See also
rtems_gpio_release_pin().
◆ rtems_gpio_release_pin()
rtems_status_code rtems_gpio_release_pin ( uint32_t  pin_number)
Parameters
Return values
*Could not disable an active interrupt on this pin,
See also
rtems_gpio_disable_interrupt().
◆ rtems_gpio_release_pin_group()
rtems_status_code rtems_gpio_release_pin_group ( rtems_gpio_group *  group)
Parameters
Return values
RTEMS_SUCCESSFULPins successfully disabled.
See also
rtems_gpio_release_pin(),
rtems_semaphore_delete() or
rtems_semaphore_flush().
◆ rtems_gpio_request_configuration()
rtems_status_code rtems_gpio_request_configuration ( const rtems_gpio_pin_conf *  conf)
Parameters
[in]confrtems_gpio_pin_conf structure filled with the pin information and desired configurations.
Return values
RTEMS_SUCCESSFULPin was configured successfully.
RTEMS_UNSATISFIEDCould not satisfy the given configuration.
◆ rtems_gpio_resistor_mode()
rtems_status_code rtems_gpio_resistor_mode ( uint32_t  pin_number,
Parameters
[in]modeThe pull resistor mode.
Return values
RTEMS_SUCCESSFULPull resistor successfully configured.
RTEMS_UNSATISFIEDCould not set the pull mode.
◆ rtems_gpio_set()
rtems_status_code rtems_gpio_set ( uint32_t  pin_number)
Parameters
Return values
RTEMS_SUCCESSFULPin was set successfully.
RTEMS_UNSATISFIEDCould not set the GPIO pin.
◆ rtems_gpio_update_configuration()
rtems_status_code rtems_gpio_update_configuration ( const rtems_gpio_pin_conf *  conf)
Parameters
Return values
RTEMS_SUCCESSFULPin configuration was updated successfully.
RTEMS_NOT_CONFIGUREDThe pin is not being used.
RTEMS_UNSATISFIEDCould not update the pin's configuration.
◆ rtems_gpio_write_group()
rtems_status_code rtems_gpio_write_group ( uint32_t  data,
Parameters
[in]dataData to write/send.
Return values
RTEMS_SUCCESSFULData successfully written.
RTEMS_NOT_DEFINEDGroup has no output pins.
