RTEMS  5.1
cpu.h
1
5 /*
6  *
7  * Copyright (c) 2015 University of York.
8  * Hesham ALMatary <hmka501@york.ac.uk>
9  *
10  * COPYRIGHT (c) 1989-1999.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * Redistribution and use in source and binary forms, with or without
14  * modification, are permitted provided that the following conditions
15  * are met:
16  * 1. Redistributions of source code must retain the above copyright
17  * notice, this list of conditions and the following disclaimer.
18  * 2. Redistributions in binary form must reproduce the above copyright
19  * notice, this list of conditions and the following disclaimer in the
20  * documentation and/or other materials provided with the distribution.
21  *
22  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
23  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
26  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
27  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
28  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
29  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
30  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
31  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
32  * SUCH DAMAGE.
33  */
34
35 #ifndef _EPIPHANY_CPU_H
36 #define _EPIPHANY_CPU_H
37
38 #ifdef __cplusplus
39 extern "C" {
40 #endif
41
42 #include <rtems/score/basedefs.h>
43 #include <rtems/score/epiphany.h> /* pick up machine definitions */
44 #ifndef ASM
45 #include <rtems/bspIo.h>
46 #include <stdint.h>
47 #include <stdio.h> /* for printk */
48 #endif
49
55 /* conditional compilation parameters */
56
57 /*
58  * Does the RTEMS invoke the user's ISR with the vector number and
59  * a pointer to the saved interrupt frame (1) or just the vector
60  * number (0)?
61  *
62  */
63
64 #define CPU_ISR_PASSES_FRAME_POINTER TRUE
65
66 #define CPU_HARDWARE_FP FALSE
67
68 #define CPU_SOFTWARE_FP FALSE
69
70 #define CPU_ALL_TASKS_ARE_FP FALSE
71
72 #define CPU_IDLE_TASK_IS_FP FALSE
73
74 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
75
76 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
77
78 /*
79  * Does the stack grow up (toward higher addresses) or down
80  * (toward lower addresses)?
81  *
82  * If TRUE, then the grows upward.
83  * If FALSE, then the grows toward smaller addresses.
84  *
85  */
86
87 #define CPU_STACK_GROWS_UP FALSE
88
89 /* FIXME: Is this the right value? */
90 #define CPU_CACHE_LINE_BYTES 64
91
92 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
93
94 /*
95  * The following defines the number of bits actually used in the
96  * interrupt field of the task mode. How those bits map to the
97  * CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
98  *
99  */
100
101 #define CPU_MODES_INTERRUPT_MASK 0x00000001
102
103 /*
104  * Processor defined structures required for cpukit/score.
105  */
106
107 /*
108  * Contexts
109  *
110  * Generally there are 2 types of context to save.
111  * 1. Interrupt registers to save
112  * 2. Task level registers to save
113  *
114  * This means we have the following 3 context items:
115  * 1. task level context stuff:: Context_Control
116  * 2. floating point task stuff:: Context_Control_fp
117  * 3. special interrupt level context :: Context_Control_interrupt
118  *
119  * On some processors, it is cost-effective to save only the callee
120  * preserved registers during a task context switch. This means
121  * that the ISR code needs to save those registers which do not
122  * persist across function calls. It is not mandatory to make this
123  * distinctions between the caller/callee saves registers for the
124  * purpose of minimizing context saved during task switch and on interrupts.
125  * If the cost of saving extra registers is minimal, simplicity is the
126  * choice. Save the same context on interrupt entry as for tasks in
127  * this case.
128  *
129  * Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
130  * care should be used in designing the context area.
131  *
132  * On some CPUs with hardware floating point support, the Context_Control_fp
133  * structure will not be used or it simply consist of an array of a
134  * fixed number of bytes. This is done when the floating point context
135  * is dumped by a "FP save context" type instruction and the format
136  * is not really defined by the CPU. In this case, there is no need
137  * to figure out the exact format -- only the size. Of course, although
138  * this is enough information for RTEMS, it is probably not enough for
139  * a debugger such as gdb. But that is another problem.
140  *
141  *
142  */
143 #ifndef ASM
144
145 typedef struct {
146  uint32_t r[64];
147
148  uint32_t status;
149  uint32_t config;
150  uint32_t iret;
151
152 #ifdef RTEMS_SMP
153
190  volatile bool is_executing;
191 #endif
193
194 #define _CPU_Context_Get_SP( _context ) \
195  (_context)->r[13]
196
198
199 /*
200  * Amount of extra stack (above minimum stack size) required by
201  * MPCI receive server thread. Remember that in a multiprocessor
202  * system this thread must exist and be able to process all directives.
203  *
204  */
205
206 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
207
208 /*
209  * Should be large enough to run all RTEMS tests. This insures
210  * that a "reasonable" small application should not have any problems.
211  *
212  */
213
214 #define CPU_STACK_MINIMUM_SIZE 4096
215
216 /*
217  * CPU's worst alignment requirement for data types on a byte boundary. This
218  * alignment does not take into account the requirements for the stack.
219  *
220  */
221
222 #define CPU_ALIGNMENT 8
223
224 /*
225  * This is defined if the port has a special way to report the ISR nesting
226  * level. Most ports maintain the variable _ISR_Nest_level.
227  */
228 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
229
230 /*
231  * This number corresponds to the byte alignment requirement for the
232  * heap handler. This alignment requirement may be stricter than that
233  * for the data types alignment specified by CPU_ALIGNMENT. It is
234  * common for the heap to follow the same alignment requirement as
235  * CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap,
236  * then this should be set to CPU_ALIGNMENT.
237  *
238  * NOTE: This does not have to be a power of 2 although it should be
239  * a multiple of 2 greater than or equal to 2. The requirement
240  * to be a multiple of 2 is because the heap uses the least
241  * significant field of the front and back flags to indicate
242  * that a block is in use or free. So you do not want any odd
243  * length blocks really putting length data in that bit.
244  *
245  * On byte oriented architectures, CPU_HEAP_ALIGNMENT normally will
246  * have to be greater or equal to than CPU_ALIGNMENT to ensure that
247  * elements allocated from the heap meet all restrictions.
248  *
249  */
250
251 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
252
253 /*
254  * This number corresponds to the byte alignment requirement for the
255  * stack. This alignment requirement may be stricter than that for the
256  * data types alignment specified by CPU_ALIGNMENT. If the CPU_ALIGNMENT
257  * is strict enough for the stack, then this should be set to 0.
258  *
259  * NOTE: This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
260  *
261  */
262
263 #define CPU_STACK_ALIGNMENT 8
264
265 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
266
267 /* ISR handler macros */
268
269 /*
270  * Support routine to initialize the RTEMS vector table after it is allocated.
271  *
272  * NO_CPU Specific Information:
273  *
274  * XXX document implementation including references if appropriate
275  */
276
277 #define _CPU_Initialize_vectors()
278
279 /*
280  * Disable all interrupts for an RTEMS critical section. The previous
281  * level is returned in _level.
282  *
283  */
284
285 static inline uint32_t epiphany_interrupt_disable( void )
286 {
287  uint32_t sr;
288  __asm__ __volatile__ ("movfs %[sr], status \n" : [sr] "=r" (sr):);
289  __asm__ __volatile__("gid \n");
290  return sr;
291 }
292
293 static inline void epiphany_interrupt_enable(uint32_t level)
294 {
295  __asm__ __volatile__("gie \n");
296  __asm__ __volatile__ ("movts status, %[level] \n" :: [level] "r" (level):);
297 }
298
299 #define _CPU_ISR_Disable( _level ) \
300  _level = epiphany_interrupt_disable()
301
302 /*
303  * Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
304  * This indicates the end of an RTEMS critical section. The parameter
305  * _level is not modified.
306  *
307  */
308
309 #define _CPU_ISR_Enable( _level ) \
310  epiphany_interrupt_enable( _level )
311
312 /*
313  * This temporarily restores the interrupt to _level before immediately
314  * disabling them again. This is used to divide long RTEMS critical
315  * sections into two or more parts. The parameter _level is not
316  * modified.
317  *
318  */
319
320 #define _CPU_ISR_Flash( _level ) \
321  do{ \
322  if ( (_level & 0x2) != 0 ) \
323  _CPU_ISR_Enable( _level ); \
324  epiphany_interrupt_disable(); \
325  } while(0)
326
327 RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
328 {
329  return ( level & 0x2 ) != 0;
330 }
331
332 /*
333  * Map interrupt level in task mode onto the hardware that the CPU
334  * actually provides. Currently, interrupt levels which do not
335  * map onto the CPU in a generic fashion are undefined. Someday,
336  * it would be nice if these were "mapped" by the application
337  * via a callout. For example, m68k has 8 levels 0 - 7, levels
338  * 8 - 255 would be available for bsp/application specific meaning.
339  * This could be used to manage a programmable interrupt controller
340  * via the rtems_task_mode directive.
341  *
342  * The get routine usually must be implemented as a subroutine.
343  *
344  */
345
346 void _CPU_ISR_Set_level( uint32_t level );
347
348 uint32_t _CPU_ISR_Get_level( void );
349
350 /* end of ISR handler macros */
351
352 /* Context handler macros */
353
354 /*
355  * Initialize the context to a state suitable for starting a
356  * task after a context restore operation. Generally, this
357  * involves:
358  *
359  * - setting a starting address
360  * - preparing the stack
361  * - preparing the stack and frame pointers
362  * - setting the proper interrupt level in the context
363  * - initializing the floating point context
364  *
365  * This routine generally does not set any unnecessary register
366  * in the context. The state of the "general data" registers is
367  * undefined at task start time.
368  *
369  * NOTE: This is_fp parameter is TRUE if the thread is to be a floating
370  * point thread. This is typically only used on CPUs where the
371  * FPU may be easily disabled by software such as on the SPARC
372  * where the PSR contains an enable FPU bit.
373  *
374  */
375
383 #define EPIPHANY_GCC_RED_ZONE_SIZE 128
384
404  void *stack_area_begin,
405  size_t stack_area_size,
406  uint32_t new_level,
407  void (*entry_point)( void ),
408  bool is_fp,
409  void *tls_area
410 );
411
412 /*
413  * This routine is responsible for somehow restarting the currently
414  * executing task. If you are lucky, then all that is necessary
415  * is restoring the context. Otherwise, there will need to be
416  * a special assembly routine which does something special in this
417  * case. Context_Restore should work most of the time. It will
418  * not work if restarting self conflicts with the stack frame
419  * assumptions of restoring a context.
420  *
421  */
422
423 #define _CPU_Context_Restart_self( _the_context ) \
424  _CPU_Context_restore( (_the_context) )
425
426 /* end of Context handler macros */
427
428 /* Fatal Error manager macros */
429
430 /*
431  * This routine copies _error into a known place -- typically a stack
432  * location or a register, optionally disables interrupts, and
433  * halts/stops the CPU.
434  *
435  */
436
437 #include <inttypes.h>
438
439 #define _CPU_Fatal_halt(_source, _error ) \
440  printk("Fatal Error %d.%" PRIu32 " Halted\n",_source, _error); \
441  asm("trap 3" :: "r" (_error)); \
442  for(;;)
443
444 /* end of Fatal Error manager macros */
445
446 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
447
448 #endif /* ASM */
449
457 #define CPU_SIZEOF_POINTER 4
458 #define CPU_EXCEPTION_FRAME_SIZE 260
459
460 #define CPU_MAXIMUM_PROCESSORS 32
461
462 #ifndef ASM
463
464 typedef struct {
465  uint32_t r[62];
466  uint32_t status;
467  uint32_t config;
468  uint32_t iret;
470
477
478
479 /* end of Priority handler macros */
480
481 /* functions */
482
483 /*
484  * _CPU_Initialize
485  *
486  * This routine performs CPU dependent initialization.
487  *
488  */
489
490 void _CPU_Initialize(
491  void
492 );
493
494 void *_CPU_Thread_Idle_body( uintptr_t ignored );
495
496 /*
497  * _CPU_Context_switch
498  *
499  * This routine switches from the run context to the heir context.
500  *
501  * epiphany Specific Information:
502  *
503  * Please see the comments in the .c file for a description of how
504  * this function works. There are several things to be aware of.
505  */
506
508  Context_Control *run,
509  Context_Control *heir
510 );
511
512 /*
513  * _CPU_Context_restore
514  *
515  * This routine is generally used only to restart self in an
516  * efficient manner. It may simply be a label in _CPU_Context_switch.
517  *
518  * NOTE: May be unnecessary to reload some registers.
519  *
520  */
521
523  Context_Control *new_context
525
526 /*
527  * _CPU_Context_save_fp
528  *
529  * This routine saves the floating point context passed to it.
530  *
531  */
532
534  void **fp_context_ptr
535 );
536
537 /*
538  * _CPU_Context_restore_fp
539  *
540  * This routine restores the floating point context passed to it.
541  *
542  */
543
545  void **fp_context_ptr
546 );
547
548 /* The following routine swaps the endian format of an unsigned int.
549  * It must be static because it is referenced indirectly.
550  *
551  * This version will work on any processor, but if there is a better
552  * way for your CPU PLEASE use it. The most common way to do this is to:
553  *
554  * swap least significant two bytes with 16-bit rotate
555  * swap upper and lower 16-bits
556  * swap most significant two bytes with 16-bit rotate
557  *
558  * Some CPUs have special instructions which swap a 32-bit quantity in
559  * a single instruction (e.g. i486). It is probably best to avoid
560  * an "endian swapping control bit" in the CPU. One good reason is
561  * that interrupts would probably have to be disabled to insure that
562  * an interrupt does not try to access the same "chunk" with the wrong
563  * endian. Another good reason is that on some CPUs, the endian bit
564  * endianness for ALL fetches -- both code and data -- so the code
565  * will be fetched incorrectly.
566  *
567  */
568
569 static inline unsigned int CPU_swap_u32(
570  unsigned int value
571 )
572 {
573  uint32_t byte1, byte2, byte3, byte4, swapped;
574
575  byte4 = (value >> 24) & 0xff;
576  byte3 = (value >> 16) & 0xff;
577  byte2 = (value >> 8) & 0xff;
578  byte1 = value & 0xff;
579
580  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
581  return( swapped );
582 }
583
584 #define CPU_swap_u16( value ) \
585  (((value&0xff) << 8) | ((value >> 8)&0xff))
586
587 typedef uint32_t CPU_Counter_ticks;
588
589 uint32_t _CPU_Counter_frequency( void );
590
591 CPU_Counter_ticks _CPU_Counter_read( void );
592
593 static inline CPU_Counter_ticks _CPU_Counter_difference(
594  CPU_Counter_ticks second,
595  CPU_Counter_ticks first
596 )
597 {
598  return second - first;
599 }
600
602 typedef uintptr_t CPU_Uint32ptr;
603
604 #endif /* ASM */
605
606 #ifdef __cplusplus
607 }
608 #endif
609
610 #endif
611
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:57
Definition: deflate.c:115
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Provide printf() PRIxxx Constante Beyond Standards.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
Interface to Kernel Print Methods.
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
unsigned context
Definition: tlb.h:108
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
