RTEMS  5.1
cpu.c File Reference
v850 CPU Initialize More...
#include <rtems/score/isr.h>
void _CPU_Initialize (void)
 CPU initialization. More...
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread. More...
void _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
v850 CPU Initialize
◆ _CPU_Context_Initialize()
void _CPU_Context_Initialize ( Context_Control *  the_context,
uint32_t *  stack_base,
uint32_t  size,
uint32_t  new_level,
void *  entry_point,
bool  is_fp,
void *  tls_area
Initialize the context to a state suitable for starting a task after a context restore operation. Generally, this involves:
  • setting a starting address
  • preparing the stack
  • preparing the stack and frame pointers
  • setting the proper interrupt level in the context
  • initializing the floating point context
Parameters
[in]the_contextpoints to the context area
[in]stack_baseis the low address of the allocated stack area
[in]sizeis the size of the stack area in bytes
[in]new_levelis the interrupt level for the task
[in]entry_pointis the task's entry point
[in]is_fpis set to TRUE if the task is a floating point task
[in]tls_areais the thread-local storage (TLS) area
NOTE: Implemented as a subroutine for the SPARC port.
