RTEMS  5.1
cpu.c File Reference
SPARC64 CPU Dependent Source. More...
#include <rtems/score/isr.h>
#include <rtems/score/tls.h>
#include <rtems/rtems/cache.h>
#define HI_BITS_SHIFT   10
#define HM_BITS_SHIFT   32
#define HH_BITS_SHIFT   42
#define IMM_MASK   0x000003FF
#define HH_BITS_MASK   0xFFFFFC0000000000
#define HM_BITS_MASK   0x000003FF00000000
#define HI_BITS_MASK   0x00000000FFFFFC00
#define LO_BITS_MASK   0x00000000000003FF
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
 SPARC specific raw ISR installer. More...
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
 SPARC specific RTEMS ISR installer. More...
volatile uint32_t _CPU_ISR_Dispatch_disable
const CPU_Trap_table_entry _CPU_Trap_slot_template
Variable Documentation
◆ _CPU_Trap_slot_template
Initial value:
0x89508000,
0x05000000,
0x8410a000,
0x8528b020,
0x07000000,
0x8610c002,
0x81c0e000,
0x84102000
This is the set of opcodes for the instructions loaded into a trap table entry. The routine which installs a handler is responsible for filling in the fields for the _handler address and the _vector trap type.
The constants following this structure are masks for the fields which must be filled in when the handler is installed.
