RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
score
cpu
sh
include
asm.h
1
17
18
* Authors: Ralf Corsepius (corsepiu@faw.uni-ulm.de) and
19
* Bernd Becker (becker@faw.uni-ulm.de)
20
21
* COPYRIGHT:
22
23
* This file is based on similar code found in newlib available
24
* from ftp.cygnus.com. The file which was used had no copyright
25
* notice. This file is freely distributable as long as the source
26
* of the file is noted. This file is:
27
28
29
* COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
30
31
* This program is distributed in the hope that it will be useful,
32
* but WITHOUT ANY WARRANTY; without even the implied warranty of
33
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
34
35
36
* COPYRIGHT (c) 1998-2001.
37
* On-Line Applications Research Corporation (OAR).
38
39
* The license and distribution terms for this file may be
40
* found in the file LICENSE in this distribution or at
41
* http://www.rtems.org/license/LICENSE.
42
43
44
#ifndef _RTEMS_ASM_H
45
#define _RTEMS_ASM_H
46
47
48
* Indicate we are in an assembly file and get the basic CPU definitions.
49
50
51
#ifndef ASM
52
#define ASM
53
#endif
54
55
56
rtems/score/sh.h
57
68
69
* Recent versions of GNU cpp define variables which indicate the
70
* need for underscores and percents. If not using GNU cpp or
71
* the version does not support this, then you will obviously
72
* have to define these as appropriate.
73
74
75
#ifndef __USER_LABEL_PREFIX__
76
#define __USER_LABEL_PREFIX__ _
77
#endif
78
79
#ifndef __REGISTER_PREFIX__
80
#define __REGISTER_PREFIX__
81
#endif
82
83
rtems/concat.h
84
85
/* Use the right prefix for global labels. */
86
87
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
88
89
/* Use the right prefix for registers. */
90
91
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
92
93
94
* define macros for all of the registers on this CPU
95
96
* EXAMPLE: #define d0 REG (d0)
97
98
#define r0 REG (r0)
99
#define r1 REG (r1)
100
#define r2 REG (r2)
101
#define r3 REG (r3)
102
#define r4 REG (r4)
103
#define r5 REG (r5)
104
#define r6 REG (r6)
105
#define r7 REG (r7)
106
#define r8 REG (r8)
107
#define r9 REG (r9)
108
#define r10 REG (r10)
109
#define r11 REG (r11)
110
#define r12 REG (r12)
111
#define r13 REG (r13)
112
#define r14 REG (r14)
113
#define r15 REG (r15)
114
#define vbr REG (vbr)
115
#define gbr REG (gbr)
116
#define pr REG (pr)
117
#define mach REG (mach)
118
#define macl REG (macl)
119
#define sr REG (sr)
120
#define pc REG (pc)
121
122
123
* Define macros to handle section beginning and ends.
124
125
126
127
#define BEGIN_CODE_DCL .text
128
#define END_CODE_DCL
129
#define BEGIN_DATA_DCL .data
130
#define END_DATA_DCL
131
#define BEGIN_CODE .text
132
#define END_CODE
133
#define BEGIN_DATA
134
#define END_DATA
135
#define BEGIN_BSS
136
#define END_BSS
137
#define END
138
139
140
* Following must be tailor for a particular flavor of the C compiler.
141
* They may need to put underscores in front of the symbols.
142
143
144
#define PUBLIC(sym) .global SYM (sym)
145
#define EXTERN(sym) .global SYM (sym)
146
147
#endif
sh.h
Hitachi SH CPU Department Source.
concat.h
