RTEMS  5.1
Data Structures | Typedefs | Functions
io.h File Reference
Classic Input/Output Manager API. More...
struct  rtems_driver_address_table
struct  rtems_driver_name_t
typedef uint32_t rtems_device_major_number
typedef uint32_t rtems_device_minor_number
typedef rtems_status_code rtems_device_driver
typedef rtems_device_driver(* rtems_device_driver_entry) (rtems_device_major_number, rtems_device_minor_number, void *)
rtems_status_code rtems_io_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 IO driver initialization. More...
rtems_status_code rtems_io_open (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Opening for the IO manager. More...
rtems_status_code rtems_io_close (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Closing for the IO manager. More...
rtems_status_code rtems_io_read (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Reading for the IO manager. More...
rtems_status_code rtems_io_write (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Writing for the IO manager. More...
rtems_status_code rtems_io_control (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Control for the IO manager. More...
rtems_status_code rtems_io_lookup_name (const char *name, rtems_driver_name_t *device_info) RTEMS_DEPRECATED
Device Driver Maintainance
rtems_status_code rtems_io_driver_io_error (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Returns RTEMS_IO_ERROR. More...
rtems_status_code rtems_io_register_driver (rtems_device_major_number major, const rtems_driver_address_table *driver_table, rtems_device_major_number *registered_major)
 Registers and initializes the device with the device driver table driver_table and major number major. More...
rtems_status_code rtems_io_unregister_driver (rtems_device_major_number major)
 Unregister a driver from the device driver table. More...
rtems_status_code rtems_io_register_name (const char *device_name, rtems_device_major_number major, rtems_device_minor_number minor)
 Registers the name device_name in the file system for the device with number tuple major and minor. More...
This file emulates the old Classic RTEMS IO manager directives which register and lookup names using the in-memory filesystem.
◆ rtems_io_lookup_name()
rtems_status_code rtems_io_lookup_name ( const char *  name,
rtems_driver_name_t *  device_info
Deprecated:
Use stat() instead.
