RTEMS  5.1
sc16is752.h
1 /*
2  * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
3  *
4  * embedded brains GmbH
5  * Dornierstr. 4
6  * 82178 Puchheim
7  * Germany
8  * <info@embedded-brains.de>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef _DEV_SERIAL_SC16IS752_H
16 #define _DEV_SERIAL_SC16IS752_H
17
18 #include <sys/ioccom.h>
19
20 #include <rtems/termiostypes.h>
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif /* __cplusplus */
25
32 typedef enum {
33  SC16IS752_MODE_RS232,
34
35  /* Enable RS485 mode */
36  SC16IS752_MODE_RS485,
37
38  /* Enable RS485 mode, enable the transmitter to control the #RTS pin */
39  SC16IS752_MODE_RS485_RTS,
40
41  /*
42  * Enable RS485 mode, enable the transmitter to control the #RTS pin, invert
43  * RTS signal (#RTS = 1 during transmission and #RTS = 0 during reception)
44  */
45  SC16IS752_MODE_RS485_RTS_INV
46 } sc16is752_mode;
47
49
55
61  int (*write_reg)(
62  sc16is752_context *ctx,
63  uint8_t addr,
64  const uint8_t *data,
65  size_t len
66  );
67
73  int (*read_reg)(
74  sc16is752_context *ctx,
75  uint8_t addr,
76  uint8_t *data,
77  size_t len
78  );
79
85  int (*read_2_reg)(
86  sc16is752_context *ctx,
87  uint8_t addr_0,
88  uint8_t addr_1,
89  uint8_t data[2]
90  );
91
98
105
112
119
125  sc16is752_mode mode;
126
133  uint32_t input_frequency;
134
141
147  uint8_t ier;
148
154  uint8_t tx_in_progress;
155
161  uint8_t tx_fifo_free;
162
168  uint8_t lcr;
169
175  uint8_t efcr;
176 };
177
181 typedef struct {
182  sc16is752_context base;
183
189  int fd;
190
196  uint8_t cs;
197
203  uint32_t speed_hz;
204
210  const char *spi_path;
212
216 typedef struct {
217  sc16is752_context base;
218
224  int fd;
225
231  const char *bus_path;
233
234 const rtems_termios_device_handler sc16is752_termios_handler;
235
241 void sc16is752_interrupt_handler(void *arg);
242
252 rtems_status_code sc16is752_spi_create(
254  const char *device_path
255 );
256
262 #define SC16IS752_SET_SLEEP_MODE _IOW('d', 0, int)
263
270 #define SC16IS752_SET_IOCONTROL _IOW('d', 1, uint8_t)
271
275 #define SC16IS752_SET_IODIR _IOW('d', 2, uint8_t)
276
280 #define SC16IS752_SET_IOSTATE _IOW('d', 3, uint8_t)
281
285 #define SC16IS752_SET_EFCR _IOW('d', 4, uint8_t)
286
290 #define SC16IS752_GET_SLEEP_MODE _IOR('d', 0, int)
291
295 #define SC16IS752_GET_IOCONTROL _IOR('d', 1, uint8_t)
296
300 #define SC16IS752_GET_IODIR _IOR('d', 2, uint8_t)
301
305 #define SC16IS752_GET_IOSTATE _IOR('d', 3, uint8_t)
306
310 #define SC16IS752_GET_EFCR _IOR('d', 4, uint8_t)
311
316 #define SC16IS752_IOCONTROL_SRESET (1u << 3)
317 #define SC16IS752_IOCONTROL_GPIO_3_0_OR_MODEM (1u << 2)
318 #define SC16IS752_IOCONTROL_GPIO_7_4_OR_MODEM (1u << 1)
319 #define SC16IS752_IOCONTROL_IOLATCH (1u << 0)
320
324 #ifdef __cplusplus
325 }
326 #endif /* __cplusplus */
327
328 #endif /* _DEV_SERIAL_SC16IS752_H */
bool(* first_open)(sc16is752_context *ctx)
First open.
Definition: sc16is752.h:97
uint8_t efcr
Shadow Extra Features Control Register (EFCR).
Definition: sc16is752.h:175
SC16IS752 I2C context.
Definition: sc16is752.h:216
int fd
The I2C bus device file descriptor.
Definition: sc16is752.h:224
int(* read_reg)(sc16is752_context *ctx, uint8_t addr, uint8_t *data, size_t len)
Reads a register.
Definition: sc16is752.h:73
Termios device context.
Definition: termiostypes.h:75
sc16is752_mode mode
Device mode.
Definition: sc16is752.h:125
Characters placed into transmit FIFO.
Definition: sc16is752.h:154
const char * spi_path
The SPI bus device path.
Definition: sc16is752.h:210
rtems_termios_tty * tty
Corresponding Termios structure.
Definition: sc16is752.h:140
int(* write_reg)(sc16is752_context *ctx, uint8_t addr, const uint8_t *data, size_t len)
Writes a register.
Definition: sc16is752.h:61
rtems_status_code
Classic API Status.
Definition: status.h:43
SC16IS752 SPI context.
Definition: sc16is752.h:181
bool(* install_irq)(sc16is752_context *ctx)
Shall install the interrupt handler.
Definition: sc16is752.h:111
Definition: termiostypes.h:283
void(* remove_irq)(sc16is752_context *ctx)
Shall remove the interrupt handler.
Definition: sc16is752.h:118
Input frequency in Hertz (dependent on crystal, see XTAL1 and XTAL2 pins).
Definition: sc16is752.h:133
uint8_t ier
Shadow Interrupt Enable Register (IER).
Definition: sc16is752.h:147
const char * bus_path
The I2C bus device path.
Definition: sc16is752.h:231
int(* read_2_reg)(sc16is752_context *ctx, uint8_t addr_0, uint8_t addr_1, uint8_t data[2])
Reads two registers.
Definition: sc16is752.h:85
SC16IS752 device context.
Definition: sc16is752.h:53
Count of free characters in the transmit FIFO.
Definition: sc16is752.h:161
int fd
The SPI bus device file descriptor.
Definition: sc16is752.h:189
void(* last_close)(sc16is752_context *ctx)
Last close.
Definition: sc16is752.h:104
uint32_t speed_hz
The SPI bus speed in Hertz.
Definition: sc16is752.h:203
uint8_t lcr
Shadow Line Control Register (LCR).
Definition: sc16is752.h:168
Termios device handler.
Definition: termiostypes.h:141
uint8_t cs
The SPI device chip select.
Definition: sc16is752.h:196
