20 #ifndef LPC176X_TIMER_DEFS_H    21 #define LPC176X_TIMER_DEFS_H    27 #define CAN_ACCEPT_BASE_ADDR 0x4003C000    29 #define CAN_DRIVER_IS_MINOR_VALID( minor ) ( minor < CAN_DEVICES_NUMBER )    30 #define CAN_DEFAULT_BAUD_RATE 1000000u    31 #define CAN_DEFAULT_INTERRUPT_CONFIGURATION 0    33 #define MAX_NUMBER_OF_CAN_BITS 25u    34 #define MIN_NUMBER_OF_CAN_BITS 4u    35 #define CAN_BRP_EXTRA_BIT 1u    36 #define CAN_TSEG_EXTRA_BITS 3u    37 #define MAX_TSEG1_TSEG2_BITS 22u    39 #define CAN_GSR_RBS_MASK 1u    40 #define CAN_CMR_RRB_MASK 4u    42 #define CAN_MAXIMUM_DATA_SIZE 8u    43 #define CAN10_MAXIMUM_ID 0x7FFu    54 #define CAN_BTR_TSEG1_SHIFT 16u    55 #define CAN_BTR_TSEG2_SHIFT 20u    56 #define CAN_BTR_SJW_SHIFT 14u    57 #define CAN_BTR_BRP_SHIFT 0u    59 #define CAN_BTR_TSEG1_MASK 0x000F0000U    60 #define CAN_BTR_TSEG2_MASK 0x00700000U    61 #define CAN_BTR_SJW_MASK 0x0000C000U    62 #define CAN_BTR_BRP_MASK 0x000003FFU    64 #define WRONG_BTR_VALUE 0xFFFFFFFF    73   CAN_NUMBER_OF_TRANSMIT_BUFFERS
    81   uint32_t can_status_mask;
    82   uint32_t not_cc_cmr_value;
    87   volatile uint32_t MOD;
    88   volatile uint32_t CMR;
    89   volatile uint32_t GSR;
    90   volatile uint32_t ICR;
    91   volatile uint32_t
IER;
    92   volatile uint32_t BTR;
    93   volatile uint32_t EWL;
   114   const uint32_t pconp_pin;
   115   const uint32_t pins[ NUMBER_OF_CAN_PINS ];
   121   volatile uint32_t TX_SR;
   122   volatile uint32_t RX_SR;
   123   volatile uint32_t
MSR;
   128   volatile uint32_t AFMR;
   129   volatile uint32_t SFF_SA;
   130   volatile uint32_t SFF_GRP_SA;
   131   volatile uint32_t EFF_SA;
   132   volatile uint32_t EFF_GRP_SA;
   133   volatile uint32_t EOT;
   134   volatile uint32_t LUT_ERR_ADR;
   135   volatile uint32_t LUT_ERR;
   136   volatile uint32_t FCANIE;
   137   volatile uint32_t FCANIC0;
   138   volatile uint32_t FCANIC1;
   158 #define CAN_INTERRUPT_TYPE_MASK 0x1ffu   165 #define CAN_MOD_RM 0x00000001U   167 #define CAN_ACCF_AFMR_ACCOF 0x00000001U   168 #define CAN_ACCF_AFMR_ACCBP 0x00000002U   169 #define CAN_ACCF_AFMR_EFCAN 0x00000004U   171 #define CAN_IER_RIE 0x000000001U   172 #define CAN_IER_TIE1 0x000000002U   173 #define CAN_IER_EIE 0x000000004U   174 #define CAN_IER_DOIE 0x000000008U   175 #define CAN_IER_WUIE 0x000000010U   176 #define CAN_IER_EPIEX 0x000000020U   177 #define CAN_IER_ALIEX 0x000000040U   178 #define CAN_IER_BEIEX 0x000000080U   179 #define CAN_IER_IDIEX 0x000000100U   180 #define CAN_IER_TIE2 0x000000200U   181 #define CAN_IER_TIE3 0x000000400U Represents the CAN controller registers.
Definition: can-defs.h:86
The CAN status and control masks to send a message for each transmit buffer.
Definition: can-defs.h:80
A driver entry for each low level device.
Definition: can-defs.h:111
can_pin_number
A TX or RX pin for each CAN device .
Definition: can-defs.h:102
Definition: rtemscompat1.h:15
#define MSR
Modem Status Register.
Definition: uart.h:93
Represents the CAN centralized registers.
Definition: can-defs.h:120
can_tseg_number
The Time segments of a CAN bit.
Definition: can-defs.h:48
can_format
The possible CAN formats for a message.
Definition: can-defs.h:144
lpc176x_pin_function
Defines the functions according to the pin.
Definition: io-defs.h:68
Definitions types used by some devices in common.
void(* lpc176x_can_isr)(lpc176x_can_number number)
An isr for a CAN interrupt.
Definition: can.h:92
lpc176x_module
lpc176x module representation.
Definition: common-types.h:44
can_type
The types of message.
Definition: can-defs.h:153
can_transmit_number
The transmit buffers of the CAN device.
Definition: can-defs.h:69
#define IER
Interrupt Enable Register.
Definition: uart.h:85
A CAN message represented for the registers of the device.
Definition: can.h:43
CAN controller for the mbed lpc1768 board.
lpc176x_can_isr lpc176x_can_isr_vector[CAN_IRQ_NUMBER]
The vector with all the callbacks for the CAN isr.
Definition: can-defs.h:163
Represents the acceptance filter registers.
Definition: can-defs.h:127
