19 #ifndef LIBBSP_POWERPC_MVME5500_BSP_H    20 #define LIBBSP_POWERPC_MVME5500_BSP_H    38 #include <libcpu/io.h>    48 BSP_BoardTypes BSP_getBoardType(
void);
    57 BSP_VMEchipTypes BSP_getVMEchipType(
void);
    66 } DiscoveryChipVersion;
    68 DiscoveryChipVersion BSP_getDiscoveryChipVersion(
void);
    70 #define _256M           0x10000000    71 #define _512M           0x20000000    73 #define GT64x60_REG_BASE        0xf1000000      74 #define GT64x60_REG_SPACE_SIZE  0x10000         76 #define GT64x60_DEV1_BASE       0xf1100000      78 #define GT64260_DEV1_SIZE       0x00100000     81 #define _IO_BASE GT64x60_REG_BASE    83 #define BSP_NVRAM_BASE_ADDR     0xf1110000    85 #define BSP_RTC_INTA_REG        0x7ff0    86 #define BSP_RTC_SECOND          0x7ff2    87 #define BSP_RTC_MINUTE          0x7ff3    88 #define BSP_RTC_HOUR            0x7ff4    89 #define BSP_RTC_DATE            0x7ff5    90 #define BSP_RTC_INTERRUPTS      0x7ff6    91 #define BSP_RTC_WATCHDOG        0x7ff7    94 #define PCI0_IO_BASE            0xf0000000    95 #define PCI1_IO_BASE            0xf0800000    98 #define PCI0_MEM_BASE                  0x80000000    99 #define PCI_MEM_BASE                   0     100 #define PCI_MEM_BASE_ADJUSTMENT        0   103 #define  PCI_DRAM_OFFSET          0   106 #define PCI1_MEM_BASE           0xe0000000   107 #define PCI1_MEM_SIZE           0x10000000   114 #define BSP_MAX_PCI_BUS_ON_PCI0 8   115 #define BSP_MAX_PCI_BUS_ON_PCI1 2   116 #define BSP_MAX_PCI_BUS  (BSP_MAX_PCI_BUS_ON_PCI0+BSP_MAX_PCI_BUS_ON_PCI1)   122 #define BSP_PCI_IRQ0 BSP_GPP_IRQ_LOWEST_OFFSET   128 #define BSP_INTERRUPT_STACK_SIZE  (16 * 1024)    131 #define BSP_UART_IOBASE_COM1  GT64x60_DEV1_BASE + 0x20000   132 #define BSP_UART_IOBASE_COM2  GT64x60_DEV1_BASE + 0x21000   134 #define BSP_CONSOLE_PORT    BSP_UART_COM1     135 #define BSP_UART_BAUD_BASE    115200   140 extern unsigned int BSP_mem_size;
   144 extern unsigned int BSP_bus_frequency;
   148 extern unsigned int BSP_processor_frequency;
   152 extern unsigned int BSP_time_base_divisor;
   154 #define BSP_Convert_decrementer( _value ) \   155   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))   157 extern void bsp_reset(
void);
   159 extern int BSP_disconnect_clock_handler(
void);
   162 unsigned long _BSP_clear_hostbridge_errors(
int enableMCP,
int quiet);
   167 char *save_boot_params(
   179 uint32_t probeMemoryEnd(
void);
   180 void     pci_interface(
void);
   181 void     BSP_printPicIsrTbl(
void);
   183   unsigned char  I2cBusAddr,
   186   unsigned char *pBuff,
   191 #define RTEMS_BSP_NETWORK_DRIVER_NAME  "gt1"   192 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH  rtems_GT64260eth_driver_attach   194 #define RTEMS_BSP_NETWORK_DRIVER_NAME  "wmG1"   195 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH  rtems_i82544EI_driver_attach   198 struct rtems_bsdnet_ifconfig;
   202 #define gccMemBar() RTEMS_COMPILER_MEMORY_BARRIER()   204 static inline void lwmemBar(
void)
   206     __asm__ volatile(
"lwsync":::
"memory");
   209 static inline void io_flush(
void)
   211     __asm__ volatile(
"isync":::
"memory");
   214 static inline void memBar(
void)
   216     __asm__ volatile(
"sync":::
"memory");
   219 static inline void ioBar(
void)
   221     __asm__ volatile(
"eieio":::
"memory");
 DEFAULT_INITIAL_EXTENSION Support.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Standard network driver attach and detach function.
Definition: bsp.h:77
int BSP_connect_clock_handler(void)
Clock Tick Device Driver.
Definition: p_clock.c:37
