15 #ifndef LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H    16 #define LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H    32 #include <libcpu/io.h>    93 #define _IO_BASE        CHRP_ISA_IO_BASE    94 #define _ISA_MEM_BASE       CHRP_ISA_MEM_BASE    96 #define PCI_DRAM_OFFSET     CHRP_PCI_DRAM_OFFSET    98 #define PCI_MEM_BASE        0   100 #define PCI_MEM_WIN0        0x80000000   103 #define _IO_BASE        PREP_ISA_IO_BASE   104 #define _ISA_MEM_BASE       PREP_ISA_MEM_BASE   107 #define PCI_DRAM_OFFSET     PREP_PCI_DRAM_OFFSET   109 #define PCI_MEM_BASE        PREP_ISA_MEM_BASE   110 #define PCI_MEM_WIN0        0   112 #define PCI_DRAM_OFFSET     0   113 #define PCI_MEM_BASE        0   114 #define PCI_MEM_WIN0        PREP_ISA_MEM_BASE   127 #if defined(mvme2100)   128 #define BSP_UART_IOBASE_COM1 ((_IO_BASE)+0x01e10000)   130 #define BSP_OPEN_PIC_BASE_OFFSET 0x40000   132 #define MVME_HAS_DEC21140   134 #define BSP_UART_IOBASE_COM1 ((_IO_BASE)+0x3f8)   135 #define BSP_UART_IOBASE_COM2 ((_IO_BASE)+0x2f8)   138 #define BSP_KBD_IOBASE       ((_IO_BASE)+0x60)   139 #define BSP_VGA_IOBASE       ((_IO_BASE)+0x3c0)   142 #if defined(mvme2300)   143 #define MVME_HAS_DEC21140   147 #define BSP_CONSOLE_PORT    BSP_UART_COM1   148 #define BSP_UART_BAUD_BASE  115200   150 struct rtems_bsdnet_ifconfig;
   152 #if defined(MVME_HAS_DEC21140)   153 #define RTEMS_BSP_NETWORK_DRIVER_NAME "dc1"   154 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_dec21140_driver_attach   155 extern int rtems_dec21140_driver_attach(
struct rtems_bsdnet_ifconfig *,
int);
   159 #define RTEMS_BSP_NETWORK_DRIVER_NAME "ne1"   160 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_ne_driver_attach   161 extern int rtems_ne_driver_attach(
int);
   170 #define BSP_IDLE_TASK_BODY bsp_ppc_idle_task_body   171 extern void *bsp_ppc_idle_task_body(uintptr_t arg);
   174 #include <bsp/openpic.h>   189 #define BSP_PIC_DO_EOI openpic_eoi(0)   192 #define outport_byte(port,value) outb(value,port)   193 #define outport_word(port,value) outw(value,port)   194 #define outport_long(port,value) outl(value,port)   196 #define inport_byte(port,value) (value = inb(port))   197 #define inport_word(port,value) (value = inw(port))   198 #define inport_long(port,value) (value = inl(port))   207 extern unsigned int BSP_mem_size;
   211 extern unsigned int BSP_heap_start;
   215 extern unsigned int BSP_bus_frequency;
   219 extern unsigned int BSP_processor_frequency;
   223 extern unsigned int BSP_time_base_divisor;
   228 extern char *BSP_commandline_string;
   230 #define BSP_Convert_decrementer( _value ) \   231   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))   234 extern int BSP_disconnect_clock_handler (
void);
   247 extern unsigned long _BSP_clear_hostbridge_errors(
int enableMCP,
int quiet);
   252 char *save_boot_params(
   264 void VIA_isa_bridge_interrupts_setup(
void);
 DEFAULT_INITIAL_EXTENSION Support.
BSP Command Line Handler.
const char * rtems_bsp_cmdline_get_param_raw(const char *name)
Obtain Pointer to the Entire Matching Argument.
Definition: bspcmdline_getparamraw.c:28
int BSP_connect_clock_handler(void)
Clock Tick Device Driver.
Definition: p_clock.c:37
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
