25 #ifndef LIBBSP_BEATNIK_BSP_H    26 #define LIBBSP_BEATNIK_BSP_H    44 #include <libcpu/io.h>    58 BSP_BoardType BSP_getBoardType(
void);
    75 DiscoveryVersion BSP_getDiscoveryVersion(
int assertion);
    81 #define BSP_INTERRUPT_STACK_SIZE          (16 * 1024)    86 #define BSP_MV64x60_BASE        (0xf1000000)    87 #define BSP_MV64x60_DEV1_BASE   (0xf1100000)    88 #define BSP_UART_IOBASE_COM1    ((BSP_MV64x60_DEV1_BASE)+0x20000)    89 #define BSP_UART_IOBASE_COM2    ((BSP_MV64x60_DEV1_BASE)+0x21000)    90 #define BSP_UART_USE_SHARED_IRQS    92 #define BSP_NVRAM_BASE_ADDR      (0xf1110000)    93 #define BSP_NVRAM_END_ADDR       (0xf1117fff)    94 #define BSP_NVRAM_RTC_START      (0xf1117ff8)    96 #define BSP_NVRAM_BOOTPARMS_START  (0xf1111000)    97 #define BSP_NVRAM_BOOTPARMS_END    (0xf1111fff)   106 #define PCI_CONFIG_ADDR        (BSP_MV64x60_BASE + 0xcf8)   107 #define PCI_CONFIG_DATA        (BSP_MV64x60_BASE + 0xcfc)   113 #define _IO_BASE          0x00000000   117 #define PCI_MEM_BASE               0   118 #define PCI_MEM_BASE_ADJUSTMENT    0   119 #define PCI_DRAM_OFFSET            0   121 extern void BSP_motload_pci_fixup(
void);
   128 #define BSP_PCI2LOCAL_ADDR(a) ((uint32_t)(a))   129 #define BSP_LOCAL2PCI_ADDR(a) ((uint32_t)(a))   131 #define BSP_CONFIG_NUM_PCI_CACHE_SLOTS  32   133 #define BSP_CONSOLE_PORT      BSP_UART_COM1   134 #define BSP_UART_BAUD_BASE    115200   140 #define BSP_VPD_I2C_ADDR      (0xA8>>1)       141 #define BSP_USR_I2C_ADDR      (0xAA>>1)       142 #define BSP_THM_I2C_ADDR      (0x90>>1)       144 #define BSP_I2C_BUS_DESCRIPTOR    gt64260_i2c_bus_descriptor   146 #define BSP_I2C_BUS0_NAME             "/dev/i2c0"   148 #define BSP_I2C_VPD_EEPROM_NAME       "vpd-eeprom"   149 #define BSP_I2C_USR_EEPROM_NAME       "usr-eeprom"   150 #define BSP_I2C_DS1621_NAME           "ds1621"   151 #define BSP_I2C_THM_NAME              BSP_I2C_DS1621_NAME   152 #define BSP_I2C_DS1621_RAW_NAME       "ds1621-raw"   154 #define  BSP_I2C_VPD_EEPROM_DEV_NAME      (BSP_I2C_BUS0_NAME ", " BSP_I2C_VPD_EEPROM_NAME)   155 #define  BSP_I2C_USR_EEPROM_DEV_NAME      (BSP_I2C_BUS0_NAME ", " BSP_I2C_USR_EEPROM_NAME)   156 #define  BSP_I2C_DS1621_DEV_NAME          (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_NAME)   157 #define BSP_I2C_THM_DEV_NAME              BSP_I2C_DS1621_DEV_NAME   158 #define  BSP_I2C_DS1621_RAW_DEV_NAME      (BSP_I2C_BUS0_NAME ", " BSP_I2C_DS1621_RAW_NAME)   173 int BSP_i2c_initialize(
void);
   176 #if defined(RTEMS_NETWORKING)   177 #include <bsp/bsp_bsdnet_attach.h>   178 int rtems_em_attach(
struct rtems_bsdnet_ifconfig *,
int);
   179 int rtems_dec21140_driver_attach(
int);
   180 int rtems_dc_driver_attach(
int);
   184 #define BSP_PCI_HOSE0_MEM_BASE    0x80000000     185 #define BSP_PCI_HOSE0_MEM_SIZE    0x20000000   187 #define BSP_PCI_HOSE1_MEM_BASE    0xe0000000   189 #define BSP_DEV_AND_PCI_IO_BASE   0xf0000000   190 #define BSP_DEV_AND_PCI_IO_SIZE   0x10000000   195 #define BSP_RW_PAGE_ATTRIBUTES  TRIV121_ATTR_M   197 extern unsigned BSP_pci_hose1_bus_base;
   199 void BSP_pci_initialize(
void);
   206 #define BSP_EXCEPTION_NOTEPAD    14   210 #define outport_byte(port,value) outb(value,port)   211 #define outport_word(port,value) outw(value,port)   212 #define outport_long(port,value) outl(value,port)   214 #define inport_byte(port,value) (value = inb(port))   215 #define inport_word(port,value) (value = inw(port))   216 #define inport_long(port,value) (value = inl(port))   223 extern unsigned int BSP_mem_size;
   227 extern unsigned int BSP_heap_start;
   231 extern unsigned int BSP_bus_frequency;
   235 extern unsigned int BSP_processor_frequency;
   239 extern unsigned int BSP_time_base_divisor;
   241 extern char BSP_productIdent[20];
   242 extern char BSP_serialNumber[20];
   244 extern char BSP_enetAddr0[7];
   245 extern char BSP_enetAddr1[7];
   250 extern char *BSP_commandline_string;
   253 #define BSP_Convert_decrementer( _value ) \   254   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))   256 extern void bsp_reset(
void);
   257 extern int BSP_disconnect_clock_handler (
void);
   274 extern unsigned long _BSP_clear_hostbridge_errors(
int enableMCP,
int quiet);
   284 extern unsigned short (*_BSP_clear_vmebridge_errors)(int);
   289 void discovery_pic_set_debug_irq(
int on);
   290 void discovery_pic_install_debug_irq(
void);
   295 char *save_boot_params(
   307 uint32_t probeMemoryEnd(
void);
 DEFAULT_INITIAL_EXTENSION Support.
int BSP_connect_clock_handler(void)
Clock Tick Device Driver.
Definition: p_clock.c:37
