23 #ifndef LIBBSP_NIOS2_NIOS2_ISS_BSP_H    24 #define LIBBSP_NIOS2_NIOS2_ISS_BSP_H    50 #define SYSTEM_BUS_WIDTH 32    52 #define JTAG_UART_BASE 0x08000000    53 #define JTAG_UART_IRQ 2    55 #define CLOCK_BASE 0x08001000    56 #define CLOCK_FREQ 50000000    57 #define CLOCK_VECTOR 1    59 #define TIMER_BASE 0x08002000    60 #define TIMER_FREQ 50000000    61 #define TIMER_VECTOR 3    65 #define NIOS2_BYPASS_CACHE ((uint32_t)0x80000000ul)    66 #define NIOS2_IO_BASE(x) ( (void*) ((uint32_t)x | NIOS2_BYPASS_CACHE ) )    67 #define NIOS2_IENABLE(x) do{ __builtin_wrctl(3,__builtin_rdctl(3)|x);}while(0)    68 #define NIOS2_IRQ_ENABLE(x) do {__builtin_wrctl(3,__builtin_rdctl(3)|x);} while(0)    73 #ifndef SYSTEM_BUS_WIDTH    74 #error SYSTEM_BUS_WIDTH is undefined    77 #if SYSTEM_BUS_WIDTH != 32    78 #error Only SYSTEM_BUS_WIDTH 32 is supported    83   volatile uint32_t status;
    85   volatile uint32_t period_lo;
    86   volatile uint32_t period_hi;
    87   volatile uint32_t snap_lo;
    88   volatile uint32_t snap_hi;
    92 #define ALTERA_AVALON_TIMER_STATUS_TO_MSK             (0x1)    93 #define ALTERA_AVALON_TIMER_STATUS_TO_OFST            (0)    94 #define ALTERA_AVALON_TIMER_STATUS_RUN_MSK            (0x2)    95 #define ALTERA_AVALON_TIMER_STATUS_RUN_OFST           (1)    97 #define ALTERA_AVALON_TIMER_CONTROL_ITO_MSK           (0x1)    98 #define ALTERA_AVALON_TIMER_CONTROL_ITO_OFST          (0)    99 #define ALTERA_AVALON_TIMER_CONTROL_CONT_MSK          (0x2)   100 #define ALTERA_AVALON_TIMER_CONTROL_CONT_OFST         (1)   101 #define ALTERA_AVALON_TIMER_CONTROL_START_MSK         (0x4)   102 #define ALTERA_AVALON_TIMER_CONTROL_START_OFST        (2)   103 #define ALTERA_AVALON_TIMER_CONTROL_STOP_MSK          (0x8)   104 #define ALTERA_AVALON_TIMER_CONTROL_STOP_OFST         (3)   108   volatile uint32_t data;
   113 #define ALTERA_AVALON_JTAG_UART_DATA_DATA_MSK             (0x000000FFu)   114 #define ALTERA_AVALON_JTAG_UART_DATA_DATA_OFST            (0)   115 #define ALTERA_AVALON_JTAG_UART_DATA_RVALID_MSK           (0x00008000u)   116 #define ALTERA_AVALON_JTAG_UART_DATA_RVALID_OFST          (15)   117 #define ALTERA_AVALON_JTAG_UART_DATA_RAVAIL_MSK           (0xFFFF0000u)   118 #define ALTERA_AVALON_JTAG_UART_DATA_RAVAIL_OFST          (16)   120 #define ALTERA_AVALON_JTAG_UART_CONTROL_RE_MSK            (0x00000001u)   121 #define ALTERA_AVALON_JTAG_UART_CONTROL_RE_OFST           (0)   122 #define ALTERA_AVALON_JTAG_UART_CONTROL_WE_MSK            (0x00000002u)   123 #define ALTERA_AVALON_JTAG_UART_CONTROL_WE_OFST           (1)   124 #define ALTERA_AVALON_JTAG_UART_CONTROL_RI_MSK            (0x00000100u)   125 #define ALTERA_AVALON_JTAG_UART_CONTROL_RI_OFST           (8)   126 #define ALTERA_AVALON_JTAG_UART_CONTROL_WI_MSK            (0x00000200u)   127 #define ALTERA_AVALON_JTAG_UART_CONTROL_WI_OFST           (9)   128 #define ALTERA_AVALON_JTAG_UART_CONTROL_AC_MSK            (0x00000400u)   129 #define ALTERA_AVALON_JTAG_UART_CONTROL_AC_OFST           (10)   130 #define ALTERA_AVALON_JTAG_UART_CONTROL_WSPACE_MSK        (0xFFFF0000u)   131 #define ALTERA_AVALON_JTAG_UART_CONTROL_WSPACE_OFST       (16)   138   rtems_isr_entry     handler,
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: intercom.c:74
