18 #ifndef LIBBSP_MIPS_MALTA_BSP_H    19 #define LIBBSP_MIPS_MALTA_BSP_H    42 #define BSP_FEATURE_IRQ_EXTENSION    43 #define BSP_SHARED_HANDLER_SUPPORT      1    45 #define REVISION_REGISTER_ADDRESS  0x1fc00010    46 #define PRORV_MASK       0x0000000f       47 #define PROID_MASK       0x000000f0       48 #define CORRV_MASK       0x00000300       49 #define CORID_MASK       0x0000fc00       50 #define FPGRV_MASK       0x00ff0000       51 #define BSP_8259_BASE_ADDRESS    (0x18000000UL | 0xa0000000UL)    52 #define BSP_PCI_BASE_ADDRESS     (0x1be00000UL | 0xa0000000UL)    53 #define BSP_NIC_IO_BASE          (0x10000000UL | 0xa0000000UL)    54 #define PCI0_IO_BASE             (0x18000000UL | 0xa0000000UL)    55 #define BSP_NIC_MEM_BASE         (0x00000000UL | 0xa0000000UL)    58 #define WRITE_PROTECTED_UINT8( _addr, _value ) \    60           volatile uint8_t *_ptr = _addr | 0x80000000; \    63 #define WRITE_PROTECTED_UINT16( _addr, _value ) \    65           volatile uint16_t *_ptr = _addr | 0x80000000; \    68 #define WRITE_PROTECTED_UINT32( _addr, _value ) \    70           volatile uint32_t *_ptr = _addr | 0x80000000; \    73 #define READ_PROTECTED_UINT8( _addr, _value ) \    75           volatile uint8_t *_ptr = _addr | 0x80000000; \    78 #define READ_PROTECTED_UINT16( _addr, _value ) \    80           volatile uint16_t *_ptr = _addr | 0x80000000; \    83 #define READ_PROTECTED_UINT32( _addr, _value ) \    85           volatile uint32_t *_ptr = _addr | 0x80000000; \    89 #define READ_UINT8( _register_, _value_ ) \    90         ((_value_) = *((volatile unsigned char *)(_register_)))    92 #define WRITE_UINT8( _register_, _value_ ) \    93         (*((volatile unsigned char *)(_register_)) = (_value_))    95 #define READ_UINT16( _register_, _value_ ) \    96      ((_value_) = *((volatile unsigned short *)(_register_)))    98 #define WRITE_UINT16( _register_, _value_ ) \    99      (*((volatile unsigned short *)(_register_)) = (_value_))   101 void simple_out_32(uint32_t base, uint32_t addr, uint32_t val);
   102 void simple_out_le32(uint32_t base, uint32_t addr, uint32_t val);
   103 uint8_t simple_in_8( uint32_t base, uint32_t addr );
   104 void simple_out_8( uint32_t base, uint32_t addr, uint8_t val );
   105 int16_t simple_in_le16( uint32_t base, uint32_t addr );
   106 int16_t simple_in_16( uint32_t base, uint32_t addr );
   107 uint32_t simple_in_le32( uint32_t base, uint32_t addr );
   108 uint32_t simple_in_32( uint32_t base, uint32_t addr );
   109 void simple_out_le16( uint32_t base, uint32_t addr, uint16_t val );
   110 void simple_out_16( uint32_t base, uint32_t addr, uint16_t val );
   116 void resettlb(
int i);
 DEFAULT_INITIAL_EXTENSION Support.
