#define  | BSP_FEATURE_IRQ_EXTENSION |
#define  | BSP_SHARED_HANDLER_SUPPORT   1 |
#define  | REVISION_REGISTER_ADDRESS   0x1fc00010 |
#define  | PRORV_MASK   0x0000000f   /* 4 bit Product Revision */ |
#define  | PROID_MASK   0x000000f0   /* 4 bit Product ID */ |
#define  | CORRV_MASK   0x00000300   /* 2 bit Core Board Revision */ |
#define  | CORID_MASK   0x0000fc00   /* 6 bit Core Board ID */ |
#define  | FPGRV_MASK   0x00ff0000   /* 8 bit CBUS FPGA Revision */ |
#define  | BSP_8259_BASE_ADDRESS   (0x18000000UL | 0xa0000000UL) |
#define  | BSP_PCI_BASE_ADDRESS   (0x1be00000UL | 0xa0000000UL) |
#define  | BSP_NIC_IO_BASE   (0x10000000UL | 0xa0000000UL) |
#define  | PCI0_IO_BASE   (0x18000000UL | 0xa0000000UL) |
#define  | BSP_NIC_MEM_BASE   (0x00000000UL | 0xa0000000UL) |
| #define  | WRITE_PROTECTED_UINT8(_addr,  _value) |
| #define  | WRITE_PROTECTED_UINT16(_addr,  _value) |
| #define  | WRITE_PROTECTED_UINT32(_addr,  _value) |
| #define  | READ_PROTECTED_UINT8(_addr,  _value) |
| #define  | READ_PROTECTED_UINT16(_addr,  _value) |
| #define  | READ_PROTECTED_UINT32(_addr,  _value) |
#define  | READ_UINT8(_register_,  _value_)   ((_value_) = *((volatile unsigned char *)(_register_))) |
#define  | WRITE_UINT8(_register_,  _value_)   (*((volatile unsigned char *)(_register_)) = (_value_)) |
#define  | READ_UINT16(_register_,  _value_)   ((_value_) = *((volatile unsigned short *)(_register_))) |
#define  | WRITE_UINT16(_register_,  _value_)   (*((volatile unsigned short *)(_register_)) = (_value_)) |
void  | simple_out_32 (uint32_t base, uint32_t addr, uint32_t val) |
void  | simple_out_le32 (uint32_t base, uint32_t addr, uint32_t val) |
uint8_t  | simple_in_8 (uint32_t base, uint32_t addr) |
void  | simple_out_8 (uint32_t base, uint32_t addr, uint8_t val) |
int16_t  | simple_in_le16 (uint32_t base, uint32_t addr) |
int16_t  | simple_in_16 (uint32_t base, uint32_t addr) |
uint32_t  | simple_in_le32 (uint32_t base, uint32_t addr) |
uint32_t  | simple_in_32 (uint32_t base, uint32_t addr) |
void  | simple_out_le16 (uint32_t base, uint32_t addr, uint16_t val) |
void  | simple_out_16 (uint32_t base, uint32_t addr, uint16_t val) |
void  | init_tlb (void) |
void  | resettlb (int i) |
