21 #ifndef LIBBSP_M68K_MVME167_BSP_H    22 #define LIBBSP_M68K_MVME167_BSP_H    56   unsigned char     chip_id;
    57   unsigned char     chip_revision;
    58   unsigned char     gen_control;
    59   unsigned char     vector_base;
    60   unsigned long     timer_cmp_1;
    61   unsigned long     timer_cnt_1;
    62   unsigned long     timer_cmp_2;
    63   unsigned long     timer_cnt_2;
    64   unsigned char     LSB_prescaler_count;
    65   unsigned char     prescaler_clock_adjust;
    66   unsigned char     timer_ctl_2;
    67   unsigned char     timer_ctl_1;
    68   unsigned char     gpi_int_ctl;
    69   unsigned char     gpio_ctl;
    70   unsigned char     timer_int_ctl_2;
    71   unsigned char     timer_int_ctl_1;
    72   unsigned char     SCC_error;
    73   unsigned char     SCC_modem_int_ctl;
    74   unsigned char     SCC_tx_int_ctl;
    75   unsigned char     SCC_rx_int_ctl;
    76   unsigned char     reserved1[3];
    77   unsigned char     modem_piack;
    78   unsigned char     reserved2;
    79   unsigned char     tx_piack;
    80   unsigned char     reserved3;
    81   unsigned char     rx_piack;
    82   unsigned char     LANC_error;
    83   unsigned char     reserved4;
    84   unsigned char     LANC_int_ctl;
    85   unsigned char     LANC_berr_ctl;
    86   unsigned char     SCSI_error;
    87   unsigned char     reserved5[2];
    88   unsigned char     SCSI_int_ctl;
    89   unsigned char     print_ack_int_ctl;
    90   unsigned char     print_fault_int_ctl;
    91   unsigned char     print_sel_int_ctl;
    92   unsigned char     print_pe_int_ctl;
    93   unsigned char     print_busy_int_ctl;
    94   unsigned char     reserved6;
    95   unsigned char     print_input_status;
    96   unsigned char     print_ctl;
    97   unsigned char     chip_speed;
    98   unsigned char     reserved7;
    99   unsigned char     print_data;
   100   unsigned char     reserved8[3];
   101   unsigned char     int_level;
   102   unsigned char     int_mask;
   109 #define pccchip2    ((pccchip2_regs * const) 0xFFF42000)   118   unsigned char     chip_id;
   119   unsigned char     reserved1[3];
   120   unsigned char     chip_revision;
   121   unsigned char     reserved2[3];
   122   unsigned char     mem_config;
   123   unsigned char     reserved3[3];
   124   unsigned char     alt_status;
   125   unsigned char     reserved4[3];
   126   unsigned char     alt_ctl;
   127   unsigned char     reserved5[3];
   128   unsigned char     base_addr;
   129   unsigned char     reserved6[3];
   130   unsigned char     ram_ctl;
   131   unsigned char     reserved7[3];
   132   unsigned char     bus_clk;
   139 #define memc040_1   ((memc040_regs * const) 0xFFF43000)   140 #define memc040_2   ((memc040_regs * const) 0xFFF43100)   157   unsigned char     reserved1[7];
   159   unsigned char     reserved2;
   161   unsigned char     reserved3[6];
   171   unsigned char     dmabsts;
   188   unsigned char     reserved4[2];
   201   unsigned char     reserved5[2];
   219   unsigned char     reserved6[2];
   221   unsigned char     reserved7;
   223   unsigned char     reserved8[7];
   224   unsigned short    tcbadru;
   225   unsigned short    tcbadrl;
   226   unsigned short    rcbadru;
   227   unsigned short    rcbadrl;
   228   unsigned short    arbadru;
   229   unsigned short    arbardl;
   230   unsigned short    brbadru;
   231   unsigned short    brbadrl;
   232   unsigned short    brbcnt;
   233   unsigned short    arbcnt;
   234   unsigned short    reserved9;
   235   unsigned char     brbsts;
   236   unsigned char     arbsts;
   237   unsigned short    atbadru;
   238   unsigned short    atbadrl;
   239   unsigned short    btbadru;
   240   unsigned short    btbadrl;
   241   unsigned short    btbcnt;
   242   unsigned short    atbcnt;
   243   unsigned short    reserved10;
   244   unsigned char     btbsts;
   245   unsigned char     atbsts;
   246   unsigned char     reserved11[32];
   249   unsigned char     reserved12[2];
   264   unsigned char     reserved13[2];
   265   unsigned char     bercnt;
   266   unsigned char     reserved14[49];
   268   unsigned char     reserved15[2];
   270   unsigned char     reserved16[4];
   272   unsigned char     reserved17[2];
   274   unsigned char     reserved18[10];
   276   unsigned char     reserved19[3];
   278   unsigned char     reserved20[3];
   279   unsigned char     msvr_rts;
   280   unsigned char     msvr_dtr;
   285   unsigned char     reserved21[8];
   290   unsigned char     reserved22[6];
   292   unsigned char     reserved23;
   300 #define cd2401          ((cd2401_regs * const) 0xFFF45000)   303 #define CD2401_CLK_RATE 20000000   308   rtems_isr_entry     handler,
   318 #define EXTERN extern   321 extern void *M68Kvec[];
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Interface to Kernel Print Methods.
Definition: mvme16x_hw.h:128
