25 #ifndef LIBBSP_M68K_MVME147_BSP_H    26 #define LIBBSP_M68K_MVME147_BSP_H    49 #define RAM_START 0x00005000    50 #define RAM_END   0x00400000    57   uint32_t         dma_table_address;
    58   uint32_t         dma_data_address;
    59   uint32_t         dma_bytecount;
    60   uint32_t         dma_data_holding;
    63   uint16_t         timer1_preload;
    64   uint16_t         timer1_count;
    65   uint16_t         timer2_preload;
    66   uint16_t         timer2_count;
    69   uint8_t         timer1_int_control;
    70   uint8_t         timer1_control;
    71   uint8_t         timer2_int_control;
    72   uint8_t         timer2_control;
    74   uint8_t         acfail_int_control;
    75   uint8_t         watchdog_control;
    77   uint8_t         printer_int_control;
    78   uint8_t         printer_control;
    80   uint8_t         dma_int_control;
    82   uint8_t         bus_error_int_control;
    84   uint8_t         abort_int_control;
    85   uint8_t         table_address_function_code;
    86   uint8_t         serial_port_int_control;
    87   uint8_t         general_purpose_control;
    88   uint8_t         lan_int_control;
    89   uint8_t         general_purpose_status;
    90   uint8_t         scsi_port_int_control;
    91   uint8_t         slave_base_address;
    92   uint8_t         software_int_1_control;
    93   uint8_t         int_base_vector;
    94   uint8_t         software_int_2_control;
    95   uint8_t         revision_level;
    98 #define pcc      ((volatile struct pcc_map * const) 0xfffe1000)   100 #define z8530 0xfffe3001   103 #define PCC_BASE_VECTOR        0x40    104 #define SCC_VECTOR             PCC_BASE_VECTOR+3   105 #define TIMER_1_VECTOR         PCC_BASE_VECTOR+8   106 #define TIMER_2_VECTOR         PCC_BASE_VECTOR+9   107 #define SOFT_1_VECTOR          PCC_BASE_VECTOR+10   108 #define SOFT_2_VECTOR          PCC_BASE_VECTOR+11   110 #define USE_CHANNEL_A   1                   111 #define USE_CHANNEL_B   0                   113 #if (USE_CHANNEL_A == 1)   114 #define CONSOLE_CONTROL  0xfffe3002   115 #define CONSOLE_DATA     0xfffe3003   116 #elif (USE_CHANNEL_B == 1)   117 #define CONSOLE_CONTROL  0xfffe3000   118 #define CONSOLE_DATA     0xfffe3001   121 extern rtems_isr_entry M68Kvec[];
   126   rtems_isr_entry     handler,
 rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
