22 #ifndef LIBBSP_M68K_MCF5206ELITE_BSP_H    23 #define LIBBSP_M68K_MCF5206ELITE_BSP_H    35 #include "mcf5206/mcf5206e.h"    48 #define BSP_MEM_ADDR_FLASH    (0xFFE00000)    49 #define BSP_MEM_SIZE_FLASH    (1*1024*1024)    50 #define BSP_MEM_MASK_FLASH    (MCF5206E_CSMR_MASK_1M)    53 #define BSP_MEM_ADDR_ESRAM    (0x30000000)    54 #define BSP_MEM_SIZE_ESRAM    (1*1024*1024)    55 #define BSP_MEM_MASK_ESRAM    (MCF5206E_CSMR_MASK_1M)    58 #define BSP_MEM_ADDR_GPIO     (0x40000000)    59 #define BSP_MEM_SIZE_GPIO     (64*1024)    60 #define BSP_MEM_MASK_GPIO     (MCF5206E_CSMR_MASK_64K)    63 #define BSP_MEM_ADDR_DRAM     (0x00000000)    64 #define BSP_MEM_SIZE_DRAM     (16*1024*1024)    65 #define BSP_MEM_MASK_DRAM     (MCF5206E_DCMR_MASK_16M)    68 #define BSP_MEM_ADDR_SRAM     (0x20000000)    69 #define BSP_MEM_SIZE_SRAM     (8*1024)    72 #define BSP_MEM_ADDR_IMM      (0x10000000)    73 #define BSP_MEM_SIZE_IMM      (1*1024)    74 #define MBAR BSP_MEM_ADDR_IMM    77 #define BSP_INTVEC_AVEC1    (25)    78 #define BSP_INTLVL_AVEC1    (1)    79 #define BSP_INTPRIO_AVEC1   (3)    81 #define BSP_INTVEC_AVEC2    (26)    82 #define BSP_INTLVL_AVEC2    (2)    83 #define BSP_INTPRIO_AVEC2   (3)    85 #define BSP_INTVEC_AVEC3    (27)    86 #define BSP_INTLVL_AVEC3    (3)    87 #define BSP_INTPRIO_AVEC3   (3)    89 #define BSP_INTVEC_AVEC4    (28)    90 #define BSP_INTLVL_AVEC4    (4)    91 #define BSP_INTPRIO_AVEC4   (3)    93 #define BSP_INTVEC_AVEC5    (29)    94 #define BSP_INTLVL_AVEC5    (5)    95 #define BSP_INTPRIO_AVEC5   (3)    97 #define BSP_INTVEC_AVEC6    (30)    98 #define BSP_INTLVL_AVEC6    (6)    99 #define BSP_INTPRIO_AVEC6   (3)   101 #define BSP_INTVEC_AVEC7    (31)   102 #define BSP_INTLVL_AVEC7    (7)   103 #define BSP_INTPRIO_AVEC7   (3)   105 #define BSP_INTVEC_TIMER1   (BSP_INTVEC_AVEC5)   106 #define BSP_INTLVL_TIMER1   (BSP_INTLVL_AVEC5)   107 #define BSP_INTPRIO_TIMER1  (2)   109 #define BSP_INTVEC_TIMER2    (BSP_INTVEC_AVEC6)   110 #define BSP_INTLVL_TIMER2    (BSP_INTLVL_AVEC6)   111 #define BSP_INTPRIO_TIMER2   (2)   113 #define BSP_INTVEC_MBUS     (BSP_INTVEC_AVEC4)   114 #define BSP_INTLVL_MBUS     (BSP_INTLVL_AVEC4)   115 #define BSP_INTPRIO_MBUS    (2)   117 #define BSP_INTVEC_UART1    (64)   118 #define BSP_INTLVL_UART1    (4)   119 #define BSP_INTPRIO_UART1   (0)   121 #define BSP_INTVEC_UART2    (65)   122 #define BSP_INTLVL_UART2    (4)   123 #define BSP_INTPRIO_UART2   (1)   125 #define BSP_INTVEC_DMA0     (66)   126 #define BSP_INTLVL_DMA0     (3)   127 #define BSP_INTPRIO_DMA0    (1)   129 #define BSP_INTVEC_DMA1     (67)   130 #define BSP_INTLVL_DMA1     (3)   131 #define BSP_INTPRIO_DMA1    (2)   134 #define DS1307_I2C_BUS_NUMBER (0)   147 #define BSP_SYSTEM_FREQUENCY ((unsigned int)&_SYS_CLOCK_FREQUENCY)   148 extern char _SYS_CLOCK_FREQUENCY;
   151 #define BSP_MBUS_FREQUENCY (16000)   154 #define I2C_NUMBER_OF_BUSES (1)   157 #define I2C_SELECT_BUS(bus)   164 #define rtems_bsp_delay( microseconds ) \   165   { register uint32_t         _delay=(microseconds); \   166     register uint32_t         _tmp=123; \   167     __asm__ volatile( "0: \   171                   : "=d" (_tmp), "=d" (_delay) \   172                   : "0"  (_tmp), "1"  (_delay) ); \   176 extern rtems_isr_entry M68Kvec[];
   183   rtems_isr_entry     handler,
   191 void Init5206e(
void);
 rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
