31 #ifndef LIBBSP_M68K_GEN68360_BSP_H    32 #define LIBBSP_M68K_GEN68360_BSP_H    53 struct rtems_bsdnet_ifconfig;
    54 extern int rtems_scc1_driver_attach (
struct rtems_bsdnet_ifconfig *
config,
int attaching);
    55 #define RTEMS_BSP_NETWORK_DRIVER_NAME   "scc1"    56 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_scc1_driver_attach    58 extern rtems_isr_entry M68Kvec[];
    62 void M360ExecuteRISC( uint16_t         command );
    63 void *M360AllocateBufferDescriptors(
int count );
    64 void *M360AllocateRiscTimers(
int count );
    65 extern char M360DefaultWatchdogFeeder;
    67 extern int m360_clock_rate;
    70   rtems_isr_entry     handler,
    78 #define ATLASHSB_ESR    0x20010000L    79 #define ATLASHSB_USICR  0x20010001L    80 #define ATLASHSB_DSRR   0x20010002L    81 #define ATLASHSB_LED4   0x20010004L    82 #define ATLASHSB_ROM_U6 0xFF080000L     92 #define PGH360_SPI_ADDR_EEPROM     0    93 #define PGH360_SPI_ADDR_DISP4_DATA 1    94 #define PGH360_SPI_ADDR_DISP4_CTRL 2    99 #define PGH360_PB_SPI_DISP4_RS_MSK   (1<<15)   100 #define PGH360_PB_SPI_DISP4_CE_MSK   (1<<14)   101 #define PGH360_PB_SPI_EEP_CE_MSK     (1<< 0)   107 void _Init68360(
void);
 Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
