26 #ifndef LIBBSP_M68K_GEN68340_BSP_H    27 #define LIBBSP_M68K_GEN68340_BSP_H    54 extern rtems_isr_entry M68Kvec[];
    59   rtems_isr_entry     handler,
    67 int dbug_in_char(
int minor );
    68 void dbug_out_char(
int minor,
int ch );
    69 int dbug_char_present(
int minor );
    70 void _dbug_dumpanic(
void);
    75 void _Init68340 (
void);
 rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
