21 #ifndef LIBBSP_LM32_LM32_EVR_BSP_H    22 #define LIBBSP_LM32_LM32_EVR_BSP_H    50 #if defined(RTEMS_NETWORKING)    51 struct rtems_bsdnet_ifconfig;
    53 extern int rtems_tsmac_driver_attach(
struct rtems_bsdnet_ifconfig *
config,
    56 #define RTEMS_BSP_NETWORK_DRIVER_NAME "TSMAC0"    57 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_tsmac_driver_attach    64 #define TSMAC_FORCE_10BASET    69   rtems_isr_entry     handler,
    77 void BSP_uart_polled_write(
char ch);
    78 int BSP_uart_polled_read(
void );
    79 char BSP_uart_is_character_ready(
char *ch);
 Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
