23 #ifndef LIBBSP_BFIN_BF537STAMP_BSP_H    24 #define LIBBSP_BFIN_BF537STAMP_BSP_H    43 #include <libcpu/bf537.h>    44 #include <libcpu/memoryRegs.h>    51 #define BSP_DATA_CACHE_CONFIG  (3 << DMEM_CONTROL_DMC_SHIFT)    68 #define PLL_CSEL    0x0000          69 #define PLL_SSEL    0x0003          70 #define PLL_MSEL    0x3A00          73 #define CCLK        500000000       74 #define SCLK        100000000       76 #define CONSOLE_FORCE_BAUD   57600    81 #define L1_DATA_SRAM_A 0xff800000L    83 #define FIFOLENGTH 0x100    90 #define rtems_bsp_delay( microseconds ) \    97 #define RAM_END   0x4000000   105 void setLED(uint8_t value);
   110 uint8_t getLEDs(
void);
   111 void setLEDs(uint8_t value);
   112 uint8_t getButtons(
void);
   115   rtems_isr_entry     handler,
   128 struct rtems_bsdnet_ifconfig;
   129 extern int bf537Stamp_network_driver_attach(
struct rtems_bsdnet_ifconfig *,
int);
   131 #define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth1"   132 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH bf537Stamp_network_driver_attach rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
Helper Function to use the EzKits LEDS. Can be used by the Application.
Definition: bspstart.c:145
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
