RTEMS
5.1
Interrupt definitions. More...
| #define | LIBBSP_ARM_RASPBERRYPI_IRQ_H |
| #define | BCM2835_INTC_TOTAL_IRQ 64 + 8 |
| #define | BCM2835_IRQ_SET1_MIN 0 |
| #define | BCM2835_IRQ_SET2_MIN 32 |
| #define | BCM2835_IRQ_ID_GPU_TIMER_M0 0 |
| #define | BCM2835_IRQ_ID_GPU_TIMER_M1 1 |
| #define | BCM2835_IRQ_ID_GPU_TIMER_M2 2 |
| #define | BCM2835_IRQ_ID_GPU_TIMER_M3 3 |
| #define | BCM2835_IRQ_ID_USB 9 |
| #define | BCM2835_IRQ_ID_AUX 29 |
| #define | BCM2835_IRQ_ID_SPI_SLAVE 43 |
| #define | BCM2835_IRQ_ID_PWA0 45 |
| #define | BCM2835_IRQ_ID_PWA1 46 |
| #define | BCM2835_IRQ_ID_SMI 48 |
| #define | BCM2835_IRQ_ID_GPIO_0 49 |
| #define | BCM2835_IRQ_ID_GPIO_1 50 |
| #define | BCM2835_IRQ_ID_GPIO_2 51 |
| #define | BCM2835_IRQ_ID_GPIO_3 52 |
| #define | BCM2835_IRQ_ID_I2C 53 |
| #define | BCM2835_IRQ_ID_SPI 54 |
| #define | BCM2835_IRQ_ID_PCM 55 |
| #define | BCM2835_IRQ_ID_UART 57 |
| #define | BCM2835_IRQ_ID_SD 62 |
| #define | BCM2835_IRQ_ID_BASIC_BASE_ID 64 |
| #define | BCM2835_IRQ_ID_TIMER_0 64 |
| #define | BCM2835_IRQ_ID_MAILBOX_0 65 |
| #define | BCM2835_IRQ_ID_DOORBELL_0 66 |
| #define | BCM2835_IRQ_ID_DOORBELL_1 67 |
| #define | BCM2835_IRQ_ID_GPU0_HALTED 68 |
| #define | BCM2835_IRQ_ID_GPU1_HALTED 69 |
| #define | BCM2835_IRQ_ID_ILL_ACCESS_1 70 |
| #define | BCM2835_IRQ_ID_ILL_ACCESS_0 71 |
| #define | BSP_INTERRUPT_VECTOR_MIN (0) |
| #define | BSP_INTERRUPT_VECTOR_MAX (BCM2835_INTC_TOTAL_IRQ - 1) |
| #define | BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX) |
| #define | BSP_IRQ_COUNT (BCM2835_INTC_TOTAL_IRQ) |
| #define LIBBSP_ARM_RASPBERRYPI_IRQ_H |
Copyright (c) 2013 Alan Cudmore
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at
1.8.15
