23 #ifndef LIBBSP_ARM_LPC32XX_BSP_H    24 #define LIBBSP_ARM_LPC32XX_BSP_H    38 #define BSP_FEATURE_IRQ_EXTENSION    51 struct rtems_bsdnet_ifconfig;
    57   struct rtems_bsdnet_ifconfig *
config,
    64 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH lpc_eth_attach_detach    69 #define RTEMS_BSP_NETWORK_DRIVER_NAME "eth0"    93 #define LPC32XX_STANDARD_TIMER (&lpc32xx.timer_1)    95 static inline unsigned lpc32xx_timer(
void)
    97   volatile lpc_timer *timer = LPC32XX_STANDARD_TIMER;
   102 static inline void lpc32xx_micro_seconds_delay(
unsigned us)
   104   unsigned start = lpc32xx_timer();
   105   unsigned delay = us * (LPC32XX_PERIPH_CLK / 1000000);
   106   unsigned elapsed = 0;
   109     elapsed = lpc32xx_timer() - start;
   110   }
while (elapsed < delay);
   113 #if LPC32XX_OSCILLATOR_MAIN == 13000000U   114   #define LPC32XX_HCLKPLL_CTRL_INIT_VALUE \   115     (HCLK_PLL_POWER | HCLK_PLL_DIRECT | HCLK_PLL_M(16 - 1))   116   #define LPC32XX_HCLKDIV_CTRL_INIT_VALUE \   117     (HCLK_DIV_HCLK(2 - 1) | HCLK_DIV_PERIPH_CLK(16 - 1) | HCLK_DIV_DDRAM_CLK(0))   119   #error "unexpected main oscillator frequency"   122 bool lpc32xx_start_pll_setup(
   123   uint32_t hclkpll_ctrl,
   124   uint32_t hclkdiv_ctrl,
   128 uint32_t lpc32xx_sysclk(
void);
   130 uint32_t lpc32xx_hclkpll_clk(
void);
   132 uint32_t lpc32xx_periph_clk(
void);
   134 uint32_t lpc32xx_hclk(
void);
   136 uint32_t lpc32xx_arm_clk(
void);
   138 uint32_t lpc32xx_ddram_clk(
void);
   141   LPC32XX_NAND_CONTROLLER_NONE,
   142   LPC32XX_NAND_CONTROLLER_MLC,
   143   LPC32XX_NAND_CONTROLLER_SLC
   144 } lpc32xx_nand_controller;
   146 void lpc32xx_select_nand_controller(lpc32xx_nand_controller nand_controller);
   152 #define BSP_IDLE_TASK_BODY bsp_idle_thread   154 #define BSP_CONSOLE_UART_BASE LPC32XX_BASE_UART_5   177 #ifdef LPC32XX_SCRATCH_AREA_SIZE   183   extern uint8_t lpc32xx_scratch_area [LPC32XX_SCRATCH_AREA_SIZE]
   187 #define LPC32XX_DO_STOP_GPDMA \   189     if ((LPC32XX_DMACLK_CTRL & 0x1) != 0) { \   190       if ((lpc32xx.dma.cfg & DMA_CFG_E) != 0) { \   192         for (i = 0; i < 8; ++i) { \   193           lpc32xx.dma.channels [i].cfg = 0; \   195         lpc32xx.dma.cfg &= ~DMA_CFG_E; \   197       LPC32XX_DMACLK_CTRL = 0; \   201 #define LPC32XX_DO_STOP_ETHERNET \   203     if ((LPC32XX_MAC_CLK_CTRL & 0x7) == 0x7) { \   204       lpc32xx.eth.command = 0x38; \   205       lpc32xx.eth.mac1 = 0xcf00; \   206       lpc32xx.eth.mac1 = 0; \   207       LPC32XX_MAC_CLK_CTRL = 0; \   211 #define LPC32XX_DO_STOP_USB \   213     if ((LPC32XX_USB_CTRL & 0x010e8000) != 0) { \   214       LPC32XX_OTG_CLK_CTRL = 0; \   215       LPC32XX_USB_CTRL = 0x80000; \   219 #define LPC32XX_DO_RESTART(addr) \   221     ARM_SWITCH_REGISTERS; \   222     rtems_interrupt_level level; \   225     rtems_interrupt_disable(level); \   228     arm_cp15_data_cache_test_and_clean(); \   229     arm_cp15_instruction_cache_invalidate(); \   231     ctrl = arm_cp15_get_control(); \   232     ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M); \   233     arm_cp15_set_control(ctrl); \   237       "mov pc, %[addr]\n" \   239       : ARM_SWITCH_OUTPUT \   240       : [addr] "r" (addr) \ Definition: deflate.c:115
void * lpc32xx_idle(uintptr_t ignored)
Optimized idle task.
int lpc_eth_attach_detach(struct rtems_bsdnet_ifconfig *config, int attaching)
Network driver attach and detach function.
Definition: lpc-ethernet.c:1827
Timer control block.
Definition: lpc-timer.h:133
DEFAULT_INITIAL_EXTENSION Support.
uint32_t lpc32xx_magic_zero_size[]
Size of magic zero area.
uint32_t lpc32xx_magic_zero_begin[]
Begin of magic zero area.
uint32_t lpc32xx_magic_zero_end[]
End of magic zero area.
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
void * bsp_idle_thread(uintptr_t ignored)
Definition: bspidle.c:26
void bsp_restart(const void *addr)
Restarts the bsp with "addr" address.
Definition: restart.c:25
