Global BSP definitions.
More...
#include <bspopts.h>
#include <bsp/lpc32xx.h>
#include <bsp/default-initial-extension.h>
#define  | BSP_FEATURE_IRQ_EXTENSION |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   lpc_eth_attach_detach |
|   | Standard network driver attach and detach function.
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "eth0" |
|   | Standard network driver name.
#define  | LPC32XX_STANDARD_TIMER   (&lpc32xx.timer_1) |
#define  | BSP_IDLE_TASK_BODY   bsp_idle_thread |
#define  | BSP_CONSOLE_UART_BASE   LPC32XX_BASE_UART_5 |
| #define  | LPC32XX_DO_STOP_GPDMA |
| #define  | LPC32XX_DO_STOP_ETHERNET |
| #define  | LPC32XX_DO_STOP_USB |
| #define  | LPC32XX_DO_RESTART(addr) |
| enum   | lpc32xx_nand_controller { LPC32XX_NAND_CONTROLLER_NONE,
LPC32XX_NAND_CONTROLLER_MLC,
LPC32XX_NAND_CONTROLLER_SLC
int  | lpc_eth_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
|   | Network driver attach and detach function.
| void *  | lpc32xx_idle (uintptr_t ignored) |
|   | Optimized idle task.  More...
bool  | lpc32xx_start_pll_setup (uint32_t hclkpll_ctrl, uint32_t hclkdiv_ctrl, bool force) |
uint32_t  | lpc32xx_sysclk (void) |
uint32_t  | lpc32xx_hclkpll_clk (void) |
uint32_t  | lpc32xx_periph_clk (void) |
uint32_t  | lpc32xx_hclk (void) |
uint32_t  | lpc32xx_arm_clk (void) |
uint32_t  | lpc32xx_ddram_clk (void) |
void  | lpc32xx_select_nand_controller (lpc32xx_nand_controller nand_controller) |
void  | bsp_restart (void *addr) |
| void *  | bsp_idle_thread (uintptr_t arg) |
