    RTEMS
    5.1
#include <bspopts.h>#include <stdbool.h>Go to the source code of this file.
| struct | lm3s69xx_gpio_config |
| void | lm3s69xx_gpio_set_config (const lm3s69xx_gpio_config *config) |
| void | lm3s69xx_gpio_set_config_array (const lm3s69xx_gpio_config *configs, unsigned int count) |
| void | lm3s69xx_gpio_digital_enable (unsigned int pin, bool enable) |
| void | lm3s69xx_gpio_analog_mode_select (unsigned int pin, bool enable) |
| void | lm3s69xx_gpio_set_pin (unsigned int pin, bool set) |
| bool | lm3s69xx_gpio_get_pin (unsigned int pin) |
IO definitions.
| #define LM3S69XX_PIN_LED | ( | port, | |
| idx | |||
| #define LM3S69XX_PIN_UART_CTS | ( | port, | |
| idx | |||
| #define LM3S69XX_PIN_UART_RTS | ( | port, | |
| idx | |||
| #define LM3S69XX_PIN_UART_RX | ( | port, | |
| idx | |||
| #define LM3S69XX_PIN_UART_TX | ( | port, | |
| idx | |||
| void lm3s69xx_gpio_analog_mode_select | ( | unsigned int | pin, |
| bool | enable | ||
Enables/disables analog mode on the specified pin.
| void lm3s69xx_gpio_digital_enable | ( | unsigned int | pin, |
| bool | enable | ||
Enables/disables digital function on the specified pin.
 1.8.15
