RTEMS  5.1
Data Structures | Typedefs | Enumerations | Functions
interrupt.h File Reference
struct  bfin_isr_s
typedef struct bfin_isr_s bfin_isr_t
enum  e_isr_t {
  IRQ_PLL_WAKEUP_INTERRUPT, IRQ_DMA_ERROR_0, IRQ_DMAR0_BLOCK_INTERRUPT, IRQ_DMAR1_BLOCK_INTERRUPT,
  IRQ_DMAR0_OVERFLOW_ERROR, IRQ_DMAR1_OVERFLOW_ERROR, IRQ_PPI_STATUS, IRQ_MAC_STATUS,
  IRQ_SPORT0_STATUS, IRQ_SPORT1_STATUS, IRQ_RESERVED_10, IRQ_RESERVED_11,
  IRQ_UART0_STATUS, IRQ_UART1_STATUS, IRQ_REAL_TIME_CLOCK, IRQ_DMA0_PPI_NFC,
  IRQ_DMA3_SPORT0_RX, IRQ_DMA4_SPORT0_TX, IRQ_DMA5_SPORT1_RX, IRQ_DMA6_SPORT1_TX,
  IRQ_TWI_INTERRUPT, IRQ_DMA7_SPI, IRQ_DMA8_UART0_RX, IRQ_DMA9_UART0_TX,
  IRQ_DMA10_UART1_RX, IRQ_DMA11_UART1_TX, IRQ_OTP, IRQ_GP_COUNTER,
  IRQ_DMA1_MAC_RX_HOSTDP, IRQ_PORT_H_INTERRUPT_A, IRQ_DMA2_MAC_TX_NFC, IRQ_PORT_H_INTERRUPT_B,
  SIC_ISR0_MAX, IRQ_TIMER0 = SIC_ISR0_MAX, IRQ_TIMER1, IRQ_TIMER2,
  IRQ_TIMER3, IRQ_TIMER4, IRQ_TIMER5, IRQ_TIMER6,
  IRQ_TIMER7, IRQ_PORT_G_INTERRUPT_A, IRQ_PORT_G_INTERRUPT_B, IRQ_MDMA0_STREAM_0_INTERRUPT,
  IRQ_MDMA1_STREAM_0_INTERRUPT, IRQ_SOFTWARE_WATCHDOG_INTERRUPT, IRQ_PORT_F_INTERRUPT_A, IRQ_PORT_F_INTERRUPT_B,
  IRQ_SPI_STATUS, IRQ_NFC_STATUS, IRQ_HOSTDP_STATUS, IRQ_HOREAD_DONE_INTERRUPT,
  IRQ_RESERVED_19, IRQ_USB_INT0_INTERRUPT, IRQ_USB_INT1_INTERRUPT, IRQ_USB_INT2_INTERRUPT,
  IRQ_USB_DMAINT, IRQ_MAX
rtems_status_code bfin_interrupt_register (bfin_isr_t *isr)
rtems_status_code bfin_interrupt_unregister (bfin_isr_t *isr)
void bfin_interrupt_init (void)
Target: TLL6527v1-0 Compiler:
COPYRIGHT (c) 2010 by ECE Northeastern University.
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license
Author
Rohan Kangralkar, ECE, Northeastern University (kangr.nosp@m.alka.nosp@m.r.r@h.nosp@m.usky.nosp@m..neu..nosp@m.edu)
LastChange:
◆ e_isr_t
enum e_isr_t
The type of interrupts handled by the SIC
◆ bfin_interrupt_init()
void bfin_interrupt_init ( void  )
blackfin interrupt initialization routine. It initializes the bfin ISR dispatcher. It will also create SIC CEC map which will be used for identifying the ISR.
Initializes the interrupt module
The bf52x has 8 IAR registers but they do not have a constant pitch.
◆ bfin_interrupt_register()
rtems_status_code bfin_interrupt_register ( bfin_isr_t *  isr)
This routine registers a new ISR. It will write a new entry to the IVT table
Parameters
isrcontains a callback function and source
Returns
rtems status code
◆ bfin_interrupt_unregister()
rtems_status_code bfin_interrupt_unregister ( bfin_isr_t *  isr)
This function unregisters a registered interrupt handler.
Parameters
isr
