RTEMS  5.1
cpu.h
1
10 /*
11  * COPYRIGHT (c) 1989-2006.
12  * On-Line Applications Research Corporation (OAR).
13  * adapted to Blackfin by Alain Schaefer <alain.schaefer@easc.ch>
14  * and Antonio Giovanini <antonio@atos.com.br>
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_SCORE_CPU_H
22 #define _RTEMS_SCORE_CPU_H
23
24 #ifdef __cplusplus
25 extern "C" {
26 #endif
27
28 #include <rtems/score/basedefs.h>
29 #include <rtems/score/bfin.h>
30
31 /* conditional compilation parameters */
32
33 /*
34  * Does the CPU follow the simple vectored interrupt model?
35  *
36  * If TRUE, then RTEMS allocates the vector table it internally manages.
37  * If FALSE, then the BSP is assumed to allocate and manage the vector
38  * table
39  *
40  * BFIN Specific Information:
41  *
42  * XXX document implementation including references if appropriate
43  */
44 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
45
55 #define CPU_ISR_PASSES_FRAME_POINTER TRUE
56
57 #define CPU_HARDWARE_FP FALSE
58
59 #define CPU_SOFTWARE_FP FALSE
60
61 #define CPU_ALL_TASKS_ARE_FP FALSE
62
63 #define CPU_IDLE_TASK_IS_FP FALSE
64
65 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
66
67 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
68
80 #define CPU_STACK_GROWS_UP FALSE
81
82 /* FIXME: Is this the right value? */
83 #define CPU_CACHE_LINE_BYTES 32
84
85 #define CPU_STRUCTURE_ALIGNMENT
86
97 #define CPU_MODES_INTERRUPT_MASK 0x00000001
98
99 #define CPU_MAXIMUM_PROCESSORS 32
100
101 /*
102  * Processor defined structures required for cpukit/score.
103  *
104  * Port Specific Information:
105  *
106  * XXX document implementation including references if appropriate
107  */
108
109 /* may need to put some structures here. */
110
111 #ifndef ASM
112
164 /* make sure this stays in sync with the assembly function
165  __CPU_Context_switch in cpu_asm.S */
166 typedef struct {
167  uint32_t register_r4;
168  uint32_t register_r5;
169  uint32_t register_r6;
170  uint32_t register_r7;
171
172  uint32_t register_p3;
173  uint32_t register_p4;
174  uint32_t register_p5;
175  uint32_t register_fp;
176  uint32_t register_sp;
177
178  uint32_t register_rets;
179
180  uint32_t imask;
182
183 #define _CPU_Context_Get_SP( _context ) \
184  (_context)->register_sp
185
191 typedef struct {
196  /*uint32_t special_interrupt_register;*/
198
209 #endif /* ASM */
210
221 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
222
232 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 16
233
238 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
239
245 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
246
256 #define CPU_STACK_MINIMUM_SIZE (1024*8)
257
258 #define CPU_SIZEOF_POINTER 4
259
268 #define CPU_ALIGNMENT 8
269
293 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
294
308 #define CPU_STACK_ALIGNMENT 8
309
310 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
311
312 #ifndef ASM
313
314 /*
315  * ISR handler macros
316  */
317
330 #define _CPU_Initialize_vectors()
331
342 #define _CPU_ISR_Disable( _level ) \
343  { \
344  __asm__ volatile ("cli %0; csync \n" : "=d" (_level) ); \
345  }
346
347
359 #define _CPU_ISR_Enable( _level ) { \
360  __asm__ __volatile__ ("sti %0; csync \n" : : "d" (_level) ); \
361  }
362
375 #define _CPU_ISR_Flash( _level ) { \
376  __asm__ __volatile__ ("sti %0; csync; cli r0; csync" \
377  : : "d"(_level) : "R0" ); \
378  }
379
380 RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
381 {
382  return level != 0;
383 }
384
400 #define _CPU_ISR_Set_level( _new_level ) \
401  { \
402  __asm__ __volatile__ ( "sti %0; csync" : : "d"(_new_level ? 0 : 0xffff) ); \
403  }
404
415 uint32_t _CPU_ISR_Get_level( void );
416
417 /* end of ISR handler macros */
418
421 /* Context handler macros */
422
456  Context_Control *the_context,
457  uint32_t *stack_base,
458  uint32_t size,
459  uint32_t new_level,
460  void *entry_point,
461  bool is_fp,
462  void *tls_area
463 );
464
480 #define _CPU_Context_Restart_self( _the_context ) \
481  _CPU_Context_restore( (_the_context) );
482
483 /* end of Context handler macros */
484
485 /* Fatal Error manager macros */
486
496 #define _CPU_Fatal_halt( _source, _error ) \
497  { \
498  __asm__ volatile ( "cli R1; \
499  R1 = %0; \
500  _halt: \
501  idle; \
502  jump _halt;"\
503  : : "r" (_error) ); \
504  }
505
506 /* end of Fatal Error manager macros */
507
508 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
509
510 /* functions */
511
520 void _CPU_Initialize(void);
521
522 typedef void ( *CPU_ISR_raw_handler )( void );
523
525  uint32_t vector,
526  CPU_ISR_raw_handler new_handler,
527  CPU_ISR_raw_handler *old_handler
528 );
529
530 typedef void ( *CPU_ISR_handler )( uint32_t );
531
533  uint32_t vector,
534  CPU_ISR_handler new_handler,
535  CPU_ISR_handler *old_handler
536 );
537
538 void *_CPU_Thread_Idle_body( uintptr_t ignored );
539
556  Context_Control *run,
557  Context_Control *heir
558 );
559
573  Context_Control *new_context
575
578 /* FIXME */
580
582
592 /*
593  *
594  * The following routine swaps the endian format of an unsigned int.
595  * It must be static because it is referenced indirectly.
596  *
597  * This version will work on any processor, but if there is a better
598  * way for your CPU PLEASE use it. The most common way to do this is to:
599  *
600  * swap least significant two bytes with 16-bit rotate
601  * swap upper and lower 16-bits
602  * swap most significant two bytes with 16-bit rotate
603  *
604  * Some CPUs have special instructions which swap a 32-bit quantity in
605  * a single instruction (e.g. i486). It is probably best to avoid
606  * an "endian swapping control bit" in the CPU. One good reason is
607  * that interrupts would probably have to be disabled to ensure that
608  * an interrupt does not try to access the same "chunk" with the wrong
609  * endian. Another good reason is that on some CPUs, the endian bit
610  * endianness for ALL fetches -- both code and data -- so the code
611  * will be fetched incorrectly.
612  *
613  * @param[in] value is the value to be swapped
614  * @return the value after being endian swapped
615  *
616  * Port Specific Information:
617  *
618  * XXX document implementation including references if appropriate
619  */
620
621 static inline uint32_t CPU_swap_u32(
622  uint32_t value
623 )
624 {
625  uint32_t byte1, byte2, byte3, byte4, swapped;
626
627  byte4 = (value >> 24) & 0xff;
628  byte3 = (value >> 16) & 0xff;
629  byte2 = (value >> 8) & 0xff;
630  byte1 = value & 0xff;
631
632  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
633  return( swapped );
634 }
635
642 #define CPU_swap_u16( value ) \
643  (((value&0xff) << 8) | ((value >> 8)&0xff))
644
647 typedef uint32_t CPU_Counter_ticks;
648
649 uint32_t _CPU_Counter_frequency( void );
650
651 CPU_Counter_ticks _CPU_Counter_read( void );
652
653 static inline CPU_Counter_ticks _CPU_Counter_difference(
654  CPU_Counter_ticks second,
655  CPU_Counter_ticks first
656 )
657 {
658  return second - first;
659 }
660
662 typedef uintptr_t CPU_Uint32ptr;
663
664 #endif /* ASM */
665
666 #ifdef __cplusplus
667 }
668 #endif
669
670 #endif
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Blackfin Set up Basic CPU Dependency Settings Based on Compiler Settings.
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU initialization.
Definition: cpu.c:45
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
unsigned size
Definition: tte.h:74
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
