#define  | CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE |
#define  | CPU_ISR_PASSES_FRAME_POINTER   FALSE |
#define  | CPU_HARDWARE_FP   FALSE |
#define  | CPU_SOFTWARE_FP   FALSE |
#define  | CPU_ALL_TASKS_ARE_FP   FALSE |
#define  | CPU_IDLE_TASK_IS_FP   FALSE |
#define  | CPU_USE_DEFERRED_FP_SWITCH   FALSE |
#define  | CPU_ENABLE_ROBUST_THREAD_DISPATCH   TRUE |
#define  | CPU_STACK_GROWS_UP   FALSE |
#define  | CPU_CACHE_LINE_BYTES   32 |
#define  | CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define  | CPU_MODES_INTERRUPT_MASK   0x1 |
#define  | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0 |
#define  | CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE |
#define  | CPU_STACK_MINIMUM_SIZE   (1024 * 4) |
#define  | CPU_SIZEOF_POINTER   4 |
#define  | CPU_ALIGNMENT   8 |
#define  | CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT |
#define  | CPU_STACK_ALIGNMENT   8 |
#define  | CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES |
#define  | CPU_USE_GENERIC_BITFIELD_CODE   TRUE |
#define  | CPU_MAXIMUM_PROCESSORS   32 |
#define  | ARM_EXCEPTION_FRAME_SIZE   80 |
#define  | ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET   52 |
#define  | ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET   72 |
#define  | ARM_VFP_CONTEXT_SIZE   264 |
| #define  | _CPU_ISR_Disable(_isr_cookie) |
#define  | _CPU_ISR_Enable(_isr_cookie)   arm_interrupt_enable( _isr_cookie ) |
#define  | _CPU_ISR_Flash(_isr_cookie)   arm_interrupt_flash( _isr_cookie ) |
#define  | _CPU_Context_Get_SP(_context)   (_context)->register_sp |
#define  | _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) ); |
| #define  | _CPU_Context_Initialize_fp(_destination) |
| #define  | _CPU_Fatal_halt(_source,  _err) |
ARM Architecture Support API.
