RTEMS  5.1
twi.c File Reference
#include "chip.h"
#include <assert.h>
#define TWIHS_IT
void TWI_ConfigureMaster (Twihs *pTwi, uint32_t dwTwCk, uint32_t dwMCk)
 Configures a TWI peripheral to operate in master mode, at the given frequency (in Hz). The duty cycle of the TWI clock is set to 50%. More...
void TWI_ConfigureSlave (Twihs *pTwi, uint8_t slaveAddress)
 Configures a TWI peripheral to operate in slave mode. More...
void TWI_Stop (Twihs *pTwi)
 Sends a STOP condition on the TWI. More...
void TWI_StartRead (Twihs *pTwi, uint8_t address, uint32_t iaddress, uint8_t isize)
 Starts a read operation on the TWI bus with the specified slave, it returns immediately. Data must then be read using TWI_ReadByte() whenever a byte is available (poll using TWI_ByteReceived()). More...
uint8_t TWI_ReadByte (Twihs *pTwi)
 Reads a byte from the TWI bus. The read operation must have been started using TWI_StartRead() and a byte must be available (check with TWI_ByteReceived()). More...
void TWI_WriteByte (Twihs *pTwi, uint8_t byte)
 Sends a byte of data to one of the TWI slaves on the bus. More...
void TWI_StartWrite (Twihs *pTwi, uint8_t address, uint32_t iaddress, uint8_t isize, uint8_t byte)
 Starts a write operation on the TWI to access the selected slave, then returns immediately. A byte of data must be provided to start the write; other bytes are written next. after that to send the remaining bytes. More...
uint8_t TWI_ByteReceived (Twihs *pTwi)
 Check if a byte have been received from TWI. More...
uint8_t TWI_ByteSent (Twihs *pTwi)
 Check if a byte have been sent to TWI. More...
uint8_t TWI_TransferComplete (Twihs *pTwi)
 Check if current transmission is completed. More...
void TWI_EnableIt (Twihs *pTwi, uint32_t sources)
 Enables the selected interrupts sources on a TWI peripheral. More...
void TWI_DisableIt (Twihs *pTwi, uint32_t sources)
 Disables the selected interrupts sources on a TWI peripheral. More...
uint32_t TWI_GetStatus (Twihs *pTwi)
 Get the current status register of the given TWI peripheral. More...
uint32_t TWI_GetMaskedStatus (Twihs *pTwi)
 Returns the current status register of the given TWI peripheral, but masking interrupt sources which are not currently enabled. More...
void TWI_SendSTOPCondition (Twihs *pTwi)
 Sends a STOP condition. STOP Condition is sent just after completing the current byte transmission in master read mode. More...
uint32_t twi_send_stop = 0
Implementation of Two Wire Interface (TWI).
◆ TWIHS_IT
#define TWIHS_IT
Value:
TWIHS_IER_OVRE | TWIHS_IER_UNRE | TWIHS_IER_NACK | \
TWIHS_IER_ARBLST | TWIHS_IER_SCL_WS | TWIHS_IER_EOSACC | \
TWIHS_IER_MCACK | TWIHS_IER_TOUT | TWIHS_IER_PECERR |\
TWIHS_IER_SMBDAM | TWIHS_IER_SMBHHM)
#define TWIHS_IER_RXRDY
(TWIHS_IER) Receive Holding Register Ready Interrupt Enable
Definition: component_twihs.h:147
#define TWIHS_IER_PECERR
(TWIHS_IER) PEC Error Interrupt Enable
Definition: component_twihs.h:159
#define TWIHS_IER_TOUT
(TWIHS_IER) Timeout Error Interrupt Enable
Definition: component_twihs.h:158
#define TWIHS_IER_SVACC
(TWIHS_IER) Slave Access Interrupt Enable
Definition: component_twihs.h:149
#define TWIHS_IER_NACK
(TWIHS_IER) Not Acknowledge Interrupt Enable
Definition: component_twihs.h:153
#define TWIHS_IER_SCL_WS
(TWIHS_IER) Clock Wait State Interrupt Enable
Definition: component_twihs.h:155
#define TWIHS_IER_SMBHHM
(TWIHS_IER) SMBus Host Header Address Match Interrupt Enable
Definition: component_twihs.h:161
#define TWIHS_IER_TXRDY
(TWIHS_IER) Transmit Holding Register Ready Interrupt Enable
Definition: component_twihs.h:148
#define TWIHS_IER_UNRE
(TWIHS_IER) Underrun Error Interrupt Enable
Definition: component_twihs.h:152
#define TWIHS_IER_TXCOMP
(TWIHS_IER) Transmission Completed Interrupt Enable
Definition: component_twihs.h:146
#define TWIHS_IER_EOSACC
(TWIHS_IER) End Of Slave Access Interrupt Enable
Definition: component_twihs.h:156
#define TWIHS_IER_GACC
(TWIHS_IER) General Call Access Interrupt Enable
Definition: component_twihs.h:150
◆ TWI_ByteReceived()
uint8_t TWI_ByteReceived ( Twihs *  pTwi)
Parameters
pTwiPointer to an Twihs instance.
Returns
1 if a byte has been received and can be read on the given TWI peripheral; otherwise, returns 0. This function resets the status register.
◆ TWI_ByteSent()
uint8_t TWI_ByteSent ( Twihs *  pTwi)
Parameters
Returns
1 if a byte has been sent so another one can be stored for transmission; otherwise returns 0. This function clears the status register.
◆ TWI_ConfigureMaster()
void TWI_ConfigureMaster ( Twihs *  pTwi,
uint32_t  dwTwCk,
uint32_t  dwMCk
Parameters
twckDesired TWI clock frequency.
mckMaster clock frequency.
◆ TWI_ConfigureSlave()
void TWI_ConfigureSlave ( Twihs *  pTwi,
Parameters
slaveAddressSlave address.
◆ TWI_DisableIt()
void TWI_DisableIt ( Twihs *  pTwi,
uint32_t  sources
Parameters
sourcesBitwise OR of selected interrupt sources.
◆ TWI_EnableIt()
void TWI_EnableIt ( Twihs *  pTwi,
uint32_t  sources
Parameters
◆ TWI_GetMaskedStatus()
uint32_t TWI_GetMaskedStatus ( Twihs *  pTwi)
Note
This resets the internal value of the status register, so further read may yield different values.
Parameters
◆ TWI_GetStatus()
uint32_t TWI_GetStatus ( Twihs *  pTwi)
Note
Parameters
Returns
TWI status register.
◆ TWI_ReadByte()
uint8_t TWI_ReadByte ( Twihs *  pTwi)
Parameters
Returns
byte read.
◆ TWI_SendSTOPCondition()
void TWI_SendSTOPCondition ( Twihs *  pTwi)
Parameters
◆ TWI_StartRead()
void TWI_StartRead ( Twihs *  pTwi,
uint8_t  address,
uint32_t  iaddress,
uint8_t  isize
Parameters
addressSlave address on the bus.
iaddressOptional internal address bytes.
isizeNumber of internal address bytes.
◆ TWI_StartWrite()
void TWI_StartWrite ( Twihs *  pTwi,
uint8_t  address,
uint32_t  iaddress,
uint8_t  isize,
uint8_t  byte
Parameters
addressAddress of slave to acccess on the bus.
iaddressOptional slave internal address.
byteFirst byte to send.
◆ TWI_Stop()
void TWI_Stop ( Twihs *  pTwi)
Parameters
◆ TWI_TransferComplete()
uint8_t TWI_TransferComplete ( Twihs *  pTwi)
Parameters
Returns
1 if the current transmission is complete (the STOP has been sent); otherwise returns 0.
◆ TWI_WriteByte()
void TWI_WriteByte ( Twihs *  pTwi,
uint8_t  byte
Note
This function must be called once before TWI_StartWrite() with the first byte of data to send, then it shall be called repeatedly after that to send the remaining bytes.
Parameters
byteByte to send.
Variable Documentation
◆ twi_send_stop
variable for control thether or not to set both START and STOP In single data byte master read, the START and STOP must both be set
