RTEMS  5.1
spi.c File Reference
#include "chip.h"
#include <stdint.h>
void SPI_Enable (Spi *spi)
 Enables a SPI peripheral. More...
void SPI_Disable (Spi *spi)
 Disables a SPI peripheral. More...
void SPI_EnableIt (Spi *spi, uint32_t dwSources)
 Enables one or more interrupt sources of a SPI peripheral. More...
void SPI_DisableIt (Spi *spi, uint32_t dwSources)
 Disables one or more interrupt sources of a SPI peripheral. More...
void SPI_Configure (Spi *spi, uint32_t dwId, uint32_t dwConfiguration)
 Configures a SPI peripheral as specified. The configuration can be computed using several macros (see SPI Configuration Macros). More...
void SPI_ChipSelect (Spi *spi, uint8_t cS)
 Configures SPI chip select. More...
void SPI_SetMode (Spi *spi, uint32_t dwConfiguration)
 Configures SPI Mode Register. More...
void SPI_ReleaseCS (Spi *spi)
 Configures SPI to release last used CS line. More...
void SPI_ConfigureNPCS (Spi *spi, uint32_t dwNpcs, uint32_t dwConfiguration)
 Configures a chip select of a SPI peripheral. The chip select configuration is computed using several macros (see SPI Configuration Macros). More...
void SPI_ConfigureCSMode (Spi *spi, uint32_t dwNpcs, uint32_t bReleaseOnLast)
 Configures a chip select active mode of a SPI peripheral. More...
uint32_t SPI_GetStatus (Spi *spi)
 Get the current status register of the given SPI peripheral. More...
uint32_t SPI_Read (Spi *spi)
 Reads and returns the last word of data received by a SPI peripheral. This method must be called after a successful SPI_Write call. More...
void SPI_Write (Spi *spi, uint32_t dwNpcs, uint16_t wData)
 Sends data through a SPI peripheral. If the SPI is configured to use a fixed peripheral select, the npcs value is meaningless. Otherwise, it identifies the component which shall be addressed. More...
void SPI_WriteLast (Spi *spi, uint32_t dwNpcs, uint16_t wData)
 Sends last data through a SPI peripheral. If the SPI is configured to use a fixed peripheral select, the npcs value is meaningless. Otherwise, it identifies the component which shall be addressed. More...
uint32_t SPI_IsFinished (Spi *spi)
 Check if SPI transfer finish. More...
Implementation of Serial Peripheral Interface (SPI) controller.
◆ SPI_ChipSelect()
void SPI_ChipSelect ( Spi *  spi,
uint8_t  cS
Parameters
spiPointer to an SPI instance.
cSChip select of NPSCx.
◆ SPI_Configure()
void SPI_Configure ( Spi *  spi,
uint32_t  dwId,
Parameters
idPeripheral ID of the SPI.
configurationValue of the SPI configuration register.
◆ SPI_ConfigureCSMode()
void SPI_ConfigureCSMode ( Spi *  spi,
uint32_t  dwNpcs,
Parameters
dwNpcsChip select to configure (0, 1, 2 or 3).
bReleaseOnLastCS controlled by last transfer. SPI_ReleaseCS() is used to release CS.
◆ SPI_ConfigureNPCS()
void SPI_ConfigureNPCS ( Spi *  spi,
uint32_t  dwNpcs,
Parameters
npcsChip select to configure (0, 1, 2 or 3).
configurationDesired chip select configuration.
◆ SPI_Disable()
void SPI_Disable ( Spi *  spi)
Parameters
◆ SPI_DisableIt()
void SPI_DisableIt ( Spi *  spi,
uint32_t  dwSources
Parameters
sourcesBitwise OR of selected interrupt sources.
◆ SPI_Enable()
void SPI_Enable ( Spi *  spi)
Parameters
◆ SPI_EnableIt()
void SPI_EnableIt ( Spi *  spi,
uint32_t  dwSources
Parameters
◆ SPI_GetStatus()
uint32_t SPI_GetStatus ( Spi *  spi)
Note
This resets the internal value of the status register, so further read may yield different values.
Parameters
spiPointer to a Spi instance.
Returns
SPI status register.
◆ SPI_IsFinished()
uint32_t SPI_IsFinished ( Spi *  spi)
Parameters
Returns
Returns 1 if there is no pending write operation on the SPI; otherwise returns 0.
◆ SPI_Read()
uint32_t SPI_Read ( Spi *  spi)
Parameters
spiPointer to an Spi instance.
Returns
read data.
◆ SPI_ReleaseCS()
void SPI_ReleaseCS ( Spi *  spi)
Parameters
◆ SPI_SetMode()
void SPI_SetMode ( Spi *  spi,
Parameters
configurationValue of the SPI mode register.
◆ SPI_Write()
void SPI_Write ( Spi *  spi,
uint32_t  dwNpcs,
uint16_t  wData
Parameters
npcsChip select of the component to address (0, 1, 2 or 3).
dataWord of data to send.
◆ SPI_WriteLast()
void SPI_WriteLast ( Spi *  spi,
uint32_t  dwNpcs,
uint16_t  wData
Parameters
