41 #ifndef __ALT_QSPI_PRIVATE_H__    42 #define __ALT_QSPI_PRIVATE_H__    50 #define ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT 1    54 #define ALT_QSPI_PAGE_ADDR_MSK          0xFFFFFF00    55 #define ALT_QSPI_PAGE_SIZE              0x00000100 // 256 B    56 #define ALT_QSPI_SUBSECTOR_ADDR_MSK     0xFFFFF000    57 #define ALT_QSPI_SUBSECTOR_SIZE         0x00001000 // 4096 B    58 #define ALT_QSPI_SECTOR_ADDR_MSK        0xFFFF0000    59 #define ALT_QSPI_SECTOR_SIZE            0x00010000 // 64 KiB    60 #define ALT_QSPI_BANK_ADDR_MSK          0xFF000000    61 #define ALT_QSPI_BANK_SIZE              0x01000000 // 16 MiB    63 #if ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT    64 #define ALT_QSPI_N25Q_DIE_ADDR_MSK      0xFE000000    65 #define ALT_QSPI_N25Q_DIE_SIZE          0x02000000 // 32 MiB    73 #define ALT_QSPI_TSHSL_NS_DEF       (50)    74 #define ALT_QSPI_TSD2D_NS_DEF       (0)    75 #define ALT_QSPI_TCHSH_NS_DEF       (4)    76 #define ALT_QSPI_TSLCH_NS_DEF       (4)    87 #define ALT_QSPI_STIG_OPCODE_READ                 (0x03)    88 #define ALT_QSPI_STIG_OPCODE_4BYTE_READ           (0x13)    89 #define ALT_QSPI_STIG_OPCODE_FASTREAD             (0x0B)    90 #define ALT_QSPI_STIG_OPCODE_FASTREAD_DUAL_OUTPUT (0x3B)    91 #define ALT_QSPI_STIG_OPCODE_FASTREAD_QUAD_OUTPUT (0x6B)    92 #define ALT_QSPI_STIG_OPCODE_FASTREAD_DUAL_IO     (0xBB)    93 #define ALT_QSPI_STIG_OPCODE_FASTREAD_QUAD_IO     (0xEB)    94 #define ALT_QSPI_STIG_OPCODE_PP                   (0x02)    95 #define ALT_QSPI_STIG_OPCODE_DUAL_PP              (0xA2)    96 #define ALT_QSPI_STIG_OPCODE_QUAD_PP              (0x32)    97 #define ALT_QSPI_STIG_OPCODE_RDID                 (0x9F)    98 #define ALT_QSPI_STIG_OPCODE_WREN                 (0x06)    99 #define ALT_QSPI_STIG_OPCODE_WRDIS                (0x04)   100 #define ALT_QSPI_STIG_OPCODE_RDSR                 (0x05)   101 #define ALT_QSPI_STIG_OPCODE_WRSR                 (0x01)   102 #define ALT_QSPI_STIG_OPCODE_SUBSEC_ERASE         (0x20)   103 #define ALT_QSPI_STIG_OPCODE_SEC_ERASE            (0xD8)   104 #define ALT_QSPI_STIG_OPCODE_BULK_ERASE           (0xC7)   105 #define ALT_QSPI_STIG_OPCODE_DIE_ERASE            (0xC4)   106 #define ALT_QSPI_STIG_OPCODE_CHIP_ERASE           (0x60)   107 #define ALT_QSPI_STIG_OPCODE_RD_EXT_REG           (0xC8)   108 #define ALT_QSPI_STIG_OPCODE_WR_EXT_REG           (0xC5)   109 #define ALT_QSPI_STIG_OPCODE_RD_STAT_REG          (0x05)   110 #define ALT_QSPI_STIG_OPCODE_WR_STAT_REG          (0x01)   111 #define ALT_QSPI_STIG_OPCODE_ENTER_4BYTE_MODE     (0xB7)   112 #define ALT_QSPI_STIG_OPCODE_EXIT_4BYTE_MODE      (0xE9)   115 #if ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT   116 #define ALT_QSPI_STIG_OPCODE_RESET_EN             (0x66)   117 #define ALT_QSPI_STIG_OPCODE_RESET_MEM            (0x99)   118 #define ALT_QSPI_STIG_OPCODE_RDFLGSR              (0x70)   119 #define ALT_QSPI_STIG_OPCODE_CLRFLGSR             (0x50)   120 #define ALT_QSPI_STIG_OPCODE_DISCVR_PARAM         (0x5A)   126 #define QSPI_READ_CLK_MHZ           (50)   127 #define QSPI_FASTREAD_CLK_MHZ       (100)   130 #define ALT_QSPI_STIG_RDID_JEDECID_MICRON      (0x20)   131 #define ALT_QSPI_STIG_RDID_JEDECID_NUMONYX     (0x20) // Same as Micron   132 #define ALT_QSPI_STIG_RDID_JEDECID_SPANSION    (0xEF)   133 #define ALT_QSPI_STIG_RDID_JEDECID_WINBOND     (0xEF) // Same as Spansion   134 #define ALT_QSPI_STIG_RDID_JEDECID_MACRONIC    (0xC2)   135 #define ALT_QSPI_STIG_RDID_JEDECID_ATMEL       (0x1F)   137 #define ALT_QSPI_STIG_RDID_JEDECID_GET(value)    ((value >>  0) & 0xff)   138 #define ALT_QSPI_STIG_RDID_CAPACITYID_GET(value) ((value >> 16) & 0xff)   140 #define ALT_QSPI_STIG_FLAGSR_ERASEPROGRAMREADY_GET(value) ((value >> 7) & 0x1)   141 #define ALT_QSPI_STIG_FLAGSR_ERASEREADY_GET(value)        ((value >> 7) & 0x1)   142 #define ALT_QSPI_STIG_FLAGSR_PROGRAMREADY_GET(value)      ((value >> 7) & 0x1)   143 #define ALT_QSPI_STIG_FLAGSR_ERASEERROR_GET(value)        ((value >> 5) & 0x1)   144 #define ALT_QSPI_STIG_FLAGSR_PROGRAMERROR_GET(value)      ((value >> 4) & 0x1)   145 #define ALT_QSPI_STIG_FLAGSR_ADDRESSINGMODE_GET(value)    ((value >> 1) & 0x1)   146 #define ALT_QSPI_STIG_FLAGSR_PROTECTIONERROR_GET(value)   ((value >> 0) & 0x1)   148 #define ALT_QSPI_STIG_SR_BUSY_GET(value)                  ((value >> 0) & 0x1)   152 #define ALT_QSPI_TIMEOUT_INFINITE (0xffffffff)   156 ALT_STATUS_CODE alt_qspi_stig_cmd(uint32_t opcode, uint32_t dummy, uint32_t timeout);
   158                                      uint32_t num_bytes, uint32_t * output,
   161                                      uint32_t num_bytes,
const uint32_t * input,
   173 #endif // __ALT_PRIVATE_QSPI_H__ int32_t ALT_STATUS_CODE
Definition: hwlib.h:60
unsigned size
Definition: tte.h:74
