RTEMS  5.1
afe_dma.c File Reference
#include "chip.h"
#include "afe_dma.h"
#include "xdmad.h"
#include <stdint.h>
#include <assert.h>
uint32_t Afe_ConfigureDma (AfeDma *pAfed, Afec *pAfeHw, uint8_t AfeId, sXdmad *pXdmad)
 Initializes the AfeDma structure and the corresponding AFE & DMA . hardware select value. The driver will uses DMA channel 0 for RX . The DMA channels are freed automatically when no DMA command processing. More...
uint32_t Afe_SendData (AfeDma *pAfed, AfeCmd *pCommand)
 Starts a AFE transfer. This is a non blocking function. It will return as soon as the transfer is started. More...
◆ Afe_ConfigureDma()
uint32_t Afe_ConfigureDma ( AfeDma *  pAfed,
Afec *  pAfeHw,
uint8_t  AfeId,
sXdmad *  pXdmad
Parameters
pAfedPointer to a AfeDma instance.
pAfeHwAssociated Afe peripheral.
AfeIdAfe peripheral identifier.
pDmadPointer to a Dmad instance.
◆ Afe_SendData()
uint32_t Afe_SendData ( AfeDma *  pAfed,
AfeCmd *  pCommand
Parameters
pCommandPointer to the Afe command to execute.
Returns
0 if the transfer has been started successfully; otherwise returns AFE_ERROR_LOCK is the driver is in use, or AFE_ERROR if the command is not valid.
