RTEMS  5.1
acc.c File Reference
#include "chip.h"
#include "acc.h"
void ACC_Configure (Acc *pAcc, uint8_t idAcc, uint8_t ucSelplus, uint8_t ucSelminus, uint16_t wAc_en, uint16_t wEdge, uint16_t wInvert)
 Initialize the ACC controller. More...
void ACC_SetComparisonPair (Acc *pAcc, uint8_t ucSelplus, uint8_t ucSelminus)
uint32_t ACC_GetComparisonResult (Acc *pAcc, uint32_t dwStatus)
Implementation of Analog Comparator Controller (ACC).
◆ ACC_Configure()
void ACC_Configure ( Acc *  pAcc,
uint8_t  idAcc,
uint8_t  ucSelplus,
uint8_t  ucSelminus,
uint16_t  wAc_en,
uint16_t  wEdge,
uint16_t  wInvert
Parameters
pAccPointer to an Acc instance.
idAccACC identifier
ucSelplusinput connected to inp, 0~7
ucSelminusinput connected to inm,0~7
wAc_enAnalog comparator enabled/disabled
wEdgeCF flag triggering mode
wInvertINVert comparator output,use pattern defined in the device header file
◆ ACC_GetComparisonResult()
uint32_t ACC_GetComparisonResult ( Acc *  pAcc,
uint32_t  dwStatus
Return Comparison Result
Parameters
dwStatusvalue of ACC_ISR
◆ ACC_SetComparisonPair()
void ACC_SetComparisonPair ( Acc *  pAcc,
uint8_t  ucSelplus,
uint8_t  ucSelminus
Return the Channel Converted Data
Parameters
ucSelplusinput applied on ACC SELPLUS
ucSelminusinput applied on ACC SELMINUS
