    RTEMS
    5.1
Go to the documentation of this file.   75 #define         F_RX_FIRST       0x1    77 #define         F_ACCESS_32_BITS 0x100    79 #define TX_INIT_RATE         16    80 #define TX_INIT_MAX_RATE     64    81 #define RX_INIT_LATENCY      64    82 #define RX_INIT_EARLY_THRESH 208     83 #define RX_NEXT_EARLY_THRESH 500    85 #define EEPROMSIZE      0x40    86 #define MAX_EEPROMBUSY  1000    87 #define EP_LAST_TAG     0xd7    88 #define EP_MAX_BOARDS   16   103 #define EP_ID_PORT      0x110   109 #define IS_BASE (is->id_iobase)   110 #define BASE    (sc->ep_io_addr)   116 #define EEPROM_CMD_RD    0x0080    117 #define EEPROM_CMD_WR    0x0040    118 #define EEPROM_CMD_ERASE 0x00c0    119 #define EEPROM_CMD_EWEN  0x0030    121 #define EEPROM_BUSY     (1<<15)   122 #define EEPROM_TST_MODE     (1<<14)   127 #define is_eeprom_busy(b) (inw((b)+EP_W0_EEPROM_COMMAND)&EEPROM_BUSY)   128 #define GO_WINDOW(x)      outw(BASE+EP_COMMAND, WINDOW_SELECT|(x))   140 #define EEPROM_NODE_ADDR_0  0x0    141 #define EEPROM_NODE_ADDR_1  0x1    142 #define EEPROM_NODE_ADDR_2  0x2    143 #define EEPROM_PROD_ID      0x3    144 #define EEPROM_MFG_ID       0x7    145 #define EEPROM_ADDR_CFG     0x8    146 #define EEPROM_RESOURCE_CFG 0x9    157 #define EP_COMMAND      0x0e       159 #define EP_STATUS       0x0e       161 #define EP_WINDOW       0x0f       167 #define EP_W0_EEPROM_DATA   0x0c   168 #define EP_W0_EEPROM_COMMAND    0x0a   169 #define EP_W0_RESOURCE_CFG  0x08   170 #define EP_W0_ADDRESS_CFG   0x06   171 #define EP_W0_CONFIG_CTRL   0x04   173 #define EP_W0_PRODUCT_ID    0x02   174 #define EP_W0_MFG_ID        0x00   180 #define EP_W1_TX_PIO_WR_2   0x02   181 #define EP_W1_TX_PIO_WR_1   0x00   183 #define EP_W1_FREE_TX       0x0c   184 #define EP_W1_TX_STATUS     0x0b       185 #define EP_W1_TIMER     0x0a       186 #define EP_W1_RX_STATUS     0x08   187 #define EP_W1_RX_PIO_RD_2   0x02   188 #define EP_W1_RX_PIO_RD_1   0x00   194 #define EP_W2_ADDR_5        0x05   195 #define EP_W2_ADDR_4        0x04   196 #define EP_W2_ADDR_3        0x03   197 #define EP_W2_ADDR_2        0x02   198 #define EP_W2_ADDR_1        0x01   199 #define EP_W2_ADDR_0        0x00   205 #define EP_W3_FREE_TX       0x0c   206 #define EP_W3_FREE_RX       0x0a   212 #define EP_W4_MEDIA_TYPE    0x0a   213 #define EP_W4_CTRLR_STATUS  0x08   214 #define EP_W4_NET_DIAG      0x06   215 #define EP_W4_FIFO_DIAG     0x04   216 #define EP_W4_HOST_DIAG     0x02   217 #define EP_W4_TX_DIAG       0x00   223 #define EP_W5_READ_0_MASK   0x0c   224 #define EP_W5_INTR_MASK     0x0a   225 #define EP_W5_RX_FILTER     0x08   226 #define EP_W5_RX_EARLY_THRESH   0x06   227 #define EP_W5_TX_AVAIL_THRESH   0x02   228 #define EP_W5_TX_START_THRESH   0x00   234 #define TX_TOTAL_OK     0x0c   235 #define RX_TOTAL_OK     0x0a   236 #define TX_DEFERRALS        0x08   237 #define RX_FRAMES_OK        0x07   238 #define TX_FRAMES_OK        0x06   239 #define RX_OVERRUNS     0x05   240 #define TX_COLLISIONS       0x04   241 #define TX_AFTER_1_COLLISION    0x03   242 #define TX_AFTER_X_COLLISIONS   0x02   243 #define TX_NO_SQE       0x01   244 #define TX_CD_LOST      0x00   260 #define GLOBAL_RESET        (u_short) 0x0000       262 #define WINDOW_SELECT       (u_short) (0x1<<11)   263 #define START_TRANSCEIVER   (u_short) (0x2<<11)    269 #define RX_DISABLE      (u_short) (0x3<<11)    271 #define RX_ENABLE       (u_short) (0x4<<11)   272 #define RX_RESET        (u_short) (0x5<<11)   273 #define RX_DISCARD_TOP_PACK (u_short) (0x8<<11)   274 #define TX_ENABLE       (u_short) (0x9<<11)   275 #define TX_DISABLE      (u_short) (0xa<<11)   276 #define TX_RESET        (u_short) (0xb<<11)   277 #define REQ_INTR        (u_short) (0xc<<11)   278 #define SET_INTR_MASK       (u_short) (0xe<<11)   279 #define SET_RD_0_MASK       (u_short) (0xf<<11)   280 #define SET_RX_FILTER       (u_short) (0x10<<11)   281 #define FIL_INDIVIDUAL  (u_short) (0x1)   282 #define FIL_GROUP       (u_short) (0x2)   283 #define FIL_BRDCST  (u_short) (0x4)   284 #define FIL_ALL     (u_short) (0x8)   285 #define SET_RX_EARLY_THRESH (u_short) (0x11<<11)   286 #define SET_TX_AVAIL_THRESH (u_short) (0x12<<11)   287 #define SET_TX_START_THRESH (u_short) (0x13<<11)   288 #define STATS_ENABLE        (u_short) (0x15<<11)   289 #define STATS_DISABLE       (u_short) (0x16<<11)   290 #define STOP_TRANSCEIVER    (u_short) (0x17<<11)   295 #define ACK_INTR        (u_short) (0x6800)   296 #define C_INTR_LATCH    (u_short) (ACK_INTR|0x1)   297 #define C_CARD_FAILURE  (u_short) (ACK_INTR|0x2)   298 #define C_TX_COMPLETE   (u_short) (ACK_INTR|0x4)   299 #define C_TX_AVAIL  (u_short) (ACK_INTR|0x8)   300 #define C_RX_COMPLETE   (u_short) (ACK_INTR|0x10)   301 #define C_RX_EARLY  (u_short) (ACK_INTR|0x20)   302 #define C_INT_RQD       (u_short) (ACK_INTR|0x40)   303 #define C_UPD_STATS (u_short) (ACK_INTR|0x80)   304 #define C_MASK  (u_short) 0xFF    324 #define S_INTR_LATCH        (u_short) (0x1)   325 #define S_CARD_FAILURE      (u_short) (0x2)   326 #define S_TX_COMPLETE       (u_short) (0x4)   327 #define S_TX_AVAIL      (u_short) (0x8)   328 #define S_RX_COMPLETE       (u_short) (0x10)   329 #define S_RX_EARLY      (u_short) (0x20)   330 #define S_INT_RQD       (u_short) (0x40)   331 #define S_UPD_STATS     (u_short) (0x80)   332 #define S_MASK  (u_short) 0xFF    333 #define S_5_INTS                (S_CARD_FAILURE|S_TX_COMPLETE|\   334                  S_TX_AVAIL|S_RX_COMPLETE|S_RX_EARLY)   335 #define S_COMMAND_IN_PROGRESS   (u_short) (0x1000)   341 #define ACF_CONNECTOR_BITS  14   342 #define ACF_CONNECTOR_UTP   0   343 #define ACF_CONNECTOR_AUI   1   344 #define ACF_CONNECTOR_BNC   3   351 #define SET_IRQ(base,irq)     outw((base) + EP_W0_RESOURCE_CFG, \   352                               ((inw((base) + EP_W0_RESOURCE_CFG) & 0x0fff) | \   353                               ((u_short)(irq)<<12))  )    372 #define ERR_RX_INCOMPLETE  (u_short) (0x1<<15)   373 #define ERR_RX         (u_short) (0x1<<14)   374 #define ERR_RX_OVERRUN     (u_short) (0x8<<11)   375 #define ERR_RX_RUN_PKT     (u_short) (0xb<<11)   376 #define ERR_RX_ALIGN       (u_short) (0xc<<11)   377 #define ERR_RX_CRC     (u_short) (0xd<<11)   378 #define ERR_RX_OVERSIZE    (u_short) (0x9<<11)   379 #define ERR_RX_DRIBBLE     (u_short) (0x2<<11)   399 #define TXS_COMPLETE        0x80   400 #define TXS_SUCCES_INTR_REQ     0x40   401 #define TXS_JABBER      0x20   402 #define TXS_UNDERRUN        0x10   403 #define TXS_MAX_COLLISION   0x8   404 #define TXS_STATUS_OVERFLOW 0x4   411 #define IS_AUI              (1<<13)   412 #define IS_BNC              (1<<12)   413 #define IS_UTP              (1<<9)   415 #define ENABLE_DRQ_IRQ          0x0001   416 #define W0_P4_CMD_RESET_ADAPTER       0x4   417 #define W0_P4_CMD_ENABLE_ADAPTER      0x1   422 #define ENABLE_UTP          0xc0   423 #define DISABLE_UTP         0x0   428 #define ACTIVATE_ADAPTER_TO_CONFIG  0xff    429 #define MFG_ID              0x6d50    430 #define PROD_ID             0x9150   436 #define RX_BYTES_MASK           (u_short) (0x07ff)
