#define  | F_RX_FIRST   0x1 |
#define  | F_PROMISC   0x8 |
#define  | F_ACCESS_32_BITS   0x100 |
#define  | TX_INIT_RATE   16 |
#define  | TX_INIT_MAX_RATE   64 |
#define  | RX_INIT_LATENCY   64 |
#define  | RX_INIT_EARLY_THRESH   208 /* not less than MINCLSIZE */ |
#define  | RX_NEXT_EARLY_THRESH   500 |
#define  | EEPROMSIZE   0x40 |
#define  | MAX_EEPROMBUSY   1000 |
#define  | EP_LAST_TAG   0xd7 |
#define  | EP_MAX_BOARDS   16 |
#define  | EP_ID_PORT   0x110 |
#define  | EP_IOSIZE   16	/* 16 bytes of I/O space used. */ |
#define  | IS_BASE   (is->id_iobase) |
#define  | BASE   (sc->ep_io_addr) |
#define  | EEPROM_CMD_RD   0x0080	/* Read:  Address required (5 bits) */ |
#define  | EEPROM_CMD_WR   0x0040	/* Write: Address required (5 bits) */ |
#define  | EEPROM_CMD_ERASE   0x00c0	/* Erase: Address required (5 bits) */ |
#define  | EEPROM_CMD_EWEN   0x0030	/* Erase/Write Enable: No data required */ |
#define  | EEPROM_BUSY   (1<<15) |
#define  | EEPROM_TST_MODE   (1<<14) |
#define  | is_eeprom_busy(b)   (inw((b)+EP_W0_EEPROM_COMMAND)&EEPROM_BUSY) |
#define  | GO_WINDOW(x)   outw(BASE+EP_COMMAND, WINDOW_SELECT|(x)) |
#define  | EEPROM_NODE_ADDR_0   0x0	/* Word */ |
#define  | EEPROM_NODE_ADDR_1   0x1	/* Word */ |
#define  | EEPROM_NODE_ADDR_2   0x2	/* Word */ |
#define  | EEPROM_PROD_ID   0x3	/* 0x9[0-f]50 */ |
#define  | EEPROM_MFG_ID   0x7	/* 0x6d50 */ |
#define  | EEPROM_ADDR_CFG   0x8	/* Base addr */ |
#define  | EEPROM_RESOURCE_CFG   0x9	/* IRQ. Bits 12-15 */ |
| #define  | EP_COMMAND |
| #define  | EP_STATUS |
| #define  | EP_WINDOW |
#define  | EP_W0_EEPROM_DATA   0x0c |
#define  | EP_W0_EEPROM_COMMAND   0x0a |
#define  | EP_W0_RESOURCE_CFG   0x08 |
#define  | EP_W0_ADDRESS_CFG   0x06 |
#define  | EP_W0_CONFIG_CTRL   0x04 |
#define  | EP_W0_PRODUCT_ID   0x02 |
#define  | EP_W0_MFG_ID   0x00 |
#define  | EP_W1_TX_PIO_WR_2   0x02 |
#define  | EP_W1_TX_PIO_WR_1   0x00 |
#define  | EP_W1_FREE_TX   0x0c |
#define  | EP_W1_TX_STATUS   0x0b	/* byte */ |
#define  | EP_W1_TIMER   0x0a	/* byte */ |
#define  | EP_W1_RX_STATUS   0x08 |
#define  | EP_W1_RX_PIO_RD_2   0x02 |
#define  | EP_W1_RX_PIO_RD_1   0x00 |
#define  | EP_W2_ADDR_5   0x05 |
#define  | EP_W2_ADDR_4   0x04 |
#define  | EP_W2_ADDR_3   0x03 |
#define  | EP_W2_ADDR_2   0x02 |
#define  | EP_W2_ADDR_1   0x01 |
#define  | EP_W2_ADDR_0   0x00 |
#define  | EP_W3_FREE_TX   0x0c |
#define  | EP_W3_FREE_RX   0x0a |
#define  | EP_W4_MEDIA_TYPE   0x0a |
#define  | EP_W4_CTRLR_STATUS   0x08 |
#define  | EP_W4_NET_DIAG   0x06 |
#define  | EP_W4_FIFO_DIAG   0x04 |
#define  | EP_W4_HOST_DIAG   0x02 |
#define  | EP_W4_TX_DIAG   0x00 |
#define  | EP_W5_READ_0_MASK   0x0c |
#define  | EP_W5_INTR_MASK   0x0a |
#define  | EP_W5_RX_FILTER   0x08 |
#define  | EP_W5_RX_EARLY_THRESH   0x06 |
#define  | EP_W5_TX_AVAIL_THRESH   0x02 |
#define  | EP_W5_TX_START_THRESH   0x00 |
#define  | TX_TOTAL_OK   0x0c |
#define  | RX_TOTAL_OK   0x0a |
#define  | TX_DEFERRALS   0x08 |
#define  | RX_FRAMES_OK   0x07 |
#define  | TX_FRAMES_OK   0x06 |
#define  | RX_OVERRUNS   0x05 |
#define  | TX_COLLISIONS   0x04 |
#define  | TX_AFTER_1_COLLISION   0x03 |
#define  | TX_AFTER_X_COLLISIONS   0x02 |
#define  | TX_NO_SQE   0x01 |
#define  | TX_CD_LOST   0x00 |
| #define  | GLOBAL_RESET |
#define  | WINDOW_SELECT   (u_short) (0x1<<11) |
| #define  | START_TRANSCEIVER |
| #define  | RX_DISABLE |
#define  | RX_ENABLE   (u_short) (0x4<<11) |
#define  | RX_RESET   (u_short) (0x5<<11) |
#define  | RX_DISCARD_TOP_PACK   (u_short) (0x8<<11) |
#define  | TX_ENABLE   (u_short) (0x9<<11) |
#define  | TX_DISABLE   (u_short) (0xa<<11) |
#define  | TX_RESET   (u_short) (0xb<<11) |
#define  | REQ_INTR   (u_short) (0xc<<11) |
#define  | SET_INTR_MASK   (u_short) (0xe<<11) |
#define  | SET_RD_0_MASK   (u_short) (0xf<<11) |
#define  | SET_RX_FILTER   (u_short) (0x10<<11) |
#define  | FIL_INDIVIDUAL   (u_short) (0x1) |
#define  | FIL_GROUP   (u_short) (0x2) |
#define  | FIL_BRDCST   (u_short) (0x4) |
#define  | FIL_ALL   (u_short) (0x8) |
#define  | SET_RX_EARLY_THRESH   (u_short) (0x11<<11) |
#define  | SET_TX_AVAIL_THRESH   (u_short) (0x12<<11) |
#define  | SET_TX_START_THRESH   (u_short) (0x13<<11) |
#define  | STATS_ENABLE   (u_short) (0x15<<11) |
#define  | STATS_DISABLE   (u_short) (0x16<<11) |
#define  | STOP_TRANSCEIVER   (u_short) (0x17<<11) |
#define  | ACK_INTR   (u_short) (0x6800) |
#define  | C_INTR_LATCH   (u_short) (ACK_INTR|0x1) |
#define  | C_CARD_FAILURE   (u_short) (ACK_INTR|0x2) |
#define  | C_TX_COMPLETE   (u_short) (ACK_INTR|0x4) |
#define  | C_TX_AVAIL   (u_short) (ACK_INTR|0x8) |
#define  | C_RX_COMPLETE   (u_short) (ACK_INTR|0x10) |
#define  | C_RX_EARLY   (u_short) (ACK_INTR|0x20) |
#define  | C_INT_RQD   (u_short) (ACK_INTR|0x40) |
#define  | C_UPD_STATS   (u_short) (ACK_INTR|0x80) |
#define  | C_MASK   (u_short) 0xFF /* mask of C_* */ |
#define  | S_INTR_LATCH   (u_short) (0x1) |
#define  | S_CARD_FAILURE   (u_short) (0x2) |
#define  | S_TX_COMPLETE   (u_short) (0x4) |
#define  | S_TX_AVAIL   (u_short) (0x8) |
#define  | S_RX_COMPLETE   (u_short) (0x10) |
#define  | S_RX_EARLY   (u_short) (0x20) |
#define  | S_INT_RQD   (u_short) (0x40) |
#define  | S_UPD_STATS   (u_short) (0x80) |
#define  | S_MASK   (u_short) 0xFF /* mask of S_* */ |
| #define  | S_5_INTS |
#define  | S_COMMAND_IN_PROGRESS   (u_short) (0x1000) |
#define  | ACF_CONNECTOR_BITS   14 |
#define  | ACF_CONNECTOR_UTP   0 |
#define  | ACF_CONNECTOR_AUI   1 |
#define  | ACF_CONNECTOR_BNC   3 |
| #define  | SET_IRQ(base,  irq) |
#define  | ERR_RX_INCOMPLETE   (u_short) (0x1<<15) |
#define  | ERR_RX   (u_short) (0x1<<14) |
#define  | ERR_RX_OVERRUN   (u_short) (0x8<<11) |
#define  | ERR_RX_RUN_PKT   (u_short) (0xb<<11) |
#define  | ERR_RX_ALIGN   (u_short) (0xc<<11) |
#define  | ERR_RX_CRC   (u_short) (0xd<<11) |
#define  | ERR_RX_OVERSIZE   (u_short) (0x9<<11) |
#define  | ERR_RX_DRIBBLE   (u_short) (0x2<<11) |
#define  | TXS_COMPLETE   0x80 |
#define  | TXS_SUCCES_INTR_REQ   0x40 |
#define  | TXS_JABBER   0x20 |
#define  | TXS_UNDERRUN   0x10 |
#define  | TXS_MAX_COLLISION   0x8 |
#define  | TXS_STATUS_OVERFLOW   0x4 |
#define  | IS_AUI   (1<<13) |
#define  | IS_BNC   (1<<12) |
#define  | IS_UTP   (1<<9) |
#define  | ENABLE_DRQ_IRQ   0x0001 |
#define  | W0_P4_CMD_RESET_ADAPTER   0x4 |
#define  | W0_P4_CMD_ENABLE_ADAPTER   0x1 |
#define  | ENABLE_UTP   0xc0 |
#define  | DISABLE_UTP   0x0 |
#define  | ACTIVATE_ADAPTER_TO_CONFIG   0xff /* to the id_port */ |
#define  | MFG_ID   0x6d50 /* in EEPROM and W0 ADDR_CONFIG */ |
#define  | PROD_ID   0x9150 |
#define  | AUI   0x1 |
#define  | BNC   0x2 |
#define  | UTP   0x4 |
#define  | RX_BYTES_MASK   (u_short) (0x07ff) |
