39 #ifndef _RTEMS_RTEMS_TASKS_H 40 #define _RTEMS_RTEMS_TASKS_H 68 #define RTEMS_SELF OBJECTS_ID_OF_SELF 74 #define RTEMS_YIELD_PROCESSOR WATCHDOG_NO_TIMEOUT 87 #define RTEMS_NO_PRIORITY RTEMS_CURRENT_PRIORITY 93 #define RTEMS_MINIMUM_PRIORITY (PRIORITY_MINIMUM + 1) 105 #define RTEMS_MAXIMUM_PRIORITY PRIORITY_MAXIMUM 111 #define RTEMS_CURRENT_PRIORITY PRIORITY_MINIMUM 114 #define RTEMS_NOTEPAD_FIRST 0 116 #define RTEMS_NOTEPAD_0 0 118 #define RTEMS_NOTEPAD_1 1 120 #define RTEMS_NOTEPAD_2 2 122 #define RTEMS_NOTEPAD_3 3 124 #define RTEMS_NOTEPAD_4 4 126 #define RTEMS_NOTEPAD_5 5 128 #define RTEMS_NOTEPAD_6 6 130 #define RTEMS_NOTEPAD_7 7 132 #define RTEMS_NOTEPAD_8 8 134 #define RTEMS_NOTEPAD_9 9 136 #define RTEMS_NOTEPAD_10 10 138 #define RTEMS_NOTEPAD_11 11 140 #define RTEMS_NOTEPAD_12 12 142 #define RTEMS_NOTEPAD_13 13 144 #define RTEMS_NOTEPAD_14 14 146 #define RTEMS_NOTEPAD_15 15 148 #define RTEMS_NOTEPAD_LAST RTEMS_NOTEPAD_15 151 #define RTEMS_NUMBER_NOTEPADS (RTEMS_NOTEPAD_LAST+1) 220 rtems_task_priority initial_priority,
403 rtems_task_priority new_priority,
404 rtems_task_priority *old_priority
419 rtems_task_argument argument
461 #if !defined(RTEMS_SMP) 507 #if defined(__RTEMS_HAVE_SYS_CPUSET_H__) 561 const cpu_set_t *cpuset
627 #if defined(__RTEMS_HAVE_SYS_CPUSET_H__) Constants and Structures Associated with the Object Handler.
uint32_t rtems_attribute
This defines the type used to contain Classic API attributes.
Definition: attr.h:44
rtems_status_code rtems_task_wake_after(rtems_interval ticks)
RTEMS Task Wake After.
Definition: taskwakeafter.c:25
size_t stack_size
This is the Initialization Task's stack size.
Definition: tasks.h:185
rtems_status_code rtems_task_set_note(rtems_id id, uint32_t notepad, uint32_t note)
RTEMS Set Task Note.
Definition: tasksetnote.c:30
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: rtems/include/rtems/rtems/types.h:80
This is the API specific information required by each thread for the RTEMS API to function correctly...
Definition: tasks.h:661
rtems_status_code rtems_task_get_scheduler(rtems_id task_id, rtems_id *scheduler_id)
Gets the scheduler of a task.
Definition: taskgetscheduler.c:23
rtems_status_code rtems_scheduler_ident(rtems_name name, rtems_id *id)
Identifies a scheduler by its name.
Definition: schedulerident.c:23
rtems_status_code rtems_task_variable_delete(rtems_id tid, void **ptr)
RTEMS Delete Task Variable.
Definition: taskvariabledelete.c:32
void rtems_task
The following defines the "return type" of an RTEMS task.
Definition: tasks.h:161
rtems_name name
This is the Initialization Task's name.
Definition: tasks.h:183
Definition: rtems/include/rtems/rtems/event.h:510
rtems_status_code rtems_task_get_note(rtems_id id, uint32_t notepad, uint32_t *note)
RTEMS Get Task Node.
Definition: taskgetnote.c:30
rtems_status_code rtems_task_wake_when(rtems_time_of_day *time_buffer)
RTEMS Task Wake When.
Definition: taskwakewhen.c:27
rtems_status_code rtems_task_ident(rtems_name name, uint32_t node, rtems_id *id)
RTEMS Task Name to Id.
Definition: taskident.c:31
Event_Control System_event
This field contains the system event control for this task.
Definition: tasks.h:665
This is the Initialization Task's argument.
Definition: tasks.h:195
rtems_attribute attribute_set
This is the Initialization Task's attributes.
Definition: tasks.h:189
rtems_status_code rtems_task_mode(rtems_mode mode_set, rtems_mode mask, rtems_mode *previous_mode_set)
RTEMS Task Mode.
Definition: taskmode.c:28
Event_Control Event
This field contains the event control for this task.
Definition: tasks.h:663
Constants and Structures Related with the Thread Control Block.
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: rtems/include/rtems/rtems/types.h:119
uint32_t Priority_Control
The following type defines the control block used to manage thread priorities.
Definition: score/include/rtems/score/priority.h:56
rtems_status_code rtems_task_create(rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id)
RTEMS Task Create.
Definition: taskcreate.c:30
void _RTEMS_tasks_Initialize_user_tasks_body(void)
Definition: taskinitusers.c:44
Data structure to manage and manipulate calendar time.
Definition: rtems/include/rtems/rtems/types.h:133
ASR_Information Signal
This field contains the Classic API Signal information for this task.
Definition: tasks.h:667
Priority_Control rtems_task_priority
Define the type for an RTEMS API task priority.
Definition: tasks.h:79
rtems_status_code
Classic API Status.
Definition: status.h:46
uint32_t rtems_name
Classic API object name type.
Definition: rtems/include/rtems/rtems/types.h:74
This structure defines the Thread Control Block (TCB).
Definition: thread.h:671
This is the Initialization Task's priority.
Definition: tasks.h:187
Thread action.
Definition: thread.h:480
rtems_task_entry entry_point
This is the Initialization Task's entry point.
Definition: tasks.h:191
rtems_status_code rtems_task_restart(rtems_id id, uint32_t arg)
RTEMS Task Restart.
Definition: taskrestart.c:24
void(* _RTEMS_tasks_Initialize_user_tasks_p)(void)
When the user configures a set of Classic API initialization tasks, This variable will point to the m...
#define RTEMS_COMPILER_DEPRECATED_ATTRIBUTE
Instructs the compiler to issue a warning whenever a variable or function with this attribute will be...
Definition: basedefs.h:186
rtems_status_code rtems_task_delete(rtems_id id)
RTEMS Delete Task.
Definition: taskdelete.c:26
rtems_status_code rtems_task_set_scheduler(rtems_id task_id, rtems_id scheduler_id)
Sets the scheduler of a task.
Definition: tasksetscheduler.c:23
rtems_status_code rtems_task_start(rtems_id id, rtems_task_entry entry_point, rtems_task_argument argument)
RTEMS Start Task.
Definition: taskstart.c:41
Thread_Control rtems_tcb
External API name for Thread_Control.
Definition: tasks.h:156
rtems_status_code rtems_task_variable_add(rtems_id tid, void **ptr, void(*dtor)(void *))
RTEMS Add Task Variable.
Definition: taskvariableadd.c:32
rtems_status_code rtems_task_is_suspended(rtems_id id)
Definition: taskissuspended.c:39
CPU_Uint32ptr Thread_Entry_numeric_type
Type of the numeric argument of a thread entry function with at least one numeric argument...
Definition: thread.h:110
Thread_Entry_numeric_type rtems_task_argument
The following defines the argument to an RTEMS task.
Definition: tasks.h:166
rtems_id rtems_task_self(void)
RTEMS Get Self Task Id.
Definition: taskself.c:24
rtems_status_code rtems_task_set_priority(rtems_id id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
RTEMS Set Task Priority.
Definition: tasksetpriority.c:24
rtems_task(* rtems_task_entry)(rtems_task_argument)
The following defines the type for the entry point of an RTEMS task.
Definition: tasks.h:171
rtems_mode mode_set
This is the Initialization Task's initial mode.
Definition: tasks.h:193
Thread_Action Signal_action
Signal post-switch action in case signals are pending.
Definition: tasks.h:672
The following records define the Initialization Tasks Table.
Definition: tasks.h:181
Modes_Control rtems_mode
Task mode type.
Definition: rtems/include/rtems/rtems/types.h:167
rtems_status_code rtems_task_variable_get(rtems_id tid, void **ptr, void **result)
Get a per-task variable.
Definition: taskvariableget.c:32
rtems_status_code rtems_task_suspend(rtems_id id)
RTEMS Suspend Task.
Definition: tasksuspend.c:24
rtems_status_code rtems_task_resume(rtems_id id)
RTEMS Resume Task.
Definition: taskresume.c:24
