rtems_termios_device_handler Struct Reference
Termios device handler. More...
#include <termiostypes.h>
bool(* first_open )(struct rtems_termios_tty *tty, rtems_termios_device_context *context, struct termios *term, rtems_libio_open_close_args_t *args)
 First open of this device. More...
void(* last_close )(struct rtems_termios_tty *tty, rtems_termios_device_context *context, rtems_libio_open_close_args_t *args)
 Last close of this device. More...
int(* poll_read )(rtems_termios_device_context *context)
 Polled read. More...
void(* write )(rtems_termios_device_context *context, const char *buf, size_t len)
 Polled write in case mode is TERMIOS_POLLED or write support otherwise. More...
bool(* set_attributes )(rtems_termios_device_context *context, const struct termios *term)
 Set attributes after a Termios settings change. More...
rtems_termios_device_mode mode
 Termios device mode.
See also
rtems_termios_device_install().
Field Documentation
◆ first_open
bool(* rtems_termios_device_handler::first_open) (struct rtems_termios_tty *tty, rtems_termios_device_context *context, struct termios *term, rtems_libio_open_close_args_t *args)
Parameters
[in]ttyThe Termios control. This parameter may be passed to interrupt service routines since it must be provided for the rtems_termios_enqueue_raw_characters() and rtems_termios_dequeue_characters() functions.
[in]contextThe Termios device context.
[in]termThe current Termios attributes.
[in]argsThe open/close arguments. This is parameter provided to support legacy drivers. It must not be used by new drivers.
Return values
trueSuccessful operation.
falseCannot open device.
See also
rtems_termios_get_device_context() and rtems_termios_set_best_baud().
◆ last_close
void(* rtems_termios_device_handler::last_close) (struct rtems_termios_tty *tty, rtems_termios_device_context *context, rtems_libio_open_close_args_t *args)
Parameters
◆ poll_read
int(* rtems_termios_device_handler::poll_read) (rtems_termios_device_context *context)
Polled read.
In case mode is TERMIOS_IRQ_DRIVEN or TERMIOS_TASK_DRIVEN, then data is received via rtems_termios_enqueue_raw_characters().
Parameters
Return values
charThe received data encoded as unsigned char.
-1No data currently available.
◆ set_attributes
bool(* rtems_termios_device_handler::set_attributes) (rtems_termios_device_context *context, const struct termios *term)
Parameters
[in]termThe new Termios attributes.
Return values
falseInvalid attributes.
◆ write
void(* rtems_termios_device_handler::write) (rtems_termios_device_context *context, const char *buf, size_t len)
Parameters
[in]bufThe output buffer.
[in]lenThe output buffer length in characters.
