rtems_ftpfs_entry Struct Reference
Connection entry for each open file stream. More...
off_t file_size
int ctrl_socket
 Control connection socket.
uint32_t client_address
int data_socket
 Data transfer socket.
size_t reply_current
 Current index into the reply buffer.
size_t reply_end
 End index of the reply buffer.
char reply_buffer [128]
 Buffer for relpy data.
bool eof
 End of file flag.
bool write
bool do_size_command
 Indicates if we should do a SIZE command. More...
ino_t ino
const char * user
const char * password
const char * hostname
const char * filename
char buffer []
Field Documentation
◆ do_size_command
bool rtems_ftpfs_entry::do_size_command
The first call to the rtems_ftpfs_fstat() handler is issued by the path evaluation to check for access permission. For this case we avoid the SIZE command.
