rtems_bdbuf_cache Struct Reference
The BD buffer cache. More...
Collaboration diagram for rtems_bdbuf_cache:
Collaboration graph
[legend]
rtems_id swapout
 Swapout task ID.
bool swapout_enabled
 Swapout is only running if enabled. More...
rtems_chain_control swapout_free_workers
 The work threads for the swapout task. More...
rtems_bdbuf_bufferbds
 Pointer to table of buffer descriptors. More...
void * buffers
 The buffer's memory. More...
size_t buffer_min_count
 Number of minimum size buffers that fit the buffer memory. More...
size_t max_bds_per_group
 The number of BDs of minimum buffer size that fit in a group. More...
uint32_t flags
 Configuration flags. More...
rtems_bdbuf_lock_type lock
 The cache lock. More...
rtems_bdbuf_lock_type sync_lock
 Sync calls block writes. More...
bool sync_active
 True if a sync is active. More...
rtems_id sync_requester
 The sync requester. More...
rtems_disk_devicesync_device
 The device to sync and BDBUF_INVALID_DEV not a device sync. More...
rtems_bdbuf_buffertree
 Buffer descriptor lookup AVL tree root. More...
rtems_chain_control lru
 Least recently used list.
rtems_chain_control modified
 Modified buffers list.
rtems_chain_control sync
 Buffers to sync list.
rtems_bdbuf_waiters access_waiters
 Wait for a buffer in ACCESS_CACHED, ACCESS_MODIFIED or ACCESS_EMPTY state. More...
rtems_bdbuf_waiters transfer_waiters
 Wait for a buffer in TRANSFER state. More...
rtems_bdbuf_waiters buffer_waiters
 Wait for a buffer and no one is available. More...
rtems_bdbuf_swapout_transferswapout_transfer
rtems_bdbuf_swapout_workerswapout_workers
size_t group_count
 The number of groups. More...
rtems_bdbuf_groupgroups
 The groups. More...
rtems_id read_ahead_task
 Read-ahead task.
rtems_chain_control read_ahead_chain
 Read-ahead request chain.
bool read_ahead_enabled
 Read-ahead enabled.
rtems_status_code init_status
 The initialization status.
Field Documentation
◆ access_waiters
rtems_bdbuf_waiters rtems_bdbuf_cache::access_waiters
◆ bds
rtems_bdbuf_buffer* rtems_bdbuf_cache::bds
◆ buffer_min_count
size_t rtems_bdbuf_cache::buffer_min_count
◆ buffer_waiters
rtems_bdbuf_waiters rtems_bdbuf_cache::buffer_waiters
◆ buffers
void* rtems_bdbuf_cache::buffers
◆ flags
uint32_t rtems_bdbuf_cache::flags
◆ group_count
size_t rtems_bdbuf_cache::group_count
◆ groups
rtems_bdbuf_group* rtems_bdbuf_cache::groups
The groups.
◆ lock
rtems_bdbuf_lock_type rtems_bdbuf_cache::lock
The cache lock.
It locks all cache data, BD and lists.
◆ max_bds_per_group
size_t rtems_bdbuf_cache::max_bds_per_group
◆ swapout_enabled
bool rtems_bdbuf_cache::swapout_enabled
Set to false to kill the swap out task. It deletes itself.
◆ swapout_free_workers
rtems_chain_control rtems_bdbuf_cache::swapout_free_workers
◆ sync_active
bool rtems_bdbuf_cache::sync_active
◆ sync_device
rtems_disk_device* rtems_bdbuf_cache::sync_device
◆ sync_lock
rtems_bdbuf_lock_type rtems_bdbuf_cache::sync_lock
◆ sync_requester
rtems_id rtems_bdbuf_cache::sync_requester
The sync requester.
◆ transfer_waiters
rtems_bdbuf_waiters rtems_bdbuf_cache::transfer_waiters
◆ tree
rtems_bdbuf_buffer* rtems_bdbuf_cache::tree
There is only one.
