_rtems_rfs_group Struct Reference
Creates bit allocator for blocks in the group simpler. More...
#include <rtems-rfs-group.h>
Collaboration diagram for _rtems_rfs_group:
Collaboration graph
[legend]
rtems_rfs_buffer_block base
 Base block number.
size_t size
 The number of blocks in the group. More...
rtems_rfs_bitmap_control block_bitmap
 The block bitmap control.
rtems_rfs_buffer_handle block_bitmap_buffer
 The handle to the block bitmap buffer.
rtems_rfs_bitmap_control inode_bitmap
 The inode bitmap control.
rtems_rfs_buffer_handle inode_bitmap_buffer
 The handle to the inode bitmap buffer.
A group is a selection of blocks on the disk. Typically the number of blocks in a group is determined by the number of bits a block holds. This makes the bit allocator for blocks in the group simpler plus is allows a simple way to localise access to files and directories.
Field Documentation
◆ size
size_t _rtems_rfs_group::size
Groups may be different sizes.
