Data Fields | |
Priority_bit_map_Word | major_bit_map |
Each sixteen bit entry in this word is associated with one of the sixteen entries in the bit map. | |
Priority_bit_map_Word | bit_map [16] |
Each bit in the bit map indicates whether or not there are threads ready at a particular priority. More... | |
Priority_bit_map_Word Priority_bit_map_Control::bit_map[16] |
The mapping of individual priority levels to particular bits is processor dependent as is the value of each bit used to indicate that threads are ready at that priority.
