MPCI_Control Struct Reference
This type defines the Multiprocessor Communications Interface (MPCI) Table. More...
#include <mpci.h>
Collaboration diagram for MPCI_Control:
Collaboration graph
[legend]
uint32_t default_timeout
 This fields contains the timeout for MPCI operations in ticks. More...
size_t maximum_packet_size
 This field contains the maximum size of a packet supported by this MPCI layer. More...
MPCI_initialization_entry initialization
 This field points to the MPCI initialization entry point. More...
MPCI_get_packet_entry get_packet
 This field points to the MPCI get packet entry point. More...
MPCI_return_packet_entry return_packet
 This field points to the MPCI return packet entry point. More...
MPCI_send_entry send_packet
 This field points to the MPCI send packet entry point. More...
MPCI_receive_entry receive_packet
 This field points to the MPCI receive packet entry point. More...
This table defines the user-provided MPCI which is a required part of a multiprocessor system.
For non-blocking local operations that become remote operations, we need a timeout. This is a per-driver timeout: default_timeout
Field Documentation
◆ default_timeout
uint32_t MPCI_Control::default_timeout
◆ get_packet
MPCI_get_packet_entry MPCI_Control::get_packet
Referenced by _MPCI_Get_packet().
◆ initialization
MPCI_initialization_entry MPCI_Control::initialization
Referenced by _MPCI_Initialization().
◆ maximum_packet_size
size_t MPCI_Control::maximum_packet_size
This size places a limit on the size of a message which can be transmitted over this interface.
Referenced by rtems_message_queue_create().
◆ receive_packet
MPCI_receive_entry MPCI_Control::receive_packet
Referenced by _MPCI_Receive_packet().
◆ return_packet
MPCI_return_packet_entry MPCI_Control::return_packet
Referenced by _MPCI_Return_packet().
◆ send_packet
MPCI_send_entry MPCI_Control::send_packet
