21 #ifndef _RTEMS_SCORE_CPU_H 22 #define _RTEMS_SCORE_CPU_H 28 #include <rtems/score/types.h> 54 #define CPU_INLINE_ENABLE_DISPATCH FALSE 83 #define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE 96 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE 116 #define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE 130 #define CPU_ALLOCATE_INTERRUPT_STACK TRUE 141 #define CPU_ISR_PASSES_FRAME_POINTER 1 178 #if ( BLACKFIN_CPU_HAS_FPU == 1 ) 179 #define CPU_HARDWARE_FP TRUE 181 #define CPU_HARDWARE_FP FALSE 183 #define CPU_SOFTWARE_FP FALSE 209 #define CPU_ALL_TASKS_ARE_FP FALSE 226 #define CPU_IDLE_TASK_IS_FP FALSE 257 #define CPU_USE_DEFERRED_FP_SWITCH TRUE 283 #define CPU_PROVIDES_IDLE_THREAD_BODY TRUE 296 #define CPU_STACK_GROWS_UP FALSE 321 #define CPU_STRUCTURE_ALIGNMENT 323 #define CPU_TIMESTAMP_USE_INT64_INLINE TRUE 346 #define CPU_BIG_ENDIAN FALSE 361 #define CPU_LITTLE_ENDIAN TRUE 375 #define CPU_MODES_INTERRUPT_MASK 0x00000001 377 #define CPU_PER_CPU_CONTROL_SIZE 0 443 uint32_t register_r4;
444 uint32_t register_r5;
445 uint32_t register_r6;
446 uint32_t register_r7;
448 uint32_t register_p3;
449 uint32_t register_p4;
450 uint32_t register_p5;
451 uint32_t register_fp;
452 uint32_t register_sp;
454 uint32_t register_rets;
459 #define _CPU_Context_Get_SP( _context ) \ 460 (_context)->register_sp 539 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) 552 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 563 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 16 569 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) 576 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE 589 #define CPU_STACK_MINIMUM_SIZE (1024*8) 591 #define CPU_SIZEOF_POINTER 4 601 #define CPU_ALIGNMENT 8 626 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT 644 #define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT 659 #define CPU_STACK_ALIGNMENT 8 677 #define _CPU_Initialize_vectors() 689 #define _CPU_ISR_Disable( _level ) \ 691 __asm__ volatile ("cli %0; csync \n" : "=d" (_level) ); \ 706 #define _CPU_ISR_Enable( _level ) { \ 707 __asm__ __volatile__ ("sti %0; csync \n" : : "d" (_level) ); \ 722 #define _CPU_ISR_Flash( _level ) { \ 723 __asm__ __volatile__ ("sti %0; csync; cli r0; csync" \ 724 : : "d"(_level) : "R0" ); \ 742 #define _CPU_ISR_Set_level( _new_level ) \ 744 __asm__ __volatile__ ( "sti %0; csync" : : "d"(_new_level ? 0 : 0xffff) ); \ 801 uint32_t *stack_base,
824 #define _CPU_Context_Restart_self( _the_context ) \ 825 _CPU_Context_restore( (_the_context) ); 849 #define _CPU_Context_Fp_start( _base, _offset ) \ 850 ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) 870 #define _CPU_Context_Initialize_fp( _destination ) \ 872 *(*(_destination)) = _CPU_Null_fp_context; \ 888 #define _CPU_Fatal_halt( _source, _error ) \ 890 __asm__ volatile ( "cli R1; \ 895 : : "r" (_error) ); \ 914 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE 924 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE 990 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE) 991 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \ 1011 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE) 1013 #define _CPU_Priority_Mask( _bit_number ) \ 1014 ( 1 << (_bit_number) ) 1031 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE) 1033 #define _CPU_Priority_bits_index( _priority ) \ 1231 static inline uint32_t CPU_swap_u32(
1235 uint32_t byte1, byte2, byte3, byte4, swapped;
1237 byte4 = (value >> 24) & 0xff;
1238 byte3 = (value >> 16) & 0xff;
1239 byte2 = (value >> 8) & 0xff;
1240 byte1 = value & 0xff;
1242 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
1253 #define CPU_swap_u16( value ) \ 1254 (((value&0xff) << 8) | ((value >> 8)&0xff)) 1258 CPU_Counter_ticks _CPU_Counter_read(
void );
1261 CPU_Counter_ticks second,
1262 CPU_Counter_ticks first
1265 return second - first;
void _CPU_Context_save_fp(Context_Control_fp **fp_context_ptr)
This routine saves the floating point context passed to it.
Definition: m68k/cpu.c:167
void _CPU_Context_validate(uintptr_t pattern)
Initializes and validates the CPU context with values derived from the pattern parameter.
Definition: score/cpu/mips/rtems/score/cpu.h:1109
uint32_t _CPU_ISR_Get_level(void)
Return the current interrupt disable level for this task in the format used by the interrupt level po...
Definition: avr/cpu.c:39
void _CPU_Context_volatile_clobber(uintptr_t pattern)
Clobbers all volatile registers with values derived from the pattern parameter.
Definition: score/cpu/mips/rtems/score/cpu.h:1104
This defines the minimal set of integer and processor state registers that must be saved during a vol...
Definition: score/cpu/arm/rtems/score/cpu.h:248
void _CPU_Context_restore_fp(Context_Control_fp **fp_context_ptr)
This routine restores the floating point context passed to it.
Definition: m68k/cpu.c:176
void _CPU_Context_restore(Context_Control *new_context)
This routine is generally used only to restart self in an efficient manner.
Definition: no_cpu/cpu_asm.c:112
void _CPU_Initialize(void)
CPU initialize.
Definition: avr/cpu.c:26
Blackfin Set up Basic CPU Dependency Settings Based on Compiler Settings.
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context
This variable is optional.
Definition: score/cpu/bfin/rtems/score/cpu.h:494
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: score/cpu/no_cpu/rtems/score/cpu.h:1461
This defines the set of integer and processor state registers that must be saved during an interrupt...
Definition: score/cpu/avr/rtems/score/cpu.h:425
void _CPU_Context_Initialize(Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
Initialize the context to a state suitable for starting a task after a context restore operation...
Definition: bfin/cpu.c:183
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
This routine switches from the run context to the heir context.
Definition: no_cpu/cpu_asm.c:92
void _CPU_ISR_install_vector(uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
This routine installs an interrupt vector.
Definition: avr/cpu.c:69
void _CPU_Install_interrupt_stack(void)
This routine installs the hardware interrupt stack pointer.
Definition: avr/cpu.c:101
CPU_Counter_ticks _CPU_Counter_difference(CPU_Counter_ticks second, CPU_Counter_ticks first)
Returns the difference between the second and first CPU counter value.
Definition: score/cpu/mips/rtems/score/cpu.h:1160
This defines the complete set of floating point registers that must be saved during any context switc...
Definition: score/cpu/arm/rtems/score/cpu.h:294
void _CPU_ISR_install_raw_handler(uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
This routine installs a "raw" interrupt handler directly into the processor's vector table...
Definition: avr/cpu.c:57
#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE
The following macro is a compiler specific way to indicate that the method will NOT return to the cal...
Definition: basedefs.h:162
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: arm-exception-frame-print.c:46
void * _CPU_Thread_Idle_body(uintptr_t ignored)
This routine is the CPU dependent IDLE thread body.
Definition: avr/cpu.c:125
#define SCORE_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:81
void * proc_ptr
XXX: Eventually proc_ptr needs to disappear!!!
Definition: basedefs.h:329
