RTEMS File System Mutex. More...
#include <rtems/rfs/rtems-rfs-mutex.h>
int | rtems_rfs_mutex_create (rtems_rfs_mutex *mutex) |
Create the mutex. More... | |
int | rtems_rfs_mutex_destroy (rtems_rfs_mutex *mutex) |
Destroy the mutex. More... | |
int rtems_rfs_mutex_create | ( | rtems_rfs_mutex * | mutex | ) |
Create the mutex.
[in] | mutex | is pointer to the mutex handle returned to the caller. |
0 | Successful operation. |
EIO | An error occurred. |
References rtems_build_name, rtems_rfs_trace(), rtems_semaphore_create(), and RTEMS_SUCCESSFUL.
int rtems_rfs_mutex_destroy | ( | rtems_rfs_mutex * | mutex | ) |
Destroy the mutex.
[in] | mutex | Reference to the mutex handle returned to the caller. |
References rtems_rfs_trace(), rtems_semaphore_delete(), and RTEMS_SUCCESSFUL.
Referenced by rtems_rfs_rtems_shutdown().
