RTEMS File Systems Block Position and Size Management. More...
#include <rtems/rfs/rtems-rfs-inode.h>
struct | rtems_rfs_block_pos_s |
A block position is a block number times the block size plus the offset. More... | |
struct | rtems_rfs_block_size_s |
A block size is the number of blocks less one plus the offset where the offset must be less than the block size. More... | |
#define | rtems_rfs_block_copy_bpos(_lhs, _rhs) |
Copy a block position. More... | |
#define | rtems_rfs_block_copy_size(_lhs, _rhs) |
Copy a block size. More... | |
#define | rtems_rfs_block_pos_last_block(_p, _s) ((((_p)->bno == 0) && ((_s)->count == 0)) || ((_p)->bno == ((_s)->count - 1))) |
Last block ? | |
#define | rtems_rfs_block_pos_past_end(_p, _s) |
Last block ? More... | |
#define | rtems_rfs_block_pos_block_past_end(_p, _s) (((_p)->bno && ((_s)->count == 0)) || ((_p)->bno >= (_s)->count)) |
Is the block position past the end. | |
#define | rtems_rfs_block_size_get_bpos(_s, _b) |
Copy the size to the block position. More... | |
#define | rtems_rfs_block_size_equal(_lhs, _rhs) (((_lhs)->count == (_rhs)->count) && ((_lhs)->offset == (_rhs)->offset)) |
Do the sizes match ? | |
Typedefs | |
typedef rtems_rfs_inode_block | rtems_rfs_block_no |
The block number is the same type as the inode block number. More... | |
typedef uint32_t | rtems_rfs_block_off |
The offset into a block. | |
typedef struct rtems_rfs_block_pos_s | rtems_rfs_block_pos |
typedef struct rtems_rfs_block_size_s | rtems_rfs_block_size |
A block size is the number of blocks less one plus the offset where the offset must be less than the block size. | |
void | rtems_rfs_block_get_bpos (rtems_rfs_file_system *fs, rtems_rfs_pos pos, rtems_rfs_block_pos *bpos) |
Given a position compute the block number and block offset. More... | |
rtems_rfs_pos | rtems_rfs_block_get_pos (rtems_rfs_file_system *fs, rtems_rfs_block_pos *bpos) |
Given a block position compute the absolute offset. More... | |
void | rtems_rfs_block_get_block_size (rtems_rfs_file_system *fs, rtems_rfs_pos pos, rtems_rfs_block_size *size) |
Set the size given a position. More... | |
rtems_rfs_pos | rtems_rfs_block_get_size (rtems_rfs_file_system *fs, rtems_rfs_block_size *size) |
Calculate the position given the number of blocks and the offset. More... | |
These functions manage the position in a block map as well as a size of data held in a block map. The position is the block count plus the offset into the last block where a block position of 0 and an offset of 0 is the start of a map. The size has a block count plus an offset, but the offset into the last block gives the actual size of the data in the map. This means a size will always have a block count greater than 0 when the file is not empty. A size offset of 0 and a non-zero block count means the length if aligned to the end of the block. For this reason there are 2 similar types so we know which set of rules are in use and the reason for this file.
#define rtems_rfs_block_copy_bpos | ( | _lhs, | |
_rhs | |||
[in] | _lhs | is the left hand side. |
[in] | _rhs | is the right hand side. |
#define rtems_rfs_block_copy_size | ( | _lhs, | |
_rhs | |||
Copy a block size.
#define rtems_rfs_block_pos_past_end | ( | _p, | |
_s | |||
Last block ?
#define rtems_rfs_block_size_get_bpos | ( | _s, | |
_b | |||
Note the block position and the size have different block counts.
This makes sure the sizes of the types match.
typedef struct rtems_rfs_block_pos_s rtems_rfs_block_pos |
The block field can be used hold a block number for the position as a look up cache.
void rtems_rfs_block_get_block_size | ( | rtems_rfs_file_system * | fs, |
rtems_rfs_pos | pos, | ||
rtems_rfs_block_size * | size | ||
[in] | fs | is the file system data. |
[in] | pos | is the position as an absolute offset from the start. |
[out] | size | is a pointer to the block size to fill in. |
void rtems_rfs_block_get_bpos | ( | rtems_rfs_file_system * | fs, |
rtems_rfs_block_pos * | bpos | ||
[out] | bpos | is a pointer to the block position to fill in. |
rtems_rfs_pos rtems_rfs_block_get_pos | ( | rtems_rfs_file_system * | fs, |
offset | The absolute offset. |
rtems_rfs_pos rtems_rfs_block_get_size | ( | rtems_rfs_file_system * | fs, |
If the block count is 0 the size is 0. If the block is greater than 0 and the offset is 0 the size is number of blocks multipled by the block size and if the offset is not 0 it is the offset into the last block. For example if blocks is 1 and offset is 0 the size is the block size. If the block count is 1 and size is 100 the size is 100.
[in] | size | The size in blocks and offset. |
size | The size in bytes. |
